    Pressure Advance: Discussion for Future Development
    Firmware wishlist
    15
    46
    4.2k
    • CCS86undefined
      CCS86
      I wanted to open up a discussion about ways to improve pressure advance functionality in the future, especially for bowden based printers.
      I'll describe my experience and setup first. I am running a custom extruder drive that uses a 5:1 geared stepper, driving a set of Bondtech dual drive gears. It has been relocated high and central, embedded in a bearing mount to allow rotation. This has let me minimize the bowden length to 450mm of Capricorn tubing. From there it goes through an E3D V6.
      With everything I can think of done mechanically to improve extrusion response, I worked on tuning pressure advance. Adapting code from the Marlin linear advance calibration print (https://marlinfw.org/tools/lin_advance/k-factor.html), I honed in on S values for my printer. Even using "fast" and "slow" values that aren't very extreme (25 mm/s & 65 mm/s), I need S values around 1.4 to achieve a constant extrusion width through these speed changes.
      While the test print looks great, getting real world prints to work with M572 S1.4 (or even S0.5 for that matter) has been an unsuccessful challenge so far. There seems to be some combination of factors in real prints that upsets the pressure advance algorithm. You have a lot of influence in tuning motion, with pressure advance enabled, using E axis jerk and acceleration. I found the best balance to be a fairly high max E_accel (8000 mm/s/s), and lower E_jerk (4 mm/s), for a max E_speed of 40 mm/s.
      For certain prints, like cylindrical shells, where everything is concentric walls and you have long periods between acceleration and deceleration, this can work very well. But, once you get into normal infill, with lots of reversals and direction changes, it seems to lose control of extrusion rate and tend towards over-extrusion.
      From watching the extruder action when it is not working well, I noticed some things. Mainly, that corrections can come in such rapid succession that the hope of having their affect time with the nozzle seems unlikely.
      I don't know the details of the current implementation, but this is my understanding: Any given extrusion rate is associated with a certain nozzle pressure, which requires a certain amount of filament/extruder preload to achieve (determined with the S value). This amount is added at the beginning of any acceleration (as fast as the extruder axis settings allow), and the print head motion is bounded in acceleration/jerk to prevent it from outpacing the extruder. Everything is reversed during deceleration. This approach of forcing synchronization probably works pretty well with very small S values (direct drive printers). But I think it falls apart at larger values.
      One question I have: Is pressure advance taking into account (sum total) XY jerk and (sum total) XY acceleration, when deciding whether to act? I swear I have seen it taking action during print head direction changes that appear to keep the nozzle at a constant velocity, either through jerk, or by X deceleration being made up for by Y acceleration. Maybe I am mistaken.
      My best ideas at the moment:
      • try to look ahead in the motion planning and determine the amount of time where extrusion rate will not match print head speed; choosing to stay inactive unless that time exceeds a user defined value. My gut says that if the mismatch time is under say 50 ms, there wouldn't be an observable quality difference with or without PA, and staying inactive could save a lot of E axis "chatter".
      • acknowledge that there is a time delay between a PA compensation and a change in nozzle pressure / extrusion rate. Ideally, through another user defined parameter, you attempt to correct for this delay. But, it's possible that this is very difficult to implement.
      • allow de-synchronization of the print head and the extruder. The more time the print head spends accelerating or decelerating, the more opportunity we have for extrusion rate mismatch. With no pressure advance, I tend to get the best results when XY accel and jerk are high enough to allow for very crisp motion. Allowing the print head to move unrestricted and have the extruder just "do its best" for E max values defined, may offer some improvement. Maybe just an M572 flag to enable this behavior.
      • allow PA to be disabled during infill. I realize that this would require parsing data from the slicer, and that labeling conventions vary. But, the upside for PA in infill is pretty small. Most of the benefit is realized in perimeters IMO.
      I definitely don't think that I have this all figured out. So, I'd love to hear from other people and their pressure advance experiences, where I might be wrong, and what other ideas are out there!
      • Slzerundefined
        Slzer
        Following this as I am struggling with a similar issue right now. I need around a value of 2 based of the same script you did. But in real prints the extruder goes wild especially on solid infills with all the changes of direction.
