    Battling sources of vibration and noise
    My Duet controlled machine
    9
    84
    5.6k
    • arhiundefined
      arhi @Nxt-1
      @Nxt-1 said in Battling sources of vibration and noise:
      already ordered and received 20T pulleys, the same as I already had a few. I'll keep the larger pulley sizes in mind for possible future revisions.
      I use big ones for the sake of belt longevity, no clue if they reduce noise, and I don't see why they would reduce noise .. now as already mentioned using 2 different size pulleys is an interesting prospect in increasing speed or precision
      • Kolbiundefined
        Kolbi @Nxt-1
        @Nxt-1, the downwards force would be from the motor's weight. Next time you pull one of the motors out, try to suspend it, with fingers at the arrow points shown below. But this is not a concern in your latest revision as the motor is supported at both ends. With this design, I would add a third damper mounting at the center position (between the two existing) on both, bottom and side mounting planes. This would give you some ability to experiment whereas maybe just one (centerline), or two (end-points), or all three dampers employed on the end/centerline would be best or for the bottom or side mount.
        • Nxt-1undefined
          Nxt-1
          Over Friday and Saturday I designed, printed and tested some revisions and I don't think it's going to work out.
          The first version looked very similar to the pictures I already posted here, but with just the front support (on the bottom and side). This was not really any better than the previous style brackets. The whole top bracket still resonated and noise was not really any better. During testing I also noticed I have made a minor error, resulting in a belt that was to right and pulling the motor to the side. It also seemed like the little rollers in the needle bearing were resonating.
          To verify the bearing issue, I redesigned the bracket to accept 608 bearings instead. Testing showed no audible change in vibration levels. Test belt tension was also corrected, so the motor sits just about perfectly straight. While this version was printing I did design a version with 2 back support dampers, but ended up not printing it as it this style of bracket seems not they way to go and the motor sat level anyway.
          To verify one more thing I removed the belt and did the same arc move that I have been using to test for a while now. And it was noticeably better. So what I feared seems true, the belt itself is poor vibration isolator. In fact the belt seems like the only real path the vibrations can couple into the rest of the machine.
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
          Kolbiundefined 1 Reply Last reply Reply Quote 0
          • Nxt-1undefined
            Nxt-1
            At this moment I am debating whether to take the money dive and have the old style brackets cnc machined out of steel (weerg.com has a promotion that makes the steel options cheaper than alu at the moment 🙂 )
            A user on the reprap forums reported that improved noise vibration issue he had with his nema23's (link to the post). It could make sense from a rigidity standpoint as well as the added mass, more mass is normally less vibrations right. Yet then again all the previous things I tried made sense too, and they didn't cost €360 to 'try out'.
            engikeneerundefined 1 Reply Last reply Reply Quote 0
            • engikeneerundefined
              engikeneer @Nxt-1
              @Nxt-1 if it is definitely the belt thats causing the resonance issues, I'd focus my efforts on that. Did you try the 20T pulleys? What about making a significant change to the belt length (longer or shorter)? Granted this might be tricky given the machine design... have you also tried using 9mm or 12mm belts instead? They'll at least have different mass/stiffness properties.
              i3 clone with a bunch of mods
              Nxt-1undefined 1 Reply Last reply Reply Quote 0
              • Nxt-1undefined
                Nxt-1 @engikeneer
                @engikeneer said in Battling sources of vibration and noise:
                I should have explained it better, I don't believe belts are causing resonance issues, the belts simply allow the vibrations to travel from the motor to the other parts of the machine instead of staying isolated to just the motor vibrating. If the belts themselves were sources of vibration you'd expect the frequency of the noise to change with varying belt tensions or lengths, which is is the opposite of what I am observing.
                Just as an fyi, I am using 9mm proper gates belts on 20T pulleys
                • Kolbiundefined
                  Kolbi @Nxt-1
                  @Nxt-1 What is the loading range of the mounts you are using in the pic? IMO they seem way too rigid - they do not yield enough elasticity to absorb the vibration energy for this application. That is if the vibration energy is emitting from the motor itself.
                  • Nxt-1undefined
                    Nxt-1 @Kolbi
                    @Kolbi said in Battling sources of vibration and noise:
                    Sadly hard to say, I picked them up from a local hardware store and they were specified as 'damper, type B', no more no less. I agree, due to the compact size the isn't really that much room for flexing rubber, so they are stiffer than I'd have wanted. On the other hand, from my test without the belt, I can conclude they do their job. Otherwise the vibrations would still travel trough the rubber into the frame, which wasn't the case.
