    Bltouch setup need help
    Firmware installation
    4.0k
    • Elvis0zundefined
      Elvis0z
      I get this error when sending G30
      G30
      Error: G30: Insufficient axes homed for bed probing
      • Elvis0zundefined
        Elvis0z @Phaedrux
        @Phaedrux
        Yep deploys and retracts that is for the M401 M402 commands
          Ok home X and Y first, move the print head to the center and then send G30. Does the pin deploy? Does the Z axis move? If you touch the pin does the Z axis stop?
          • Elvis0zundefined
            Elvis0z
            @Elvis0z said in Bltouch setup need help:
            Yep deployed and red light went out and got the error
            • JoergS5undefined
              JoergS5 @Elvis0z
              @Elvis0z please remove
              M307 H3 A-1 C-1 D-1
              this not valid in RRF3 any more.
              Edit: this is the source: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M307
              Elvis0zundefined 1 Reply Last reply Reply Quote 0
              • Elvis0zundefined
                Elvis0z @JoergS5
                @JoergS5
                Yep removed
                  Just to make sure, the files you are editing are in the /sys folder, right?
                  • Elvis0zundefined
                    Elvis0z @Phaedrux
                    @Phaedrux
                    Yep
                      Can you upload the actual files to your post? config.g homeall.g homex.g homey.g homez.g deployprobe.g retractprobe.g
                      And maybe a photo of your wiring?
                      • Elvis0zundefined
                        Elvis0z
                        Not sure what you mean "Actual files" or how to do it not copy paste?
                          In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
                          • Elvis0zundefined
                            Elvis0z
                            config.g
                            deployprobe.g
                            homeall.g
                            homex.g
                            homey.g
                            homez.g
                            retractprobe.g
                            • Elvis0zundefined
                              Elvis0z
                              Thank you for all the help. I have to go out for a while will be back
                              Cheers
                                Can you send M98 P"config.g" in the gcode console and report the results?
                                • Elvis0zundefined
                                  Elvis0z @Phaedrux
                                  @Phaedrux yep will do soon as I'm back home
                                  • JoergS5undefined
                                    JoergS5
                                    I am not sure whether it's a problem that retractprobe.g doesn't have a CRLF at the last line.
                                    • Elvis0zundefined
                                      Elvis0z
                                      M98 P"config.g"
                                      HTTP is enabled on port 80
                                      FTP is enabled on port 21
                                      TELNET is disabled
                                      Error: bad model parameters
                                      • Elvis0zundefined
                                        Elvis0z @JoergS5
                                        @JoergS5 CRLF not sure what that is
                                        A Former User? JoergS5undefined 2 Replies Last reply Reply Quote 0
                                          A Former User @Elvis0z
                                          @Elvis0z carriage return and line feed. In other words press enter.
                                          • JoergS5undefined
                                            JoergS5 @Elvis0z
                                            @Elvis0z please try
                                            G31 P25 X41.0 Y10.0 Z0.0
                                            instead of
                                            G31 P25 X+41 Y+10 Z0.0
                                            and run M98 P"config.g" again whether the bad model parameters is still there.