        • CCS86undefined
          CCS86
          Here is a good example of why my first idea might work. It's a very common situation: line infill.
          These infill lines sweep back and forth, connected by a small travel movement. With XY moving optimally, the amount of time spent below commanded infill speed is tiny. If you watch the extruder, even with the small travel move instead of a print move connection, the dwell is hard to even see. With no pressure advance, the amount of over-extrusion in the direction change areas is negligible. Yet, pressure advance will fully advance and bleed for every move. When these infill lines are in a tight area, with only a few mm of travel, they happen in rapid succession and the whole thing falls apart.
          Seeing that the dip in required extrusion rate will be extremely short and filtering out a pressure advance correction could solve this issue all together.
          • CCS86undefined
            CCS86
            Here is a gcodeanalyzer view of a single infill line. Obviously % time spent accel/decel depends on the length of the line. But, you can see the distance is pretty tiny:
            • zaptaundefined
              zapta
              (not trying to be Smart Aleck)
              Have you considered switching to a direct extruder? I went through a similar struggle with a bowden configuration and pretty much all the problems went away when Is switch to a direct extruder.
              As for the topic here, are there mechanical/physical simulations software that can simulate the behavior of the bowden + hotend? This could save a lot of trial and error.
              CCS86undefined 1 Reply Last reply Reply Quote 1
              • botundefined
                bot
                What slicer are you using? Cura? Or is that just for visualiation? Those infills remind me of the glorious infill segments from IceSL. 🙂
                *not actually a robot
                CCS86undefined 1 Reply Last reply Reply Quote 0
                • CCS86undefined
                  CCS86 @zapta
                  @zapta said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                  I don't know what problems you had with your bowden setup, but I don't have any real problems. Even without pressure advance, I have generally good extrusion rate control. Pressure advance should be an "icing on the cake" feature. But it ends up worsening print quality for me.
                  • CCS86undefined
                    CCS86 @bot
                    @bot said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                    I tend to use Cura (first screenshot)
                    The second screenshot is: http://gcodeanalyser.com/ for visualizing actual print head speed using your motion control settings.
                      Phaedrux Moderator @CCS86
                      @CCS86 said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                      Post your config and slicer settings?
                      • CCS86undefined
                        CCS86 @Phaedrux
                        @Phaedrux said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                        Which slicer settings are you interested in? There are a ton. Basic stuff: line width=0.4mm, layer height=0.15mm, outer wall=30mm/s, infill=60mm/s. I have tried with and without coasting.
                        ; Configuration file for Duet Maestro (firmware version 3)
                        G90                                                    ; absolute coordinates
                        M83                                                    ; relative extruder
                        M550 P"Maestro86"                                      ; set printer name
                        M552 P0.0.0.0 S1                                       ; enable network and acquire dynamic address via DHCP
                        M586 P0 S1                                             ; enable HTTP
                        M586 P1 S0                                             ; disable FTP
                        M586 P2 S0                                             ; disable Telnet
                        M569 P0 S0                                             ; physical drive 0 goes forwards / bw
                        M569 P1 S1                                             ; physical drive 1 goes backwards / fw
                        M569 P2 S0                                             ; physical drive 2 goes backwards
                        M569 P3 S0                                             ; physical drive 3 goes backwards
                        M569 P0 D2 ;V150									   ; Stealthchop2 till about 31.3 mm/sec / spreadcycle now D2
                        M569 P1 D2 ;V150 									   ; Stealthchop2 till about 31.3 mm/sec / spreadcycle now D2
                        M569 P2 V40 										   ; Stealthchop2 till about 46.9 mm/sec
                        M569 P3 D2 											   ; Extruder in Spreadcyle
                        M584 X1 Y0 Z2 E3                                       ; set drive mapping
                        M92 X159.93 Y159.75 Z400.00 E510                       ; set steps per mm
                        M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
                        M201 X4000.00 Y4000.00 Z400.00 E10000.00                ; set max accelerations (mm/s^2)
                        M203 X10200.00 Y10200.00 Z1800.00 E2400.00             ; set maximum speeds (mm/min)
                        M204 P2200 T3500                                       ; set accelerations (mm/s^2)
                        M205 X8 Y8 Z4 E4.5                                       ; set maximum instantaneous speed changes (mm/s)
