    D-PATCH
    My Duet controlled machine
    10
    46
    3.8k
    • Danalundefined
      Danal
      Would you be willing to post the tool macros?
      • taconiteundefined
        taconite
        @gtj0 thank you :), I will keep updating this post with news
        @Danal Thank you very much for your kind words. It feels good to hear, that people like it 🙂
        What else would you like to know?
        I have not completed the tool macros for this machine, yet but I can upload the ones for the prototype
        Custom ANET A8
        Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
        All I do here is under this license: CC BY-NC-SA
        • taconiteundefined
          taconite
          Hey Guys,
          I uploaded some videos of the first prints here.
          Furthermore I added a video of a manual tool change
          https://www.youtube.com/user/Taconiteable/videos
          Best Regards
          Adrian
          Custom ANET A8
          • oliofundefined
            oliof
            That's really cool, I missed your original post! The first tool changing delta I am aware of is from 2013 (see https://www.youtube.com/watch?v=f60YuBrHRCA -- it's actually a pancake printer as shown in https://www.youtube.com/watch?v=t3O19n_JqXU).
            We've come a long way in the mean time! Can you give some details on your locking mechanism? It seems way more involved than a bunch of magnets.
            • taconiteundefined
              taconite
              @oliof Yeah you are right - I found these videos, too, when I started to look into tool changing Delta printers, but not many infos out there.
              About your question - yeah a little more brain juice went into the design of the locking mechanism.
              So it is basically a bayonet lock that is driven by a Bowden cable and reset by a bunch of springs
              The pieces of the bayonet that lock the tool are angled so a downward force is created by the rotation of the bayonet. It is locking onto 3 zylindrical pins that are placed 120° apart from each other so that the locking is uniformly
              Custom ANET A8
              o_lampeundefined 1 Reply Last reply Reply Quote 4
              • oliofundefined
                oliof
                Pretty cool! I hope you publish your design one day as this would be an interesting setup for three printers down my ideas to build (orthogonal tripteron, or sextupteron). But that's a couple years out optimistically speaking (-:
                • taconiteundefined
                  taconite
                  Thanks that you like it! Yeah as soon as this version will be finished I'm thinking about publish the files under CC-BY-NC so that the community can use it 🙂
                  BTW: I really love your unconventional tripteron design!
                  Custom ANET A8
                  • oliofundefined
                    oliof
                    The design is not mine though. That credit goes to Evan Callicoat.
                    • taconiteundefined
                      taconite
                      Started working on the Tool-Changer itself
                      Custom ANET A8
                      • taconiteundefined
                        taconite
                        Hey guys,
                        worked a little bit more on the printer.
                        I got the first automatic tool change (even if it needs a little more tuning), but it's a first step in the "proof of concept" direction (which I already did with the first prototyp).
                        https://youtu.be/OE60ZKuhTJ0
                        Custom ANET A8
                        fškundefined 1 Reply Last reply Reply Quote 1
                        • fÅ¡kundefined
                          fšk @taconite
                          @taconite that's a cool design. Where did you get the tapered metal parts?
                          • taconiteundefined
                            taconite
                            @fšk thank you 😉
                            I designed the tool so, that it utalizes standard stock material. The tapered part was done by a friend of mine on a standard lathe.
                            Custom ANET A8
                            • taconiteundefined
                              taconite
                              Tool Change Scripts
                              Custom ANET A8
                              • taconiteundefined
                                taconite
                                Tool Changing of two tools can be seen here:
                                https://youtu.be/nLvNUum48fg
                                upcoming is the first multi-material print
                                Custom ANET A8
                                JoergS5undefined 1 Reply Last reply Reply Quote 1
                                • JoergS5undefined
                                  JoergS5 @taconite
                                  @taconite that's a nice tool changer!
                                  • HebigTundefined
                                    HebigT
                                    @taconite Hey any thoughts about preventing heat-creep after a (hot) tool is placed back on the carousel?
                                    • taconiteundefined
                                      taconite
                                      @JoergS5 Thank you
                                      @jpomo10 of course ;). There are multiple options:
                                      1. set the stand-by temperature so low, that a equilibrium is reached
                                        (+ no additional fans, - long heat up time)
                                      2. one fan for each tool in parking position
                                        (+ sufficient cooling, - lot of fans with lots of noise)
                                      3. one bigger fan with a fan-duct to direct the air to the heat sinks of the tools in parking position
                                      For now I have no fans at all. So after the first prints I had not a lot of heat creep and no problems with jams. But I guess I will move on with option 3
                                      BTW: I posted another video of the first dual color print on youtube
                                      Custom ANET A8
                                      HebigTundefined 1 Reply Last reply Reply Quote 4
                                      • Vetiundefined
                                        Veti
                                        this looks like a sci fi attack hovercraft
                                        • HebigTundefined
                                          HebigT @taconite
                                          @taconite Thanks for the reply!
                                          Is the tool-changer "carriage" set up as an additional axis? How does it increment along with the Z-axis?
                                          • taconiteundefined
                                            taconite
                                            @jpomo10
                                            Yep it is set up as U axis. I wrote a custom post-processing script for cura 😉
                                            Custom ANET A8
