    Pressure Advance: Discussion for Future Development
    Firmware wishlist
    15
    46
    4.2k
    • CCS86undefined
      CCS86 @zapta
      @zapta said in Pressure Advance: Discussion for Improvement in Bowden Printers:
      (not trying to be Smart Aleck)
      Have you considered switching to a direct extruder? I went through a similar struggle with a bowden configuration and pretty much all the problems went away when Is switch to a direct extruder.
      As for the topic here, are there mechanical/physical simulations software that can simulate the behavior of the bowden + hotend? This could save a lot of trial and error.
      I don't know what problems you had with your bowden setup, but I don't have any real problems. Even without pressure advance, I have generally good extrusion rate control. Pressure advance should be an "icing on the cake" feature. But it ends up worsening print quality for me.
      • CCS86undefined
        CCS86 @bot
        @bot said in Pressure Advance: Discussion for Improvement in Bowden Printers:
        What slicer are you using? Cura? Or is that just for visualiation? Those infills remind me of the glorious infill segments from IceSL. 🙂
        I tend to use Cura (first screenshot)
        The second screenshot is: http://gcodeanalyser.com/ for visualizing actual print head speed using your motion control settings.
          Phaedrux Moderator @CCS86
          @CCS86 said in Pressure Advance: Discussion for Improvement in Bowden Printers:
          Post your config and slicer settings?
          CCS86undefined 1 Reply Last reply Reply Quote 1
          • CCS86undefined
            CCS86 @Phaedrux
            @Phaedrux said in Pressure Advance: Discussion for Improvement in Bowden Printers:
            Which slicer settings are you interested in? There are a ton. Basic stuff: line width=0.4mm, layer height=0.15mm, outer wall=30mm/s, infill=60mm/s. I have tried with and without coasting.
            ; Configuration file for Duet Maestro (firmware version 3)
            G90                                                    ; absolute coordinates
            M83                                                    ; relative extruder
            M550 P"Maestro86"                                      ; set printer name
            M552 P0.0.0.0 S1                                       ; enable network and acquire dynamic address via DHCP
            M586 P0 S1                                             ; enable HTTP
            M586 P1 S0                                             ; disable FTP
            M586 P2 S0                                             ; disable Telnet
            M569 P0 S0                                             ; physical drive 0 goes forwards / bw
            M569 P1 S1                                             ; physical drive 1 goes backwards / fw
            M569 P2 S0                                             ; physical drive 2 goes backwards
            M569 P3 S0                                             ; physical drive 3 goes backwards
            M569 P0 D2 ;V150									   ; Stealthchop2 till about 31.3 mm/sec / spreadcycle now D2
            M569 P1 D2 ;V150 									   ; Stealthchop2 till about 31.3 mm/sec / spreadcycle now D2
            M569 P2 V40 										   ; Stealthchop2 till about 46.9 mm/sec
            M569 P3 D2 											   ; Extruder in Spreadcyle
            M584 X1 Y0 Z2 E3                                       ; set drive mapping
            M92 X159.93 Y159.75 Z400.00 E510                       ; set steps per mm
            M350 X16 Y16 Z16 E16 I1                                ; configure microstepping with interpolation
            M201 X4000.00 Y4000.00 Z400.00 E10000.00                ; set max accelerations (mm/s^2)
            M203 X10200.00 Y10200.00 Z1800.00 E2400.00             ; set maximum speeds (mm/min)
            M204 P2200 T3500                                       ; set accelerations (mm/s^2)
            M205 X8 Y8 Z4 E4.5                                       ; set maximum instantaneous speed changes (mm/s)
            M593 F00                                               ; dynamic accel cancel 0 hz
            M572 D0 S0.20	    									   	; Pressure Advance
            M906 X1200 Y1200 Z1200 E1200 I40                       ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                                ; Set idle timeout
            M208 X0 Y0 Z0 S1                                       ; set axis minima
            M208 X205 Y195 Z220 S0                                 ; set axis maxima
            M574 X1 S1 P"!xstop"                                   ; configure active-high endstop for low end on X via pin !xstop
            M574 Y1 S1 P"!ystop"                                   ; configure active-high endstop for low end on Y via pin !ystop
            M574 Z1 S2 ; Set endstops controlled by probe
            ;M558 P9 C"^zprobe.in" H5 F300 T6000                   ; set Z probe type to bltouch and the dive height + speeds
            M558 P5 C"^zprobe.in" H5 F500 T6000
            M950 S0 C"zprobe.mod"                                  ; create servo pin 0 for BLTouch
            G31 P25 X12 Y-18 Z2.37                                 ; set Z probe trigger value, offset and trigger height
