    RepRapFirmware 3.2 planned improvements
    99
    6.6k
    • botundefined
      bot @garyd9
      @garyd9 On that list is to improve step pulse generation, and re-introduce multi-stepping. This should help achieve faster speeds on prints which are not limited by the gcode queue, but by step pulse generation.
      *not actually a robot
      • arhiundefined
        arhi @bot
        This post is deleted!
        • zaptaundefined
          zapta
          Any plans to support slicer's (e.g. Prusaslicer) time markers for more accurate time-left display?
          Or is it already implemented on RRF? I am still on 2.x.
            dc42 administrators @zapta
            @zapta said in RepRapFirmware 3.02 planned improvements:
            Do you mean the M73 command?
            • CCS86undefined
              CCS86
              Any chance of revisiting this topic?
              https://forum.duet3d.com/topic/4802/6th-order-jerk-controlled-motion-planning
                It's on the list for implementation, but IMO it's pointless as long as jerk or junction deviation is needed at corners. The first-order motion components need to be made continuous before or at the same time as worrying about third and high order components.
                botundefined CCS86undefined 2 Replies Last reply Reply Quote 0
                • Nuramoriundefined
                  Nuramori
                  • botundefined
                    bot @dc42
                    @dc42 Is there anything that a slicer could output to make improved motion planning easier for the firmware?
                    I've been playing around with IceSL, which requires a LUA script to process the sliced model and generate gcode output. And therefore, we have an opportunity to use the raw, non-truncated, slice geometry data before it is turned to gcode and calculate anything we wish and format it alongside the gcode in any way we wish.
                    Unfortunately, the underlying slicer does not generate curves. But, we can calculate angles, segment lengths, extrusion rates, etc. in the slicer and offload that from the FW.
                    I'm currently making a RRF-specific printer profile for IceSL, which is basically just implementing all the features duet users expect, and producing gcode compatible with RRF.
                    Long story short, we have the possibility now to do high-precision pre-processing of the gcode at the same time that we slice it.
                    • Bipotronicundefined
                      Bipotronic
                      Implementation of Variables of GCode Meta Comments would be useful. Or is this function already implemented?
                      • zaptaundefined
                        zapta @dc42
                        @dc42 said in RepRapFirmware 3.02 planned improvements:
                        Yes, M73. This is what I got from in a 22minutes (estimated) gcode file:
                        M73 P0 R22
                        M73 P0 R22
                        M73 P4 R21
                        M73 P9 R20
                        M73 P13 R19
                        M73 P18 R18
                        M73 P22 R17
                        M73 P27 R16
                        M73 P31 R15
                        M73 P36 R14
                        M73 P40 R13
                        M73 P45 R12
                        M73 P49 R11
                        M73 P54 R10
                        M73 P58 R9
                        M73 P63 R8
                        M73 P67 R7
                        M73 P72 R6
                        M73 P76 R5
                        M73 P81 R4
                        M73 P85 R3
                        M73 P90 R2
                        M73 P94 R1
                        M73 P99 R0
                        M73 P100 R0
                        In the early phases of the print probably the remaining time R is more useful for the estimation and in later phase probably the percentage P and actual time so far will give a better estimation.
                        The markers seem to be in (estimated) 1 minute intervals.
                          I've added M73 to the list for consideration.
                          zaptaundefined 2 Replies Last reply Reply Quote 0
                          • zaptaundefined
                            zapta @dc42
                            • CCS86undefined
                              CCS86 @dc42
                              What is causing that dependance?
                              • zaptaundefined
                                zapta @dc42
                                @dc42, FYI, I run a small experiment correlating the M73 markers with actual prints (replaced them with G10 and M140 that propagated the values to standby fields in the json). Results look very good, both for linearity and absolute time values.
                                My slicer has default setting, without any calibration for the max speed, acceleration and jerk of my printer.
                                You can probably run tests much faster using simulator mode.
                                • copystringundefined
                                  copystring
                                  Please add inverted M80/M81 for meanwell PSUs.
                                  I know. I'm inpatient. Is it a lot of work to implement this?
                                  • SpoonUnitundefined
                                    SpoonUnit
                                    Could the option be added to set the min limit for behaviours similar to that controlled my M190. A default of 41 seems fine, but ultimately arbitrary, and having the option to hand control of this value to the operator would be nice. M143 sets max limits, perhaps it could be overloaded to support specifying min limits also?
                                      droftarts administrators @dc42
                                      @dc42 really looking forward to playing with G5 Bezier curves!
                                        dc42 administrators @copystring
                                        @copystring said in RepRapFirmware 3.02 planned improvements:
                                        This is included in the planned work to make the PS_ON pin configurable.
                                        • arhiundefined
                                          arhi @dc42
                                          Support G5
                                          Does this involve maybe also G15 / G16 ? (I don't know if any slicer know how to use them, I only used them when I wrote code manually on my old milling machine)
                                          • DaveAundefined
                                            DaveA
                                            Maybe I'm just more confused than normal but I don't understand the versioning system.
                                            Is 3.1.0, soon to be 3.1.1, not the latest stable release? If so, why is the next version going to be 3.02?
                                            A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