                        M593 F00                                               ; dynamic accel cancel 0 hz
                        M572 D0 S0.20	    									   	; Pressure Advance
                        M906 X1200 Y1200 Z1200 E1200 I40                       ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30                                                ; Set idle timeout
                        M208 X0 Y0 Z0 S1                                       ; set axis minima
                        M208 X205 Y195 Z220 S0                                 ; set axis maxima
                        M574 X1 S1 P"!xstop"                                   ; configure active-high endstop for low end on X via pin !xstop
                        M574 Y1 S1 P"!ystop"                                   ; configure active-high endstop for low end on Y via pin !ystop
                        M574 Z1 S2 ; Set endstops controlled by probe
                        ;M558 P9 C"^zprobe.in" H5 F300 T6000                   ; set Z probe type to bltouch and the dive height + speeds
                        M558 P5 C"^zprobe.in" H5 F500 T6000
                        M950 S0 C"zprobe.mod"                                  ; create servo pin 0 for BLTouch
                        G31 P25 X12 Y-18 Z2.37                                 ; set Z probe trigger value, offset and trigger height
                        M557 X12:200 Y0:169.2 S18.8                            ; define mesh grid
                        M376 H2                                                ; mesh taper
                        M308 S0 P"spi.cs1" Y"rtd-max31865"                     ; configure sensor 0 as a PT100 sensor in the first position on the Duet 2 daughter board connector
                        M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                        M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
                        M140 H0                                                ; map heated bed to heater 0
                        M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
                        M308 S1 P"e0temp" Y"pt1000" ;T100000 B4725 C7.06e-8    ; configure sensor 1 as PT1000 on pin e0temp
                        M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                        M143 H1 S260                                          ; set temperature limit for heater 1 to 250C
                        M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
                        M308 S2 Y"drivers" A"DRIVERS"                          ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                        M308 S3 Y"mcu-temp" A"MCU"                             ; configure sensor 3 as thermistor on pin e1temp for left stepper
                        ; Heater model parameters
                        M307 H0 A126.9 C671.6 D1.2 S1.00 V23.0 B0
                        M307 H1 A374.7 C132.0 D4.4 S1.00 V24.3 B0
                        M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                        M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                        M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                        M106 P1 S1 H1 T40 B1.5                                 ; set fan 1 value. Thermostatic control is turned on
                        M950 F2 C"fan2" ;Q800                                  ; create fan 2 on pin fan2 and set its frequency
                        M106 P2 H1:2:3 L1 X1 T53                               ; set fan 2 value
                        M563 P0 S"E0" D0 H1 F0                                 ; define tool 0
                        G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                        G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                        T0                                                     ; select first tool
                        ;M501                                                  ; Load config-override.g
                        • botundefined
                          bot
                          Can you post a gcode file you’ve printed and had bad experiences with in regards to PA?
                          • CCS86undefined
                            CCS86
                            I can't remember with confidence which files I tried and failed to get a good result. The next time I have that issue, I will set the code aside.
                            I decided to try to make a test print that I hoped would replicate my PA issues for demonstration. Just a short, narrow print, which necks down from an 8mm width, to 2mm width. This object is copied 4 times, printed one at a time, with M572 D0 S0, S0.5, S1.0, S1.5.
                            I photographed the results with my macro lens, but it's really hard to make judgement from the photos. In hand, they all look similar. If anything the S0 print looks best. With PA enabled, you certainly lose a bunch of time.
                            • QuintBrandundefined
                              QuintBrand
                              I relate to your ideas and findings. I have a nimble though, so bit different situation. A nimble has trouble to keep up wit PA due to its high gear ratio (as noted on duet website). So although direct drive it has some "bowden like" behavior in PA. My findings:
                              • using Marlin routine I need S0.54
                              • using the Python script approach I need S0.6
                              • in real printing I find better results with S0.4
                              So lower than in the tests with I think relate to your observation on for the under extrusion on very short lines.
