    Duet Web Control 2.1.1 released
    Duet Web Control
    19
    51
    3.5k
    • smoki3undefined
      smoki3 @insertnamehere
      @insertnamehere I had this also on my duet 2. I now upgraded to RC6 and it is working fine
      insertnamehereundefined 1 Reply Last reply Reply Quote 0
      • hypnolobsterundefined
        hypnolobster
        I'm another with a fan thing happening. Using the laser/servo pwm with a blower on a Duet 3 for part cooling and the blower works as intended, but displays as 0 speed in DWC during a print.
        M950 F1 C"out9" Q25000
        M106 P1 C"Partcooling" S0 H-1 B0 X0.3
        • OwenDundefined
          OwenD
          With regard to the fan being missing form the DWC, I too found that initially.
          However it was simply hidden and had to be re-selected for display.
          It functions normally.
          See progression shots.
          Initial install
          Click on "Change visibility"
          Voila
          hypnolobsterundefined 1 Reply Last reply Reply Quote 0
            hypnolobster @OwenD
            @OwenD Unfortunately that's not the issue, at least with those of using using slightly odder part cooling.
            More information in general for what's happening specifically for me;
            When I call a fan name in M106, the slider is in DWC while not printing, but doesn't actually do anything. When printing, the part cooling fan works as it should, but the slider sits at zero unless I touch it (and I do then have control), until the gcode changes the fan setting (at which point the slider stays where I put it and the fan changes to the speed the gcode called for). In this instance, the option for Tool Fan and the same fan as the name I've set in M106 are available.
            If I remove the fan name from M106, it is not available while not printing at all (and neither is Tool Fan), but it otherwise functions the same during a print (Tool Fan becomes available).
            If I run M106 P1 S0.5 while not in a print, it does work.
            edit:
            After updating to RC6, the functioning slider is back while not printing, but it's displaying the pre- X value set in M106. In my case, X0.3 and setting the fan slider at 50% will cause it to snap back to 15. Using the + and - buttons is sort of fruitless unless you click really fast.
            • insertnamehereundefined
              insertnamehere @smoki3
              @smoki3 said in Duet Web Control 2.1.1 released:
              Thanks, I just needed to update to RC6 and it works now.
              • PaulHewundefined
                PaulHew
                @chrishamm
                Found this this morning.
                'Turn Everything Off' does not do anything.
                FIRMWARE_NAME: RepRapFirmware for Duet 2 Maestro FIRMWARE_VERSION: 3.0 ELECTRONICS: Duet Maestro 1.0 FIRMWARE_DATE: 2020-01-03b3
                GrodanBundefined 1 Reply Last reply Reply Quote 1
                • chrishammundefined
                  chrishamm administrators @garyd9
                  @garyd9 @PaulHew Thanks for reporting these issues! I'll fix them in v2.1.2.
                  Duet software engineer
                  PaulHewundefined 1 Reply Last reply Reply Quote 0
                  • mikedahlgrenundefined
                    mikedahlgren
                    Ever since RC6 I have been getting disconnects and the following error from "Journalctl -f"
                    Apr 06 14:34:56 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                    Apr 06 14:34:56 duet3 DuetControlServer[2170]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                    Apr 06 14:34:57 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
                    Apr 06 14:34:57 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:35260
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: [fatal] Update task faulted
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: System.ArgumentException: Requested value 'fault' was not found.
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 535.3719ms ^CApr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1] Apr 06 14:34:57 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)' Apr 06 14:34:57 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2] Apr 06 14:34:57 duet3 DuetWebServer[551]: Request finished in 540.9393ms 101 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                    Apr 06 14:34:57 duet3 DuetControlServer[2170]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                      mikedahlgren
                      Apr 06 14:59:45 duet3 DuetControlServer[7457]: Duet Control Server v1.3.1
                      Apr 06 14:59:45 duet3 DuetControlServer[7457]: Written by Christian Hammacher for Duet3D
                      Apr 06 14:59:45 duet3 DuetControlServer[7457]: Licensed under the terms of the GNU Public License Version 3
                      Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Settings loaded
                      Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Environment initialized
                      Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] Connection to Duet established
                      Apr 06 14:59:46 duet3 DuetControlServer[7457]: [info] IPC socket created at /var/run/dsf/dcs.sock
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: [info] Aux: Running code from firmware 'M20 S2 P0:/macros' on channel Aux
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: Request starting HTTP/1.1 GET http://duet3/machine
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Abnormal program termination
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: DuetWebServer.Controllers.WebSocketController[0]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket connected from ::ffff:127.0.0.1:36822
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: [fatal] Update task faulted
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: System.ArgumentException: Requested value 'fault' was not found.