            M557 X12:200 Y0:169.2 S18.8                            ; define mesh grid
            M376 H2                                                ; mesh taper
            M308 S0 P"spi.cs1" Y"rtd-max31865"                     ; configure sensor 0 as a PT100 sensor in the first position on the Duet 2 daughter board connector
            M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                                ; map heated bed to heater 0
            M143 H0 S120                                           ; set temperature limit for heater 0 to 120C
            M308 S1 P"e0temp" Y"pt1000" ;T100000 B4725 C7.06e-8    ; configure sensor 1 as PT1000 on pin e0temp
            M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
            M143 H1 S260                                          ; set temperature limit for heater 1 to 250C
            M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
            M308 S2 Y"drivers" A"DRIVERS"                          ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
            M308 S3 Y"mcu-temp" A"MCU"                             ; configure sensor 3 as thermistor on pin e1temp for left stepper
            ; Heater model parameters
            M307 H0 A126.9 C671.6 D1.2 S1.00 V23.0 B0
            M307 H1 A374.7 C132.0 D4.4 S1.00 V24.3 B0
            M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T40 B1.5                                 ; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" ;Q800                                  ; create fan 2 on pin fan2 and set its frequency
            M106 P2 H1:2:3 L1 X1 T53                               ; set fan 2 value
            M563 P0 S"E0" D0 H1 F0                                 ; define tool 0
            G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
            G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
            T0                                                     ; select first tool
            ;M501                                                  ; Load config-override.g
            • botundefined
              bot
              Can you post a gcode file you’ve printed and had bad experiences with in regards to PA?
              *not actually a robot
              • CCS86undefined
                CCS86
                I can't remember with confidence which files I tried and failed to get a good result. The next time I have that issue, I will set the code aside.
                I decided to try to make a test print that I hoped would replicate my PA issues for demonstration. Just a short, narrow print, which necks down from an 8mm width, to 2mm width. This object is copied 4 times, printed one at a time, with M572 D0 S0, S0.5, S1.0, S1.5.
                I photographed the results with my macro lens, but it's really hard to make judgement from the photos. In hand, they all look similar. If anything the S0 print looks best. With PA enabled, you certainly lose a bunch of time.
                • QuintBrandundefined
                  QuintBrand
                  I relate to your ideas and findings. I have a nimble though, so bit different situation. A nimble has trouble to keep up wit PA due to its high gear ratio (as noted on duet website). So although direct drive it has some "bowden like" behavior in PA. My findings:
                  • using Marlin routine I need S0.54
                  • using the Python script approach I need S0.6
                  • in real printing I find better results with S0.4
                  So lower than in the tests with I think relate to your observation on for the under extrusion on very short lines.
                  I have no need anymore for coasting in cura, and overall I have better quality. I hope and think you do too right? It's about improving it even more.
                  So I think your idea on the minimum amount of time could work well. I'm wondering if it should be time or travel length though? That would take out the need to tune each time when you print with different speeds for different prints, or even when using different speeds while printing different features.
                  I think having both options would be best to tinker with.
                  Also I would think it would be even nicer if one can give two parameters:
                  • length/time No PA
                  • length/time Full PA.
                  And an interpolation in between to give a sliding PA value?
                  No idea how hard to implement, but I bet it would be a selling point when this works well (I'd be happy to test 🙂 when indeed working well.
                  While think about it: anybody know how to modify a gcode file to search for short line length and putting an M572 in front (and after) to change the settings with some existing scripts or something to prototype test?
                  Cheers Q
                    QuintBrand
                    Seems little interest CCS... 🤔
                    CCS86undefined 1 Reply Last reply Reply Quote 0
                    • Slzerundefined
                      Slzer
                      I ended up just using 0.5 for my PA on my long bowden setup despite all tests indicating more or less no change until 1.5-2 range.
                      I'm actually getting quite nice results but I was simply limited by what didn't cause the extruder to sound like a machine gun
                      Exerqtorundefined 1 Reply Last reply Reply Quote 0
                      • Exerqtorundefined
                        Exerqtor @Slzer
                        @Slzer
                        That's exactly what i ended up doing to (well i setteled on 0.4), even though i would get the most consistent pressure somewhere close to 2, but it sounded like my BMG was one nudge away from exploding at that point 😂
                        Designed new extruder mounts so i could move the extruders over the build area (corexy machine) and shorten the bowdens down to 300mm ish, so 0.4 isn't that much off.
                        RyanPundefined 1 Reply Last reply Reply Quote 0
                        • CCS86undefined
                          CCS86 @QuintBrand
                          @QuintBrand said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                          Were you waiting on my feedback? It sounded like you were generally agreeing with me and not asking questions.
                          I don't think "length" is a better parameter to use for filtering over "time". We are dealing with time based phenomenon, ie lag between extruder drive motion > nozzle pressure > nozzle flow rate. How fast the print head is traveling doesn't impact these things.
                          QuintBrandundefined 1 Reply Last reply Reply Quote 0
                          • Edgars Batnaundefined
                            Edgars Batna
                            I have resorted to printing without PA now. In my case I observed that the extruder reverse motion gets skipped on consecutive small segments, thus all my over-extrusion issues ensued.
                            I also dug in the Firmware and at some point it just stopped being fun as there are multiple approximations related to step generation which smell bad. Having no handy HW simulation tools it just took too long to debug with all the variables.
                            I saw Klipper implements "smoothing" for PA, so I started moving to it to test it out. While there are pros and cons between Duet and Klipper (I still like the Duet), but at least in Klipper the CPU basically only runs the step pulses, so no need to deal with interrupts being late or whatnot.
                            Not finished yet, tho.
                              QuintBrand @CCS86
                              @CCS86
                              Hey, no I was not trying to push you in any way, but actually trying to support this tread from sliding away as I think it is an excellent idea to get the "gun" effect out of the printing with PA 👍.
                              I think bit time and length would be nice. I agree that if we'd "need to choose" time is probably better, but when printing at (quite) different speeds for infill, walls etc I think length is also nice.
                              I also went from 0.4-0.5 found from testing to 0.2 to ease the printing somewhat and get good results anyways too.
                              • RyanPundefined
                                RyanP @Exerqtor
                                @Exerqtor said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                                @Slzer
                                Answers like this make me not feel alone in the world.
                                CR10S, August 2018
                                Anycubic Photon S December 2019
                                Ender 5 Feb 2020
                                Ender 5 Plus May 2020
                                Anycubic Photon Mono X Nov 2020
                                https://3dimensiongames.com/
                                Slzerundefined 1 Reply Last reply Reply Quote 0
                                • Slzerundefined
                                  Slzer @RyanP
                                  @RyanP said in Pressure Advance: Discussion for Improvement in Bowden Printers:
                                  @Slzer
                                  Aye me too... Most calibration things I can see the difference and select a good balance (although often having to run multiple parameter ranges to get a matrix of options - stringing control being a good example here, move speed, retraction length, retraction rate wipe etc.) but this one feels like black magic hah
                                  • Exerqtorundefined
                                    Exerqtor
                                    Just saw this tutorial pop up, note that it is for klipper-fw, but it should be translateable for RRF to i think. Gonna try it tomorrow and see what numbee i end up with this time 😅
                                    https://www.lpomykal.cz/anycubic-kossel-klipper-pressure-advance/
                                    • CCS86undefined
                                      CCS86
                                      @dc42, any thoughts on this?
                                      • CCS86undefined
                                        CCS86
                                        @dc42 I was really hoping you would weigh in here!
                                        • CCS86undefined
                                          CCS86
                                            I'm sorry, I don't have time to look at improving PA until I've implemented input shaping. But I've bookmarked this thread so that I can return to it. Pressure advance smoothing is something I was already thinking about.
                                            CCS86undefined 1 Reply Last reply Reply Quote 4
