    hbot homes correctly but prints mirrored ,
    8.1k
    • peter247undefined
      peter247 @Phaedrux
      @Phaedrux
      So from your link is way to fix is ?
      If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
      My head hurts !!! Brain Overload !!!!
      Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
      tracarundefined 1 Reply Last reply Reply Quote 0
      • tracarundefined
        tracar @peter247
        @peter247 brain overload x2
        peter247undefined 1 Reply Last reply Reply Quote 0
          M569 P0 S0 ; X motor runs forwards
          M569 P1 S0 ; Y motor runs forwards
          Set that first.
          Test for the correct X motor movement by sending these commands from the console:
          G91
          G1 S2 X10 F3000
          If the head moves diagonally in the +X and +Y directions, all is well. If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. If it moves towards +X and -Y, or towards -X and +Y, then either turn the power off and swap the X and Y motor connections, or use M584 in config.g to swap the X and Y motor drivers over.
          When you have the X motor moving correctly, test the Y motor by sending from the console:
          G91
          G1 S2 Y10 F3000
          If the head moves diagonally in the +X and -Y directions, all is well. If it moves in the -X and +Y directions, change the S parameter in the M569 P1 command to S1.
          Y+ meaning to the back
          • peter247undefined
            peter247 @tracar
            @tracar
            You do need to change the Y homing files , but I think you may have to play to get the direction correct.
            Don't forget to invert all the moves or the G1 Y5 F800 will push it into the end stop.
              The homing direction for Y should be positive direction to the endstop at the rear.
              • tracarundefined
                tracar @Phaedrux
                @Phaedrux said in hbot homes correctly but prints mirrored ,:
                im not using the built in drivers , all are external
                my config is currently this for x and y:
                M569 P5 S1 T5 R1 ; physical drive x goes forwards
                M569 P6 S1 T5 R1 ; physical drive y goes forwards
                  Phaedrux Moderator @tracar
                  @tracar said in hbot homes correctly but prints mirrored ,:
                  Ok, well the idea is that you're setting the motors to rotate in a forward direction, however you do that. I believe that would make it clockwise.
                  • tracarundefined
                    tracar
                    i have set to this
                    M569 P5 S0 T5 R1 ; physical drive x goes forwards
                    M569 P6 S0 T5 R1 ; physical drive y goes forwards
                    the
                    G91
                    G1 S2 X10 F3000
                    they both move towards the back left corner (where the endstops are )
                    so x moves in a negative and y in a positive
                      So swap your X and Y motor plugs.
                      • tracarundefined
                        tracar
                        changed drives to :
                        M584 X6 Y5 Z7:8 E3 ; set drive mapping
                        now with
                        G91
                        G1 S2 X10 F3000
                        x and y move to the negative. so heading x to 0 and y to 0
                        which is the front left side of the printer.
                          If it moves in the -X and -Y directions, change the S parameter to S1 in the M569 P0 command. Or in your case, flip the direction on your external stepper for the P0 driver, labeled as X.
                          Actually that might be wrong because you've now remapped which driver X is assigned to. You're now using driver 6? Flip that one.
                          • tracarundefined
                            tracar
                            M569 P5 S0 T5 R1 ; physical drive y goes forwards
                            M569 P6 S1 T5 R1 ; physical drive x goes forwards
                            both move in a positive , to the top right side of the printer
                              Move on to the next direction move test.
                              G91
                              G1 S2 Y10 F3000
                              • tracarundefined
                                tracar
                                x pos
                                y neg
                                  Alright, so now when you jog the print head normally, does +x go to the right and Y+ to the back?
                                  Have you changed your homing files to move to Y positive?
                                  • tracarundefined
                                    tracar
                                    jogging is correct
                                    y homing needs to be reversed
                                    • peter247undefined
                                      peter247 @Phaedrux
                                      @Phaedrux
                                      There is also some positive move need to go minus , eg the back off the end stop move , or they will push into the back stop instead of backing off.
                                      So like I said don't change invert all y moves.
                                      • tracarundefined
                                        tracar
                                        homeall works
                                        homex ,and homey work
                                        and......x y jog work in the right way
                                        • peter247undefined
                                          peter247 @tracar
                                          @tracar
                                          So all you need to do now is set the Z offset ?
                                          • tracarundefined
                                            tracar
                                            @peter247 said in hbot homes correctly but prints mirrored ,:
                                            z always worked right