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseByName(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt64& result) Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, String originalValueString, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boolean ignoreCase, Boolean throwOnFailure, TypeCode type, Int32& result)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.TryParse(Type enumType, String value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOptions options) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Utility/JsonLowerCaseStringEnumConverter.cs:line 62 Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfoNullable2.OnRead(ReadStack& state, Utf8JsonReader& reader)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonPropertyInfo.Read(JsonTokenType tokenType, ReadStack& state, Utf8JsonReader& reader)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(JsonSerializerOptions options, Utf8JsonReader& reader, ReadStack& readStack)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.ReadCore(Type returnType, JsonSerializerOptions options, Utf8JsonReader& reader)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 282
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelCollectionHelper.UpdateFromJson(IList list, Type itemType, JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelCollection.cs:line 227
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 264
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/Base/ModelObject.cs:line 248
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetAPI.Machine.MachineModel.UpdateFromFirmwareModel(String key, JsonElement jsonElement) in /home/christian/duet/DuetSoftwareFramework/src/DuetAPI/Machine/MachineModel.cs:line 134
                      Apr 06 14:59:47 duet3 DuetControlServer[7457]: at DuetControlServer.Model.Updater.Run() in /home/christian/duet/DuetSoftwareFramework/src/DuetControlServer/Model/Updater.cs:line 140
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: WebSocket disconnected from ::ffff:127.0.0.1:36822
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed action DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer) in 374.0239ms
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: Executed endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                      Apr 06 14:59:47 duet3 DuetWebServer[551]: Request finished in 374.9353ms 101
                      • PaulHewundefined
                        PaulHew @chrishamm
                        @chrishamm And fan sliders do not work or indicate current speed.
                        Sorry.
                        • DocTruckerundefined
                          DocTrucker
                          Version 2.0.7 ran fine on v0.6 and v0.8.5 boards. Is version 2.1+ dependant on using RepRapFirmware 2+ or 3+?
                            jay_s_uk @DocTrucker
                            @DocTrucker
                            Its dependant on RRF3.01+ as it uses the object model
                              DocTrucker @jay_s_uk
                              @jay_s_uk cheers, that's what I expected but I wasn't sure if it used the object model it available, or exclusively. From what you say it is the latter.
                              • GrodanBundefined
                                GrodanB @PaulHew
                                @PaulHew said in Duet Web Control 2.1.1 released:
                                @chrishamm
                                Also strange is that with a dual set-up the loaded filament is moved from T1 to T0 and cannot be unloaded.
                                (To be clear, T1 has a filament loaded, I do a pause, then immediately a cancel and suddenly T0 is loaded with T1 filament and that cannot be loaded to T1 again and T0 does not what to unload it. Temp settings is still on as espected on T1 (old temp) and t0 also as before...)
                                I had to delete the file "filaments.csv" and do a "EMERGENCY STOP" to get T0 to relese the T1 filament...
                                I think this happen when I cancel a print...
                                Which I do a lot since I try to get my filament to stick.
                                Would be nice to be able to cancel directly and not need to pause and then cancel...
                                This time I do not see the "filament.csv" so I pray to god that a power on of cycle get my printer back...
                                I did... the file was not shown until I made a power on/off cycle.
                                That would be nice if it did.
                                I also do not understand why the file "filament.csv" kept after a power cycle? At least a forced unload feature would be useful...
                                • GrodanBundefined
                                  GrodanB
                                  For some reason I cannot change the wording mistake I did above (someServer.com identified post as spam)
                                  So a power OFF/ON did work...
                                  • smoki3undefined
                                    smoki3
                                    Is M122 working for someone?
                                    SIamundefined 1 Reply Last reply Reply Quote 0
                                      Thanks, I've already fixed the crash that occurs when a heater fault occurs and I'll fix the filament assignment next. Both fixes will be available when RRF 3.01 is released. Likewise the "Turn off all" button has been fixed and a new DWC version will be released among the next DSF version.
