WIP CoreXY with heated chamber
My Duet controlled machine
13
68
5.9k
    Phaedrux Moderator @felt342
    @felt342 said in WIP CoreXY with heated chamber:
    I don't think I need to change to rails?
    Nothing wrong with wheels. The only issues i've found are that the V slots and wheels must be cleaned occasionally, and the bearings of the mini V wheels can fail sometimes, especially if they are cheap chinese bearings and if they are over tensioned.
    undefined 1 Reply Last reply 1 Apr 2020, 18:23 Reply Quote 0
      felt342 @Phaedrux
      @Phaedrux
      Yes, I found out it always accumulate some dust/debris on wheels. Hopefully enclosed box can decrease the amount of dust inside. I do have wheels from openbuilds original. Do you have experience with the polycarbonate wheels from them?
      Industrial 3D printing service in the Netherlands - gagatstudio.com
        The polycarbonate wheels are harder and so might be more noisy or have more vibration. The Delrin wheels are still very durable and will settle in a bit over time. The only reason I've seen for using polycarbonate wheels would be in industrial applications where chemical and heat resistance would be required or when there would be very heavy loads. The heated enclosure in your case might qualify.
          felt342
          Aha thank you! Will se in a future how it will work with heated enclosure.
            Turbo @felt342
            @felt342 HOnestly if you can get the rollers perfect, don't mess with it. The only advantage I've found for linear rails is they're basically maintenance free once you align 'em properly. and they are more compact than the roller design.
            Cant stop tuning wont stop tuning.
            Dbot, Custom i3, Voron 0&2
              Turbo @mrehorstdmd
              @mrehorstdmd 415 Steps on the Z axis, although i need to tweak it since my cubes are about .2mm too short right now, but i also need to make sure its not my first layer or anything else. No lift on retract. I may adjust layer height, but for now .25Lh is my go to since i already have a printer for high detail stuff.
              undefined 1 Reply Last reply 1 Apr 2020, 21:21 Reply Quote 0
                mrehorstdmd @Turbo
                @Turbo It's generally accepted practice to set layer thickness to a whole number multiple of the full step movement of the Z axis. For example, if the full step Z movement is 15 um, you would not use 200 um for the layer thickness, you'd use something like 210 um instead. That ensures that the motor is always in the same position relative to a full step at each layer position and should maximize print quality, at least with regard to layer thicknesses being the same. With the odd ratio of your gearbox, the whole step travel is going to be a number with lots of digits to the right of the decimal which makes getting a repeatable whole step multiple tricky. 5+2/11 ratio = 5.181818... I'm not sure how many digits you'd need to use before you reach the resolution limit of the system.
                Let's say your whole step travel worked out to be 51.8181818... um. If you went with a 4 full step multiple the layer thickness would be 207.272727... um. I don't know if you'd enter that as 207.3, 207.27, 207.273, etc. in the slicer to ensure that the motor was always in the same position relative to a full step at each layer.
                  felt342
                  Update - quick wrapping in aluminum foil. Hopefully I don't need to open it any soon 😄
                    felt342
                    And finally I got a bed heater! I am working now on a way to constrain the cable from the bed and installing TCO for safety. Overall I am very happy with this bed its get to 140C in 15 minutes and its only 350W on 8mm mic6 plate.
                    C54AA61C-C7BE-4DD3-9A4B-4373BC513027.jpeg 077-671d0cf8-066a-46e8-9c76-5b216a9b77ed-resized.jpeg)
                      felt342
                      So I decided to CNC out some parts as I am being very happy with the printing big ABS parts already for real customers without warping and strong layer bonding. The passive heating is reaching 55 degrees and it was possible to print 22 hours object. But I always needed to adjust wheels a bit after the print is finished, as ABS printed parts are not good enough. For now, I have an X carriage made completely from aluminum and did a test with a fan blower reaching 70 degrees inside, cable holder, and bond tech extruder mount printed from Nylon + CF. It did survive without problems printing a 13-hour object. But the Y-axis mounts got a bit of flex after all as they are still from ABS, so I redesign them and ordered a CNC one, which should be done end of this week! Then testing and setting up an active heater.
