    Bltouch setup need help
    Firmware installation
    3.9k
    • Elvis0zundefined
      Elvis0z
      @Elvis0z said in Bltouch setup need help:
      Error: G30: Insufficient axes homed for bed probing
      Yep deployed and red light went out and got the error
      • JoergS5undefined
        JoergS5 @Elvis0z
        @Elvis0z please remove
        M307 H3 A-1 C-1 D-1
        this not valid in RRF3 any more.
        Edit: this is the source: https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M307
        Elvis0zundefined 1 Reply Last reply Reply Quote 0
        • Elvis0zundefined
          Elvis0z @JoergS5
          @JoergS5
          Yep removed
            Just to make sure, the files you are editing are in the /sys folder, right?
            • Elvis0zundefined
              Elvis0z @Phaedrux
              @Phaedrux
              Yep
                Can you upload the actual files to your post? config.g homeall.g homex.g homey.g homez.g deployprobe.g retractprobe.g
                And maybe a photo of your wiring?
                • Elvis0zundefined
                  Elvis0z
                  Not sure what you mean "Actual files" or how to do it not copy paste?
                    In the /sys folder select the files and then right click and download. Then drag the files onto the post text box in the forum to upload.
                    • Elvis0zundefined
                      Elvis0z
                      config.g
                      deployprobe.g
                      homeall.g
                      homex.g
                      homey.g
                      homez.g
                      retractprobe.g
                      • Elvis0zundefined
                        Elvis0z
                        Thank you for all the help. I have to go out for a while will be back
                        Cheers
                          Can you send M98 P"config.g" in the gcode console and report the results?
                          • Elvis0zundefined
                            Elvis0z @Phaedrux
                            @Phaedrux yep will do soon as I'm back home
                            • JoergS5undefined
                              JoergS5
                              I am not sure whether it's a problem that retractprobe.g doesn't have a CRLF at the last line.
                              • Elvis0zundefined
                                Elvis0z
                                M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is enabled on port 21
                                TELNET is disabled
                                Error: bad model parameters
                                • Elvis0zundefined
                                  Elvis0z @JoergS5
                                  @JoergS5 CRLF not sure what that is
                                  A Former User? JoergS5undefined 2 Replies Last reply Reply Quote 0
                                    A Former User @Elvis0z
                                    @Elvis0z carriage return and line feed. In other words press enter.
                                    • JoergS5undefined
                                      JoergS5 @Elvis0z
                                      @Elvis0z please try
                                      G31 P25 X41.0 Y10.0 Z0.0
                                      instead of
                                      G31 P25 X+41 Y+10 Z0.0
                                      and run M98 P"config.g" again whether the bad model parameters is still there.
                                      • Elvis0zundefined
                                        Elvis0z
                                        TELNET is disabled
                                        • JoergS5undefined
                                          JoergS5 @Elvis0z
                                          @Elvis0z ok, somewhere is a syntax error in the config.g, but I cannot see it.
                                          • Elvis0zundefined
                                            Elvis0z
                                            @JoergS5 said in Bltouch setup need help:
                                            Should I have P9 or P25
