    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.0k
    • smoki3undefined
      smoki3
      @deadwood83 Cool design. I use a would use a similar one but with an integrated 5V DCDC converter to power the raspberry. Otherwise you need an external one which is not so pretty and easy to use.
      I also integrated the same pin layout as on the raspberry to use a simple ribbon cable.
      But actually the firmware is the first thing which need to be fixed 🙂
      • PCRundefined
        PCR
        @deadwood83 Wrote you a PM
          A Former User @deadwood83
          @deadwood83 said in Duet 2 Ethernet and SBC:
          2 layer FR4 1.6mm 1-Oz copper PCB
          4 layer and 2 Oz for the Duets
            T3P3Tony administrators @deadwood83
            @deadwood83 R100,R101,R105 on the SPI lines on the Duet 2 side are 47R. There are relatively short lines from those resistors to the relevant pins. External copper is 2Oz and these are 0.25mm traces. internal solder is 1Oz, same trace width.
            Where we use those buffers on the Duet 3 we don't have series resistors in the circuit as well as the buffers so the 470R is probably unnecessary
            • deadwood83undefined
              deadwood83 @arhi
              @arhi said in Duet 2 Ethernet and SBC:
              The schematics/PCB
              awesome 🙂 thanks
              Did you made this in kicad and exported to easyeda or you made it directly in easyeda. I can redraw it in kicad but if you already have it in kicad it would save me some time 😄
              I made it in EasyEDA. I keep trying to go to KiCAD but snap to grid just... drives me completely insane. I wager that will become pretty much mandatory once I graduate beyond 2-layer.
              @smoki3 said in Duet 2 Ethernet and SBC:
              I fear that any buck which would fit on a reasonable sized board would not be up to snuff. I have seen LMs and MP bucks burn Pi's faaaar too many times to feel comfortable putting one in one of my designs. Also, when you put power to the pi through GPIO it is my understanding that it bypasses a significant section of input protection. I will stick to $10 10A converters. Much safer to run 10-30% of a very cheap piece of kit's rating IMO when it has questionable pedigree.
              RE: Ribbon cable; My personal preference is to twist MISO/MOSI lines from individual conductors. CS has a buffer resistor near the node end (and doesn't have the sensitivity of the other 3) and 3v3_Pi isn't near the SPI pins anyway. Plus anybody soldering to a 3d printer controller probably has some dupont connectors #DiabloEternal
              RE: Firmware fix; from the RF3.2 excel spreadsheet -
              Duet+SBC support
              Duet 2 SBC support Done
              @PCR said in Duet 2 Ethernet and SBC:
              Replied
              @bearer said in Duet 2 Ethernet and SBC:
              Understood, my impedance calcs were based on my cheap PCB though. I am not worried about the Duet circuitry since it comes from more capable designers than I
              @T3P3Tony said in Duet 2 Ethernet and SBC:
              Thanks Tony. I have updated my PCB layout to remove that and will put a simple solder bridge once my PCBs arrive. Being 0403 size, it could probably be bridged with a c-store lighter! (I will use my T12 station)
              arhiundefined wilrikerundefined 2 Replies Last reply Reply Quote 0
              • arhiundefined
                arhi @deadwood83
                😄 😄 😄 I'm still getting used to KiCAD since I don't have access to licenced Altium any more and since I don't allow "cured" software on my computers had to find alternative and KiCAD is kinda best I managed to find.
                The grid thing .. what I do is I make my own set of trace widths and my own grid values and then I switch between them ... there's probbly a better way to do it but...
                I wanted to steal from your design the dimensions - position of headers vs that hole on top and the screw and ... but since I'm doing a push-on daughterboard (I used eth modules so remove eth board, plug in this one) with 5A DCDC and maybe some leds I might actually don't need to worry about positions...
                deadwood83undefined 1 Reply Last reply Reply Quote 0
                  deadwood83 @arhi
                  @arhi
                  There is a PCB in the EasyEDA link which is closed off and with through-holes for the ethernet board for those who want to just stick on some headers and go. The components are low-profile so it will fit top or bottom.