                      Updated link for some new photos:
                      https://www.icloud.com/photos/#0xNaIFtCVxhc7LV4lLBvnyL5A
                      undefined 1 Reply Last reply 3 Jun 2020, 20:05 Reply Quote 0
                        whosrdaddy @felt342
                        @felt342 : nice printer you have there!
                        Question, where are you getting the CNC parts from?
                        undefined 1 Reply Last reply 4 Jun 2020, 06:43 Reply Quote 0
                          felt342 @whosrdaddy
                          @whosrdaddy Thank you!
                          This is from 3D hubs, first time used their service.
                            felt342
                            Hi all, things moving but very slow, this is progress so far by today. I got all-aluminum machined parts for the motion system, very happy with them, and moving very smoothly. I can tighten them very hard without worry what plastic will crack, or they will start wobble then the chamber is getting 45 degrees C. Besides this I also installed front panel and wheel to be able moving printer around as its getting quite heavy. Working on the door now and decided what it will be not hinged, but removable on the channel magnets, with transparent polycarbonate sheet.
                            Some images:
                              felt342
                              Update - part cooling fan added. Mount and fan shroud printed from PA6.6. I used those fans - https://nl.rs-online.com/web/p/axial-fans/1356898/
                              They are rated to work at 70C and has a small form factor of 35x35x10mm with good pressure.
                              undefined 1 Reply Last reply 24 Jun 2020, 20:25 Reply Quote 0
                              • CR3Dundefined
                                CR3D
                                I read your project very carefully! Really really cool! 🙂
                                I have published a fan duct for the BMG X2 ... maybe it will help you a little 🙂
                                https://www.thingiverse.com/thing:4462527
                                Regards Christian (CR-3D)
                                Christian from CR-3D
                                Homepage:
                                www.cr-3d.de
                                Facebook:
                                https://www.facebook.com/cr3d.official
                                Our Discord Server
                                https://discord.gg/SxRaPNuRdA
                                Thingiverse Profile:
                                https://www.thingiverse.com/cr-3d_official/about
                                  felt342
                                  Hi Cristian,
                                  Thanks for this, it looks really great, might consider this! I was looking for something already made for BMG, but couldn't find any neat solutions, so I design my own, and there is yours now. Thanks again 🙂
                                    mrehorstdmd @felt342
                                    @felt342 Does any air come out of those print cooling fan ducts? Axial fans don't usually work very well against pressure...
                                    https://vimeo.com/252609601
                                    undefined 1 Reply Last reply 24 Jun 2020, 20:29 Reply Quote 1
                                      Phaedrux Moderator @mrehorstdmd
                                      @mrehorstdmd @CR3D looks to be using small blower fans at least.
                                      I was trying to find a fan duct option for a friend who is building an ulticlone and they are all axial fans with super restricted ducts. How did this become a popular option?!
                                      https://www.thingiverse.com/search?q=ultimaker+fan+ducts&type=things&sort=relevant
                                      undefined 1 Reply Last reply 24 Jun 2020, 20:50 Reply Quote 0
                                        felt342
                                        @mrehorstdmd It has a lot of air coming out, I did get inspired by Raise 3D pro I have, and it has the same idea sort of, gives a lot of air - also this fan what I am using has a lot of pressure compared to Noctua or similar. I did a small video trying to show it with the lighter.
                                        https://share.icloud.com/photos/0UQ3lXNX68oKFoiqHt2Zj_HAQ
                                        undefined 1 Reply Last reply 24 Jun 2020, 20:46 Reply Quote 0
                                          @felt342 Well it's all about static pressure, so if you've got that, you're all good.
