    Cura Script to Automatically Probe Only Printed Area
    60
    7.6k
    • tcjundefined
      tcj @Baenwort
      @Baenwort said in Cura Script to Automatically Probe Only Printed Area:
      Does this bring it closer to working for Delta's? Or at least probing a square area of the circular bed?
      Yes, this makes it usable for delta's, because
      "For Cartesian printers, specify minimum and maximum X and Y values to probe and the probing interval. For Delta printers, specify the probing radius. If you define both, the probing area will be the intersection of the rectangular area and the circle. "
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M557_Set_Z_probe_point_or_define_probing_grid
      Baenwortundefined 2 Replies Last reply Reply Quote 1
      • zaptaundefined
        zapta @Red Sand Robot
        @Red-Sand-Robot, the change that you made in the program, changing the default meshable area to -100:100 is correct. Just remember to apply it again if you will download a newer version of this script.
        I run your gcode file and got this which looks ok to me
        MESHABLE area: -100.0:100.0,-100.0:100.0
        Opening gcode file: flex.gcode
        Read 33099 lines
        Parsing state = ParsingState.WAITING_FOR_LAYER1
        ; Automesh: begin layer 0
        Parsing state = ParsingState.IN_LAYER1
        ; Automesh: begin layer 1
        Parsing state = ParsingState.LAYER1_DONE
        First layer print areas: -13:13,-48:48
        printArea: -13:13,-48:48
        Will use 3 x 4 mesh points
        Marker: M557 X-23:23 Y-58:58 P3:4
        Inserted: M557 X-23:23 Y-58:58 P3:4
        Does it work for you now or are there still problems?
        Edit: for your question the -- flags should be specified immediately after the .py script name.
        • Baenwortundefined
          Baenwort @tcj
          @tcj Great! I'll give it a try on my next print.
          Do you think it will use the Delta probe interval for the new area or one specified by the gcode?
          • Baenwortundefined
            Baenwort @tcj
            @tcj So I'm still learning Cura after switching from using MatterControl since I got my Rostock v3. I tried adding the duet3d_automesh.py from zapta's github to the scripts area of the postprocessing folder of Cura's plugin folder.
            I do have Python 3 installed (3.8.3 to be exact) but this seems to make no difference to it showing up in Cura. 😕
            • zaptaundefined
              zapta @Baenwort
              @Baenwort, can you provide a little bit more info. E.g. what computer you are using (windows? mac? linux?) and how you set up the script in cura.
              Baenwortundefined 1 Reply Last reply Reply Quote 0
              • Baenwortundefined
                Baenwort @zapta
                @zapta
                Window's but I also tried it with a Ubuntu 20.04 Cura install. Both are Cura 4.6 and the OP and most post processing scripts direct placing the .py file in the plugin post processing directory.
                I can get you the exact tree when I get.back to my home tonight.
                • sandozundefined
                  sandoz
                  I have installed this into Cura 4.62 and using on my Railcore II. When it goes to run it always defines my X end point as being 1800.
                  M557 X103.850:1800.000 Y115.304:164.705 S10.000 ; Leveling mesh defined by LevelingMeshOptimizer
                  Railcore of course doesn't like this and then just skips the mesh:
                  Error: M557: bad grid definition: Too many grid points; suggest increase spacing to 44.2mm
                  Error: G29: No valid grid defined for bed probing
                  Is there something I am doing wrong?
                  • zaptaundefined
                    zapta @sandoz
                    @sandoz said in Cura Script to Automatically Probe Only Printed Area:
                    My guess is that there is a X1800 somewhere in the gcode that is picked by the script. Can you post the gcode file?
                    sandozundefined 1 Reply Last reply Reply Quote 1
                    • sandozundefined
                      sandoz @zapta
                      @zapta Alright.. using your comments as a place to start I found that having my Jerk control turned on in Cura led to some M566 x1800 commands that it was picking up. I turned off Curas control and just set it in the machine settings and now it slices properly.
                      zaptaundefined 1 Reply Last reply Reply Quote 1
                      • zaptaundefined
                        zapta @sandoz
                        @sandoz, the code is dump, looking for X<number> in the text regardless of the command, may even look in comments, I am not sure. If needed, it can be restricted it to a set of commands such as G0, G1, etc.