                              I have no need anymore for coasting in cura, and overall I have better quality. I hope and think you do too right? It's about improving it even more.
                              So I think your idea on the minimum amount of time could work well. I'm wondering if it should be time or travel length though? That would take out the need to tune each time when you print with different speeds for different prints, or even when using different speeds while printing different features.
                              I think having both options would be best to tinker with.
                              Also I would think it would be even nicer if one can give two parameters:
                              • length/time No PA
                              • length/time Full PA.
                              And an interpolation in between to give a sliding PA value?
                              No idea how hard to implement, but I bet it would be a selling point when this works well (I'd be happy to test 🙂 when indeed working well.
                              While think about it: anybody know how to modify a gcode file to search for short line length and putting an M572 in front (and after) to change the settings with some existing scripts or something to prototype test?
                              Cheers Q
                                QuintBrand
                                Seems little interest CCS... 🤔
                                • Slzerundefined
                                  Slzer
                                  I ended up just using 0.5 for my PA on my long bowden setup despite all tests indicating more or less no change until 1.5-2 range.
                                  I'm actually getting quite nice results but I was simply limited by what didn't cause the extruder to sound like a machine gun
                                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                                  • Exerqtorundefined
                                    Exerqtor @Slzer
                                    @Slzer
                                    That's exactly what i ended up doing to (well i setteled on 0.4), even though i would get the most consistent pressure somewhere close to 2, but it sounded like my BMG was one nudge away from exploding at that point 😂
                                    Designed new extruder mounts so i could move the extruders over the build area (corexy machine) and shorten the bowdens down to 300mm ish, so 0.4 isn't that much off.
                                    RyanPundefined 1 Reply Last reply Reply Quote 0
                                    • CCS86undefined
                                      CCS86 @QuintBrand
                                      @QuintBrand said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                                      Were you waiting on my feedback? It sounded like you were generally agreeing with me and not asking questions.
                                      I don't think "length" is a better parameter to use for filtering over "time". We are dealing with time based phenomenon, ie lag between extruder drive motion > nozzle pressure > nozzle flow rate. How fast the print head is traveling doesn't impact these things.
                                      QuintBrandundefined 1 Reply Last reply Reply Quote 0
                                      • Edgars Batnaundefined
                                        Edgars Batna
                                        I have resorted to printing without PA now. In my case I observed that the extruder reverse motion gets skipped on consecutive small segments, thus all my over-extrusion issues ensued.
                                        I also dug in the Firmware and at some point it just stopped being fun as there are multiple approximations related to step generation which smell bad. Having no handy HW simulation tools it just took too long to debug with all the variables.
                                        I saw Klipper implements "smoothing" for PA, so I started moving to it to test it out. While there are pros and cons between Duet and Klipper (I still like the Duet), but at least in Klipper the CPU basically only runs the step pulses, so no need to deal with interrupts being late or whatnot.
                                        Not finished yet, tho.
                                          QuintBrand @CCS86
                                          @CCS86
                                          Hey, no I was not trying to push you in any way, but actually trying to support this tread from sliding away as I think it is an excellent idea to get the "gun" effect out of the printing with PA 👍.
                                          I think bit time and length would be nice. I agree that if we'd "need to choose" time is probably better, but when printing at (quite) different speeds for infill, walls etc I think length is also nice.
                                          I also went from 0.4-0.5 found from testing to 0.2 to ease the printing somewhat and get good results anyways too.
                                          • RyanPundefined
                                            RyanP @Exerqtor
                                            @Exerqtor said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                                            @Slzer
                                            Answers like this make me not feel alone in the world.
                                            CR10S, August 2018
                                            Anycubic Photon S December 2019
                                            Ender 5 Feb 2020
                                            Ender 5 Plus May 2020
                                            Anycubic Photon Mono X Nov 2020
                                            https://3dimensiongames.com/
                                            Slzerundefined 1 Reply Last reply Reply Quote 0
