    D-PATCH
    My Duet controlled machine
    10
    46
    3.7k
    • taconiteundefined
      taconite
      Hey Guys,
      I uploaded some videos of the first prints here.
      Furthermore I added a video of a manual tool change
      https://www.youtube.com/user/Taconiteable/videos
      Best Regards
      Adrian
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • oliofundefined
        oliof
        That's really cool, I missed your original post! The first tool changing delta I am aware of is from 2013 (see https://www.youtube.com/watch?v=f60YuBrHRCA -- it's actually a pancake printer as shown in https://www.youtube.com/watch?v=t3O19n_JqXU).
        We've come a long way in the mean time! Can you give some details on your locking mechanism? It seems way more involved than a bunch of magnets.
        • taconiteundefined
          taconite
          @oliof Yeah you are right - I found these videos, too, when I started to look into tool changing Delta printers, but not many infos out there.
          About your question - yeah a little more brain juice went into the design of the locking mechanism.
          So it is basically a bayonet lock that is driven by a Bowden cable and reset by a bunch of springs
          The pieces of the bayonet that lock the tool are angled so a downward force is created by the rotation of the bayonet. It is locking onto 3 zylindrical pins that are placed 120° apart from each other so that the locking is uniformly
          Custom ANET A8
          o_lampeundefined 1 Reply Last reply Reply Quote 4
          • oliofundefined
            oliof
            Pretty cool! I hope you publish your design one day as this would be an interesting setup for three printers down my ideas to build (orthogonal tripteron, or sextupteron). But that's a couple years out optimistically speaking (-:
            • taconiteundefined
              taconite
              Thanks that you like it! Yeah as soon as this version will be finished I'm thinking about publish the files under CC-BY-NC so that the community can use it 🙂
              BTW: I really love your unconventional tripteron design!
              Custom ANET A8
              • oliofundefined
                oliof
                The design is not mine though. That credit goes to Evan Callicoat.
                • taconiteundefined
                  taconite
                  Started working on the Tool-Changer itself
                  Custom ANET A8
                  • taconiteundefined
                    taconite
                    Hey guys,
                    worked a little bit more on the printer.
                    I got the first automatic tool change (even if it needs a little more tuning), but it's a first step in the "proof of concept" direction (which I already did with the first prototyp).
                    https://youtu.be/OE60ZKuhTJ0
                    Custom ANET A8
                    fškundefined 1 Reply Last reply Reply Quote 1
                    • fškundefined
                      fšk @taconite
                      @taconite that's a cool design. Where did you get the tapered metal parts?
                      • taconiteundefined
                        taconite
                        @fšk thank you 😉
                        I designed the tool so, that it utalizes standard stock material. The tapered part was done by a friend of mine on a standard lathe.
                        Custom ANET A8
                        • taconiteundefined
                          taconite
                          Tool Change Scripts
                          Custom ANET A8
                          • taconiteundefined
                            taconite
                            Tool Changing of two tools can be seen here:
                            https://youtu.be/nLvNUum48fg
                            upcoming is the first multi-material print
                            Custom ANET A8
                            JoergS5undefined 1 Reply Last reply Reply Quote 1
                            • JoergS5undefined
                              JoergS5 @taconite
                              @taconite that's a nice tool changer!
                              • HebigTundefined
                                HebigT
                                @taconite Hey any thoughts about preventing heat-creep after a (hot) tool is placed back on the carousel?
                                • taconiteundefined
                                  taconite
                                  @JoergS5 Thank you
                                  @jpomo10 of course ;). There are multiple options:
                                  1. set the stand-by temperature so low, that a equilibrium is reached
                                    (+ no additional fans, - long heat up time)
                                  2. one fan for each tool in parking position
                                    (+ sufficient cooling, - lot of fans with lots of noise)
                                  3. one bigger fan with a fan-duct to direct the air to the heat sinks of the tools in parking position
                                  For now I have no fans at all. So after the first prints I had not a lot of heat creep and no problems with jams. But I guess I will move on with option 3
                                  BTW: I posted another video of the first dual color print on youtube
                                  Custom ANET A8
                                  HebigTundefined 1 Reply Last reply Reply Quote 4
                                  • Vetiundefined
                                    Veti
                                    this looks like a sci fi attack hovercraft
                                    • HebigTundefined
                                      HebigT @taconite
                                      @taconite Thanks for the reply!
                                      Is the tool-changer "carriage" set up as an additional axis? How does it increment along with the Z-axis?
                                      • taconiteundefined
                                        taconite
                                        @jpomo10
                                        Yep it is set up as U axis. I wrote a custom post-processing script for cura 😉
                                        Custom ANET A8
                                        • taconiteundefined
                                          taconite
                                          Hey guys,
                                          I keep posting small videos - some are not really special but I still want to share them with you: https://youtu.be/6-CR_1vN3cE
                                          In this small video I print with my go-to 100mm/s-profile
                                          And I just uploaded a video of the change of 4 tools
                                          https://youtu.be/aJt_HRal5rY
                                          Custom ANET A8
                                          HebigTundefined 1 Reply Last reply Reply Quote 2
                                          • HebigTundefined
                                            HebigT @taconite
                                            @taconite Thanks for the links!
                                            Also, check out the posts about a TC Delta on this page: https://twitter.com/deltamaker
                                            taconiteundefined 1 Reply Last reply Reply Quote 0