                        • MartinNYHCundefined
                          MartinNYHC
                          I wanted to set the probe spacing according to the size of the model. If it's <= 100 spacing should be 20, if it's >100 spacing should be 50.
                          Need to find the proper size/spacing values, but if anyone is interested, here's the diff:
                          128,135d127
                          <     sizeX = int(bounds['X']['max'] - bounds['X']['min'])
                          <     sizeY = int(bounds['Y']['max'] - bounds['Y']['min'])
                          <     if sizeX >= 100 or sizeY >= 100:
                          <         bounds['S'] = 50
                          <     else:
                          <         bounds['S'] = 20
                          137c129
                          <     gridNew = 'M557 X%d:%d Y%d:%d S%d' % (
                          >     gridNew = 'M557 X%d:%d Y%d:%d' % (
                          140d131
                          <         bounds['S'],
                          147c138
                          <             linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+ S\d+', gridNew, line, flags=re.MULTILINE))
                          >             linesNew.append(re.sub(r'^M557 X\d+:\d+ Y\d+:\d+', gridNew, line, flags=re.MULTILINE))
                          • nick9one1undefined
                            nick9one1
                            I'm trying to get this working in superslicer but get an error. Can anyone help?
                            in post-processing script
                            C:\Users\mumby\.windows-build-tools\python27\python.exe "C:\Program Files\SuperSlicer\meshgrid.py"
                            my start gcode (added M557)
                            M557 X20:292 Y15:300 P5                      	; define mesh grid
                            M104 S[first_layer_temperature]                   ; set extruder temp
                            M140 S[first_layer_bed_temperature]           ; set bed temp
                            G21			                   ; metric values
                            M190 S[first_layer_bed_temperature]           ; wait for bed temp
                            G28			                   ; home all
                            G32			                   ; Run mesh grid compenstion
                            G92 E0 F100			; reset extruder
                            G1 Z10 F3000 			; move z up little to prevent scratching of surface
                            M109 S[first_layer_temperature]                    ; wait for extruder temp
                            M98 P"0:/macros/Filament/Clean Nozzle"	; Clean nozzle macro
                            M98 P/macros/Filament/Purge		; Run nozzle purge macro
                            G1 E-3 F2000		                  ; Retract 3mm filament
                            G92 E0 		                                     ; reset extruder
                            this script itself (coped from an earlier post here)
                            #!/usr/bin/env python3
                            """Simplify3D post-processing script for RepRap firmware printers which dynamically defines the mesh grid dimensions (M557) based on the print dimensions.
                            {1}
                            Usage:
                            {1}
                                Within Simplify3D > Process Settings > Scripts > Post Processing > add the following command:
                                    python3 <script_location>/meshgrid.py "[output_filepath]"
                                Starting script must contain M557 Command (ie M557 X30:300 Y30:300 P20).
                            {1}
                            Args:
                            {1}
                                Path: Complete path to the gcode file created by Simplify 3d.
                            {1}
                            Requirements:
                            {1}
                                Tested using Python 3.8.1.
                            {1}
                            Credit:
                            {1}
                                Adapted from code originally posted by CCS86 on https://forum.duet3d.com/topic/15302/cura-script-to-automatically-probe-only-printed-area?_=1587348242875.
                            {1}
                            import sys
                            import re
                            import math
                            def main(filename):
                                try:
                                    _s3dFile = open(filename, encoding='utf-8')
                                except TypeError:
                                    try:
                                        _s3dFile = open(filename)
                                    except:
                                        print("Open file exception. Exiting meshgrid.py.")
                                        sys.exit()
                                except FileNotFoundError:
                                    print('File not found. Exiting meshgrid.py.')