                                      GrodanBundefined 1 Reply Last reply Reply Quote 0
                                      • SIamundefined
                                        SIam @smoki3
                                        @smoki3
                                        M122 is working here
                                        6.4.2020, 20:32:50 	m122
                                        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.01-RC6 running on Duet WiFi 1.02 or later + DueX5
                                        Board ID: 08DGM-95BNL-MGPSJ-6J9FD-3SJ6N-K1W3Y
                                        Used output buffers: 4 of 24 (22 max)
                                        Static ram: 28052
                                        Dynamic ram: 94208 of which 24 recycled
                                        Exception stack ram used: 576
                                        Never used ram: 8212
                                        Tasks: NETWORK(ready,116) HEAT(blocked,1244) DUEX(suspended,136) MAIN(running,1608) IDLE(ready,80)
                                        Owned mutexes: WiFi(NETWORK)
                                        Last reset 11:14:43 ago, cause: software
                                        Last software reset at 2020-04-06 09:18, reason: User, spinning module GCodes, available RAM 8532 bytes (slot 3)
                                        Error status: 0
                                        Free file entries: 10
                                        SD card longest block write time: 133.8ms, max retries 0
                                        MCU temperature: min 21.7, current 39.7, max 41.7
                                        Supply voltage: min 24.0, current 24.3, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                        Driver 0: standstill, SG min/max 0/981
                                        Driver 1: standstill, SG min/max 0/1023
                                        Driver 2: standstill, SG min/max 0/1023
                                        Driver 3: standstill, SG min/max 0/1023
                                        Driver 4: standstill, SG min/max 0/1023
                                        Driver 5: standstill, SG min/max not available
                                        Driver 6: standstill, SG min/max not available
                                        Driver 7: standstill, SG min/max not available
                                        Driver 9: standstill, SG min/max 0/1023
                                        Date/time: 2020-04-06 20:32:48
                                        Slowest loop: 312.35ms; fastest: 0.12ms
                                        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 107, MaxWait: 5922743ms
                                        === MainDDARing ===
                                        === AuxDDARing ===
                                        Heater 0 is on, I-accum = 0.0
                                        Heater 1 is on, I-accum = 0.7
                                        Segments left: 0
                                        Movement lock held by null
                                        HTTP is idle in state(s) 0
                                        Telnet is idle in state(s) 0
                                        File is idle in state(s) 0
                                        USB is idle in state(s) 0
                                        Aux is idle in state(s) 0
                                        Trigger is idle in state(s) 0
                                        Queue is idle in state(s) 0
                                        Daemon is idle in state(s) 0
                                        Code queue is empty.
                                        === Network ===
                                        Slowest loop: 789.12ms; fastest: 0.00ms
                                        Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(2) FTP(0) Telnet(0)
                                        HTTP sessions: 2 of 8
                                        - WiFi -
                                        Network state is active
                                        WiFi firmware version 1.23
                                        WiFi MAC address 2c:3a:e8:0b:06:33
                                        WiFi Vcc 3.44, reset reason Unknown
                                        WiFi flash size 4194304, free heap 15424
                                        WiFi IP address 192.168.188.36
                                        WiFi signal strength -49dBm, reconnections 0, sleep mode modem
                                        Socket states: 4 0 0 4 0 0 0 0
                                        === Filament sensors ===
                                        Extruder 0 sensor: ok
                                        Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
                                        RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
                                        Duet WiFi Server: 1.26
                                        Duet Web Control 3.4.0beta4 (2021-09-27)
                                        smoki3undefined 1 Reply Last reply Reply Quote 0
                                        • GrodanBundefined
                                          GrodanB @chrishamm
                                          @chrishamm said in Duet Web Control 2.1.1 released:
                                          Great, by the way, great work. Much appreciated.
                                          Do you require me to upgrade to RRF 3.01? Do not see the benefit to me until new functions are added at the moment I understand that soon it will be at the same function level as latest 2.x.
                                          Again thanks.
                                            DocTrucker @GrodanB
                                            @GrodanB said in Duet Web Control 2.1.1 released:
                                            @jay_s_uk said in Duet Web Control 2.1.1 released:
