hbot homes correctly but prints mirrored ,
8.1k
    Follow this for testing corexy motor movement.
    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCoreXYPrinter#Section_Testing_motor_movement
    This is key for Corexy.
    Sounds like you got the endstops and homing directions working correctly. This last test will tell you how to get the motors going correctly. It's a bit different because of corexy using two motors together for motion.
    undefined 1 Reply Last reply 25 Aug 2020, 17:57 Reply Quote 0
      peter247 @Phaedrux
      @Phaedrux
      So I'm lost about corexy , can he just change the y motor direction ?
      or is it me who is wrong ?
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      undefined 1 Reply Last reply 25 Aug 2020, 17:59 Reply Quote 0
        Phaedrux Moderator @peter247
        @peter247 said in hbot homes correctly but prints mirrored ,:
        The link answers all.
          peter247 @tracar
          @tracar
          SORRY !!!! , look like I was wrong I did know about corexy , both motors ?
          I'm 100% sure about the homing file needing changing , and know that the motor direction need changing , but I'm lost how to change it on a corexy.
            You're on the right track. On a cartesian printer it's easy because it's one motor and direction per axis. With corexy there is motor direction of rotation and also which motor is connected to which driver that also matters.
            The movement test in the link isolates each motor so you can see which direction it's going by itself and then from the results it tells you what to change.
            undefined 1 Reply Last reply 25 Aug 2020, 18:15 Reply Quote 0
              peter247 @Phaedrux
              @Phaedrux
              So from your link is way to fix is ?
              If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
              My head hurts !!! Brain Overload !!!!
              undefined 1 Reply Last reply 25 Aug 2020, 18:16 Reply Quote 0
                tracar @peter247
                @peter247 brain overload x2
                undefined 1 Reply Last reply 25 Aug 2020, 18:20 Reply Quote 0
                  M569 P0 S0 ; X motor runs forwards
                  M569 P1 S0 ; Y motor runs forwards
                  Set that first.
                  Test for the correct X motor movement by sending these commands from the console:
                  G91
                  G1 S2 X10 F3000
                  If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
                  When you have the X motor moving correctly, test the Y motor by sending from the console:
                  G91
                  G1 S2 Y10 F3000
                  If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
                  Y+ meaning to the back
                  undefined 1 Reply Last reply 25 Aug 2020, 18:22 Reply Quote 0
                    peter247 @tracar
                    @tracar
                    You do need to change the Y homing files , but I think you may have to play to get the direction correct.
                    Don't forget to invert all the moves or the G1 Y5 F800 will push it into the end stop.
                      The homing direction for Y should be positive direction to the endstop at the rear.
                        tracar @Phaedrux
                        @Phaedrux said in hbot homes correctly but prints mirrored ,:
                        im not using the built in drivers , all are external
                        my config is currently this for x and y:
                        M569 P5 S1 T5 R1 ; physical drive x goes forwards
                        M569 P6 S1 T5 R1 ; physical drive y goes forwards
                        undefined 1 Reply Last reply 25 Aug 2020, 18:23 Reply Quote 0
                          Phaedrux Moderator @tracar
                          @tracar said in hbot homes correctly but prints mirrored ,:
                          Ok, well the idea is that you're setting the motors to rotate in a forward direction, however you do that. I believe that would make it clockwise.
                            tracar
                            i have set to this
                            M569 P5 S0 T5 R1 ; physical drive x goes forwards
                            M569 P6 S0 T5 R1 ; physical drive y goes forwards
                            the
                            G91
                            G1 S2 X10 F3000
                            they both move towards the back left corner (where the endstops are )
                            so x moves in a negative and y in a positive
                            undefined 1 Reply Last reply 25 Aug 2020, 18:45 Reply Quote 0
                              So swap your X and Y motor plugs.
                                tracar
                                changed drives to :
                                M584 X6 Y5 Z7:8 E3 ; set drive mapping
                                now with
                                G91
                                G1 S2 X10 F3000
                                x and y move to the negative. so heading x to 0 and y to 0
                                which is the front left side of the printer.
                                undefined 1 Reply Last reply 25 Aug 2020, 18:57 Reply Quote 0
                                  If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. Or in your case, flip the direction on your external stepper for the P0 driver, labeled as X.
                                  Actually that might be wrong because you've now remapped which driver X is assigned to. You're now using driver 6? Flip that one.
                                    tracar
                                    M569 P5 S0 T5 R1 ; physical drive y goes forwards
                                    M569 P6 S1 T5 R1 ; physical drive x goes forwards
                                    both move in a positive , to the top right side of the printer
                                    undefined 1 Reply Last reply 25 Aug 2020, 19:06 Reply Quote 0
                                      Move on to the next direction move test.
                                      G91
                                      G1 S2 Y10 F3000
                                        tracar
                                        x pos
                                        y neg
                                          Alright, so now when you jog the print head normally, does +x go to the right and Y+ to the back?
                                          Have you changed your homing files to move to Y positive?
                                          undefined 1 Reply Last reply 25 Aug 2020, 19:17 Reply Quote 0
                                          66 out of 169