                                    sys.exit()
                                lines = _s3dFile.readlines()
                                _s3dFile.close()
                                linesNew = calcBed(lines)
                                _s3dFileNew = open(filename, "r+")
                                _s3dFileNew.seek(0)
                                _s3dFileNew.truncate()
                                for element in linesNew:
                                    _s3dFileNew.write(element)
                                _s3dFileNew.close()
                                return
                            def calcBed(lines):
                                bounds = findBounds(lines)
                                bed = findBed(lines)
                                for axis in bounds:
                                    if bounds[axis]['max'] - bounds[axis]['min'] < bed[axis]:
                                        print(f'Success: {axis} mesh is smaller than bed')
                                    else:
                                        print('Error: Mesh is larger than bed. Exiting meshgrid.py.')
                                        sys.exit()
                                    for limit in bounds[axis]:
                                        if limit == 'min':
                                            if (bed[axis] / 2) - bounds[axis][limit] > 0:
                                                print (f'Success: {axis} {limit} coordinate is on the bed.')
                                            else:
                                                print (f'Error: {axis} {limit} coordinate is off the bed. Exiting meshgrid.py.')
                                                sys.exit()
                                        if limit == 'max':
                                            if (bed[axis]) - bounds[axis][limit] > 0:
                                            else:
                                                sys.exit()
                                return fillGrid(bounds, lines)
                            def findBed(lines):
                                bed = {
                                    'X': 0,
                                    'Y': 0,
                                for line in lines:
                                    if line.startswith(';   strokeXoverride,'):
                                        bed['X'] = int(re.search(r'\d.+\S', line).group())
                                    elif line.startswith(';   strokeYoverride,'):
                                        bed['Y'] = int(re.search(r'\d.+', line).group())
                                        break
                                return bed
                            def findBounds(lines):
                                bounds = {
                                    'X': {'min': 9999, 'max': 0},
                                    'Y': {'min': 9999, 'max': 0},
                                parsing = False
                                for line in lines:
                                    if line.startswith('; layer 1,'):
                                        parsing = True
                                        continue
                                    elif line.startswith('; layer 2,'):
                                        break
                                    if parsing:
                                        # Get coordinates on this line
                                        for match in re.findall(r'([YX])([\d.]+)\s', line):
                                            # Get axis letter
                                            axis = match[0]
                                            # Skip axes we don't care about
                                            if axis not in bounds:
                                                continue
                                            # Parse parameter value
                                            value = float(match[1])
                                            # Update bounds
                                            bounds[axis]['min'] = math.floor(min(bounds[axis]['min'], value))
                                            bounds[axis]['max'] = math.ceil(max(bounds[axis]['max'], value))
                                return bounds
                            def fillGrid(bounds, lines):
                                # Fill in the level command template
                                    bounds['X']['min'], bounds['X']['max'],
                                    bounds['Y']['min'], bounds['Y']['max'],
                                # Replace M557 command in GCODE
                                linesNew = []
                                for line in lines:
                                    if line.startswith('M557'):
                                    else:
                                        linesNew.append(line)
                                return linesNew
                            if __name__ == '__main__':
                                if sys.argv[1]:
                                    main(filename = sys.argv[1])
                                else:
                                    print('Error: Proper s3d post processing command is python3 <script_location>/meshgrid.py "[output_filepath]". Exiting meshgrid.py.')
                                    sys.exit()
                            PCRundefined 1 Reply Last reply Reply Quote 0
                            • Phaedruxundefined Phaedrux referenced this topic
                            • PCRundefined
                              PCR @nick9one1
                              @nick9one1 See this 😉
                              https://forum.duet3d.com/topic/25882/only-probe-bed-where-it-is-printed-solution-with-prusaslicer/3
                              nick9one1undefined 1 Reply Last reply Reply Quote 1
                              • gloomyandyundefined gloomyandy referenced this topic
                                nick9one1 @PCR
                                @pcr
                                Thanks! I actually got this working, and its been great since I posted. But will take a look at your solution 🙂
                                • engikeneerundefined engikeneer referenced this topic
                                • KP0005undefined KP0005 referenced this topic
