    Bltouch setup need help
    Firmware installation
    3.9k
    • Elvis0zundefined
      Elvis0z @Phaedrux
      @Phaedrux
      Yep deploys and retracts that is for the M401 M402 commands
        Ok home X and Y first, move the print head to the center and then send G30. Does the pin deploy? Does the Z axis move? If you touch the pin does the Z axis stop?
        • Elvis0zundefined
          Elvis0z
          @Elvis0z said in Bltouch setup need help:
          Error: G30: Insufficient axes homed for bed probing
          Yep deployed and red light went out and got the error
          • JoergS5undefined
            JoergS5 @Elvis0z
            @Elvis0z please remove
            M307 H3 A-1 C-1 D-1
            this not valid in RRF3 any more.
            Edit: this is the source: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M307
            Elvis0zundefined 1 Reply Last reply Reply Quote 0
            • Elvis0zundefined
              Elvis0z @JoergS5
              @JoergS5
              Yep removed
                Just to make sure, the files you are editing are in the /sys folder, right?
                • Elvis0zundefined
                  Elvis0z @Phaedrux
                  @Phaedrux
                  Yep
                    Can you upload the actual files to your post? config.g homeall.g homex.g homey.g homez.g deployprobe.g retractprobe.g
                    And maybe a photo of your wiring?
                    • Elvis0zundefined
                      Elvis0z
                      Not sure what you mean "Actual files" or how to do it not copy paste?
                        In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
                        • Elvis0zundefined
                          Elvis0z
                          config.g
                          deployprobe.g
                          homeall.g
                          homex.g
                          homey.g
                          homez.g
                          retractprobe.g
                          • Elvis0zundefined
                            Elvis0z
                            Thank you for all the help. I have to go out for a while will be back
                            Cheers
                              Can you send M98 P"config.g" in the gcode console and report the results?
                              • Elvis0zundefined
                                Elvis0z @Phaedrux
                                @Phaedrux yep will do soon as I'm back home
                                • JoergS5undefined
                                  JoergS5
                                  I am not sure whether it's a problem that retractprobe.g doesn't have a CRLF at the last line.
                                  • Elvis0zundefined
                                    Elvis0z
                                    M98 P"config.g"
                                    HTTP is enabled on port 80
                                    FTP is enabled on port 21
                                    TELNET is disabled
                                    Error: bad model parameters
                                    • Elvis0zundefined
                                      Elvis0z @JoergS5
                                      @JoergS5 CRLF not sure what that is
                                      A Former User? JoergS5undefined 2 Replies Last reply Reply Quote 0
                                        A Former User @Elvis0z
                                        @Elvis0z carriage return and line feed. In other words press enter.
                                        • JoergS5undefined
                                          JoergS5 @Elvis0z
                                          @Elvis0z please try
                                          G31 P25 X41.0 Y10.0 Z0.0
                                          instead of
                                          G31 P25 X+41 Y+10 Z0.0
                                          and run M98 P"config.g" again whether the bad model parameters is still there.
                                          • Elvis0zundefined
                                            Elvis0z
                                            TELNET is disabled
