    My BLV MGN cube build/upgrade saga (ongoing)
    My Duet controlled machine
    11
    54
    9.1k
    • dhusoloundefined
      dhusolo
      You don't need to have Facebook for it and it's not really an "official" beta. The parts have been released to only one specific supplier on Aliexpress. Anyone can order them. There's no signup to get them. You just buy them
      • Vetiundefined
        Veti @dhusolo
        @dhusolo
        can you answer some questions?
        where do the endstops on the x carriage go now? the bottom seems to be different and no space to mount the endstop.
        are the mounting holes on the x carriage compatible with the hemera?
        does the original hotend cooling fan cover fit?
        does the original part cooling fan duct fit?
        dhusoloundefined 1 Reply Last reply Reply Quote 0
        • dhusoloundefined
          dhusolo @Veti
          @Veti I'm not entirely sure. I haven't seen any of the cad drawings to see how it's assembled. I won't purchase the metal parts until a suitable triple/quad independent Z axis is developed.
          However I was mistaken. You do need to be on the Facebook group to have access to the beta metal parts
          • I_Jediundefined
            I_Jedi @MartinNYHC
            I used blind joints with my Misumi extrusions and it was worth every penny! Misumi's cuts were spot on and when done, no angle was off my more than .3 degrees using my digital square. And SOLID as a rock to! Thanks to @Nuramori for the suggestion!
            • Vetiundefined
              Veti
              the metal parts have now been released.
              https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
              not sure if i will get them as i like a direct extruder setup, and so far its only bowden
              whopping pochardundefined dhusoloundefined MartinNYHCundefined 3 Replies Last reply Reply Quote 1
              • whopping pochardundefined
                whopping pochard @Veti
                @Veti that looks pretty great!
                • dhusoloundefined
                  dhusolo @Veti
                  @Veti Ben will be making a direct drive version. I also talked to him and I'm going to be alpha testing the independent triple Z setup when he finishes it
                  • MartinNYHCundefined
                    MartinNYHC @Veti
                    @Veti I just assembled the kit and I think it's worth it even if you don't use the extruder parts. I also skipped the extruder parts because I'm using a BMG-M with Mosquito.
                    And I'm currently working on a three axis setup 😉
                    • Vetiundefined
                      Veti
                      Ben just posted a video about blind joints
                      https://www.youtube.com/watch?v=ueniUWrUcjE
                      MartinNYHCundefined 1 Reply Last reply Reply Quote 0
                        MartinNYHC @Veti
                        @Veti Yes, I'm very interested but I think I can't wait until it's available. I need my kitchen 🙂
                        • Vetiundefined
                          Veti @MartinNYHC
                          @MartinNYHC
                          not by ben, but for 1204 there is a metal kit
                          https://de.aliexpress.com/item/4001277526161.html
                            MartinNYHC @Veti
                            @Veti Very nice. Did you try it?
                            Wondering if there every will be a point in time where a build is finished. Don't think so 😂
                            • Vetiundefined
                              Veti @MartinNYHC
                              @MartinNYHC
                              no i made my own 1204 mounting with metal parts.
                                whopping pochard
                                Very cool! Love to see the ballscrews.
                                Looking forward to seeing the finished product!
                                • Vetiundefined
                                  Veti
                                  the bed is rock solid and does not move under pressure.
                                    MartinNYHC
                                    @Veti Can you please share details of your reinforcement rods and mounts? Where can I get them?
                                    • Vetiundefined
                                      Veti @MartinNYHC
                                      @MartinNYHC
                                      4x 8mm linear rods (had them from an old printer)
                                      8x SK8
                                      https://www.robotdigg.com/product/126/SK8-Linear-Shaft-Support-Unit
                                      4 SCS8LUU (screwed into 2020 profile with m3 t nut)
                                      https://www.robotdigg.com/product/422/SCS8LUU-Linear-Block
                                      2 Nema 17 2020 mounting brackets (the store from which i ordered does not sell them anymore, similar item)
                                      https://www.aliexpress.com/item/32892098907.html
                                      2 SFU1204
                                      the sfu1204 mount will be replaced with when i replace the other parts with the blv metal kit
                                      https://www.aliexpress.com/item/4001120210864.html
                                        MartinNYHC
                                        Thanks @Veti
                                        • fcwiltundefined
                                          fcwilt
                                          Simple can work as well.
                                          The part with the V groove attaches to the bed support frame, which is not shown for clarity purposes.
                                          I like seeing the wide variety of solutions to common issues.
                                          • flux_capacitorundefined
                                            flux_capacitor
                                            Amazing mod! The independent triple z-axis system from @Nuramori seems unavailable though: the zip file on Thingiverse contains only one small file (chain_mount_-_bed.stl). What happened to the design?
                                            dhusoloundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