                  The only things you would need to add are 5v buck and some LEDs. Look in the EasyEDA project for ethernetPCB and you will find it there, ready for you.👍
                  • wilrikerundefined
                    wilriker @deadwood83
                    Duet+SBC support
                    Unfortunately this support is currently limited to Duet 2 only, i.e. no DueX2/DueX5 connected.
                    EDIT: the above is still considered a preliminary limitation and it is being worked on to get this resolved.
                    Explicitly pulling the ESP_Enable line down (for a still present Wifi module) should be added to firmware soon.
                    Manuel
                    My Tool Collection
                    • arhiundefined
                      arhi @deadwood83
                      @deadwood83 seen that but I want to make it different (a pcb that will plug directly into rpi + duet), but looks like easier to measure distance of the hole from the header than reworking the easyeda project ... I'll share the project when I make it
                        A Former User @arhi
                        the kicad sources for the duet gives you all the measurements, with the measurement tool in kicad? I used that to print a piece to glue some dupont headers to and keep the holes for the stand-offs.
                        arhiundefined 1 Reply Last reply Reply Quote 1
                        • arhiundefined
                          arhi @A Former User
                          HAAHA I did not see the tree from the forest ... thanks, I was trying to move the tiny board to kicad, danced with calipers... loading kicad source of the duet2eth board did not at any point come to mind 😄 😄 😄 thanks, that solves my problem 100%
                          • arhiundefined
                            arhi
                            I went with a WAAAAAY bigger board to avoid using any cables. Something like this .. I kept all 3 mount holes for the wifi board, expanded the board outside of the duet pcb so that this board can plug directly, in the same time, into duet and into rpi so no cables .. I also added a header for RX/TX for uart1 on the duet since it's not used any more might be useful for cnc pendant or second screen or ..
                            I still suck at kicad big time but this should work .. kicad files who wanna play, maybe make better
                            A Former User? JoergS5undefined 2 Replies Last reply Reply Quote 1
                              A Former User @arhi
                              interesting!
                              • arhiundefined
                                arhi @A Former User
                                interesting!
                                I just ordered assembled boards from jlpcb (trying them out for the first time, normally I was using seed, itead and dirty) should be here in 5-6 days so will say how it works (or not 😄 )
                                • JoergS5undefined
                                  JoergS5 @arhi
                                  @arhi I agree, it is an interesting idea to design without cables.
                                  • arhiundefined
                                    arhi @JoergS5
                                    @JoergS5 said in Duet 2 Ethernet and SBC:
                                    made sense to me, we'll see, fedex normally arrive inside 7 days so .. not a long time to wait and not expensive (2$ for 5 pcb's, 15$ assembly+parts, 15$ fedex) ideal board to try out the jlcpcb system
                                    oliofundefined Dougal1957undefined 2 Replies Last reply Reply Quote 0
                                      deadwood83
                                      Have you ever had a DHL driver scream at you then throw a package at your face while shouting "Social distancing?"
                                      Yeah, me either. They do leave things at my door and run away though. Jumper for scale.20200925_091645.jpg
                                      Look at those tiny resistors. Aren't they cute? you could accidentally desolder them with an intense gaze. I'm going to do just that to R1 and at least once to an R2.
                                      • smoki3undefined
                                        smoki3
                                        Any news about a firmware fix for SBC and Duex5?
                                          deadwood83
                                          Dry run looks super promising. I goofed though and realized I do not have any 24->5V USB-C power delivery units.
                                          Now I need to build out a male-male harness, throw this on my delta, solder a second board to the delta duet, and try a real run.
                                          smoki3undefined 1 Reply Last reply Reply Quote 0
                                          • smoki3undefined
                                            smoki3 @deadwood83
                                            @deadwood83 would be cool to have an integrated 5V regulator
                                            I used this one:
                                            https://www.amazon.de/PEMENOL-Einstellbar-Spannungwandler-Stromversorgung-Wirkungsgrad/dp/B07DP2MDJQ/ref=mp_s_a_1_2?dchild=1&keywords=5v+buck+converter&qid=1601061499&sprefix=5v+buxk+&sr=8-2
                                            They are super small. But I have to wire them with a cable directly from 24V
