    Bltouch setup need help
    Firmware installation
    3.9k
      Phaedrux Moderator @Elvis0z
      @Elvis0z said in Bltouch setup need help:
      Hey guys need help to set this up its a v1.0 bltouch.
      Is this a version with the trace to cut or does it come with the resistor? It's been a long time since I've seen anyone with a V1, so I'm wondering if it matters in this case. If it's a new Duet 1.04 it can't be hurt by 5v, but perhaps there is something in the BLtouch that will not trigger. If removing the ^ and checking your white wire is fruitless, maybe look into the trace/resistor
      • Elvis0zundefined
        Elvis0z
        No I replaced it with a v3.1 that I had
        • Elvis0zundefined
          Elvis0z
          If I send command M401 and M402 it triggers
            You mean it deploys and retracts?
            When you send G30 does the pin deploy?
            Elvis0zundefined 1 Reply Last reply Reply Quote 0
            • Elvis0zundefined
              Elvis0z
              I get this error when sending G30
              G30
              Error: G30: Insufficient axes homed for bed probing
              • Elvis0zundefined
                Elvis0z @Phaedrux
                @Phaedrux
                Yep deploys and retracts that is for the M401 M402 commands
                  Ok home X and Y first, move the print head to the center and then send G30. Does the pin deploy? Does the Z axis move? If you touch the pin does the Z axis stop?
                  • Elvis0zundefined
                    Elvis0z
                    Yep deployed and red light went out and got the error
                    • JoergS5undefined
                      JoergS5 @Elvis0z
                      @Elvis0z please remove
                      M307 H3 A-1 C-1 D-1
                      this not valid in RRF3 any more.
                      Edit: this is the source: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M307
                      • Elvis0zundefined
                        Elvis0z @JoergS5
                        @JoergS5
                        Yep removed
                          Just to make sure, the files you are editing are in the /sys folder, right?
                          • Elvis0zundefined
                            Elvis0z @Phaedrux
                            @Phaedrux
                            Yep
                              Can you upload the actual files to your post? config.g homeall.g homex.g homey.g homez.g deployprobe.g retractprobe.g
                              And maybe a photo of your wiring?
                              • Elvis0zundefined
                                Elvis0z
                                Not sure what you mean "Actual files" or how to do it not copy paste?
                                  In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
                                  • Elvis0zundefined
                                    Elvis0z
                                    config.g
                                    deployprobe.g
                                    homeall.g
                                    homex.g
                                    homey.g
                                    homez.g
                                    retractprobe.g
                                    • Elvis0zundefined
                                      Elvis0z
                                      Thank you for all the help. I have to go out for a while will be back
                                      Cheers
                                        Can you send M98 P"config.g" in the gcode console and report the results?
                                        • Elvis0zundefined
                                          Elvis0z @Phaedrux
                                          @Phaedrux yep will do soon as I'm back home
                                          • JoergS5undefined
                                            JoergS5
                                            I am not sure whether it's a problem that retractprobe.g doesn't have a CRLF at the last line.