                    • Nxt-1undefined
                      Nxt-1
                      Finally some good news! 🙂
                      Yesterday evening I decided to try the inertial damper route. Someone linked it before in this thread and it's basically a high rotational inertia disk that you bolt on the stepper shaft. The added inertia functions similar to a smoothing capacitor in electronics and smooths down the riple, in this case of the vibrations caused by the motor.
                      Because I didn't have the time (nor the budget to just try) to get the real stuff from Oriental, I designed a very simple DIY intermediate. With lead disks and a printer cover to keep them in place. While it certainly is DIY 🙂 it provides a night and day difference. I will most likely order the proper ones this week.
                      arhiundefined theruttmeisterundefined 2 Replies Last reply Reply Quote 1
                      • arhiundefined
                        arhi @Nxt-1
                        @Nxt-1 aren't those supposed to slip?
                        • Nxt-1undefined
                          Nxt-1 @arhi
                          @arhi said in Battling sources of vibration and noise:
                          Examining what little documents I can find on the proper dampers that could very well be the case. And I see it making sense to smooth movement while continuously turning, yet not hindering acceleration/jerk.
                          I don't think that level of performance is going to happen with what I just build here though, it's either all slip or no slip 🙂
                          I just placed an order for 3 of the proper ones from Oriental so we'll find out more soon enough I guess 🙂
                          arhiundefined Kolbiundefined 2 Replies Last reply Reply Quote 0
                          • arhiundefined
                            arhi @Nxt-1
                            @Nxt-1
                            https://forum.duet3d.com/topic/17007/fly-wheel-on-stepper-motor
                            https://www.cnczone.com/forums/stepper-motors-drives/30941-making-harmonic-dampers-flywheel-motors.html
                            • Kolbiundefined
                              Kolbi @Nxt-1
                              Hope it goes well, I was wondering how those would be in regards to acceleration and jerk.
                              • theruttmeisterundefined
                                theruttmeister @Nxt-1
                                @Nxt-1
                                I'm curious to see the numbers once you have three installed. I would expect that you can still get the motors to vibrate, but the dampers are probably shifting that frequency to a place you'll never get to...
                                I'm also curious if they make a difference to print quality.
                                Isolate, substitute, verify.
                                • Kolbiundefined
                                  Kolbi
                                  @Nxt-1, I just had an idea on determining your motor vibration emission, not sure on how effective though.
                                  If you cut the current down by ~75% it should decrease the intensity of motor generated vibrations while the movement (drive train) generated vibrations would stay the same. This could let you know what to expect with the installation of the rotational dampers / help separate the two possible offending sources.
                                  • Nxt-1undefined
                                    Nxt-1 @Kolbi
                                    This is what I am doing at the moment to keep the noise levels down whenever I want to. It's a far from ideal solution but quite effective. Further reinforcing my point that the motors are the major source if not the only real source.
                                    • Kolbiundefined
                                      Kolbi @Nxt-1
                                      @Nxt-1 Did you make any progress with the Oriental clean dampers?
                                      • Nxt-1undefined
                                        Nxt-1 @Kolbi
                                        @Kolbi Define progress, I am 2/3's of the way through waiting for them to be shipped 😞 Oriental is disappointingly slow this time around, the expected shipping date is the 24th
                                        • Kolbiundefined
                                          Kolbi @Nxt-1
                                          @Nxt-1 Ug, that sucks.
                                          • Nxt-1undefined
                                            Nxt-1
                                            Finally some decent news, the dampers arrived as predicted on the 25th. Installation was quick and easy, two setscrews and done. On thing that I noticed right away is that they are light, the datasheets specs them at 61g. Compared to the ~300-400g of lead I had on there before, that's absolutely nothing. This made my quite hesitant as to there performance.
                                            Yet after some first moves I can say that the dampers do not disappoint. Not a magical noise reducer by any means but they definitely take the edge off and bring the noise down to something acceptable. I need to do some more testing but at this point I'd say they are worth ~€120 for a set.
                                            At this point I still plan to have the motor brackets machined out of steel, but for a number of reasons (including cost) that will have to wait for a while. What I do want to try out soon-ish is removing the stepper face dampers again. Just to see what would happen.
                                            Kolbiundefined 1 Reply Last reply Reply Quote 1
