    Duet 3 SBC DCS has stopped
    Beta Firmware
    8
    80
    4.5k
      jay_s_uk @dhusolo
      @dhusolo well at least you're back on the latest firmware.
      @chrishamm any comments on the error above whilst updating?
      • dhusoloundefined
        dhusolo
        More of a status update: I've started the same print again but I don't load any filament. I didn't want to waste the filament if it's going to cancel on me again.
        However I can now hear some strange jerky movements. I have a coreXY so it's hard to narrow down what stepper it's coming from especially since there's no filament going through it.
        • oliofundefined
          oliof
          I think my recent post about issues with 3.2b3 are very similar to this issue.
            Phaedrux Moderator @dhusolo
            @dhusolo Thanks for the update. In the meantime are you able to downgrade to 3.1.1 and use standalone mode to get back printing reliably?
            A Former User? dhusoloundefined 2 Replies Last reply Reply Quote 0
              A Former User @Phaedrux
              @Phaedrux said in Duet 3 SBC DCS has stopped:
              Oh the irony.....
              • dhusoloundefined
                dhusolo @Phaedrux
                @Phaedrux I'm going to attempt to go back to RRF 3.1.1 with RPI since issues with connecting are resolved. Doesn't make a lot of sense that it was working previously for 3 months without any issue.
                If that brings the same symptoms I'll run it in standalone until RRF 3.2 is stable. At least I know the board isn't bad
                  Phaedrux Moderator @A Former User
                  @CaLviNx It's not irony because no one ever disagreed with you.
                  • dhusoloundefined
                    dhusolo
                    Can confirm going back to 3.1.1. the bug is still present. No idea why it appeared months after the original upload and weeks after any update to my config.
                    I did notice under Linux interface it shows a failed transfer, some bit loss and a SPI underrun
                    	M122
                    RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                    Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF
                    Used output buffers: 1 of 40 (12 max)
                    Static ram: 154604
                    Dynamic ram: 163392 of which 140 recycled
                    Exception stack ram used: 584
                    Never used ram: 74496
                    Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1384) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,2672) IDLE(ready,76)
                    Owned mutexes:
                    Last reset 03:06:26 ago, cause: power up
                    Last software reset at 2020-11-09 16:57, reason: User, spinning module LinuxInterface, available RAM 77008 bytes (slot 1)
                    Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                    Error status: 0
                    MCU temperature: min 34.4, current 37.6, max 39.2
                    Supply voltage: min 24.2, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                    Driver 0: standstill, reads 55804, writes 22 timeouts 0, SG min/max 0/193
                    Driver 1: standstill, reads 55797, writes 30 timeouts 0, SG min/max 0/1023
                    Driver 2: standstill, reads 55797, writes 30 timeouts 0, SG min/max 0/1023
                    Driver 3: standstill, reads 55794, writes 34 timeouts 0, SG min/max 0/1023
                    Driver 4: standstill, reads 55794, writes 34 timeouts 0, SG min/max 0/1023
                    Driver 5: standstill, reads 55795, writes 34 timeouts 0, SG min/max 0/1023
                    Date/time: 2020-11-09 20:05:07
                    Slowest loop: 9.46ms; fastest: 0.14ms
                    === Storage ===
                    Free file entries: 10
                    Hiccups: 0(0), FreeDm: 375, MinFreeDm: 317, MaxWait: 669637ms
                    Bed compensation in use: mesh, comp offset -0.024
                    === MainDDARing ===
                    Scheduled moves: 169139, completed moves: 169139, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                    === AuxDDARing ===
                    Segments left: 0
                    Movement lock held by null
                    HTTP* is ready with "M122" in state(s) 0
                    Telnet is idle in state(s) 0
                    File* is idle in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Queue* is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon* is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    Code queue is empty.
                    === Network ===
                    Slowest loop: 1.44ms; fastest: 0.01ms
                    HTTP sessions: 0 of 8
                    - Ethernet -
                    State: disabled
                    Error counts: 0 0 0 0 0
                    === Filament sensors ===
                    Extruder 0 sensor: ok
                    === CAN ===
                    Messages sent 44905, longest wait 0ms for type 0
                    === Linux interface ===
                    State: 0, failed transfers: 1
                    Last transfer: 17ms ago
                    RX/TX seq numbers: 36691/32296
                    SPI underruns 1, overruns 0
                    Number of disconnects: 0
                    Buffer RX/TX: 0/0-0
                    === Duet Control Server ===
                    Duet Control Server v3.1.1
                    Daemon:
                    Finishing macro daemon.g, started by system
                    > Next stack level
                    Code buffer space: 4096
                    Full transfers per second: 32.48
                      The irony is that time and effort has been needlessly expended in a vain attempt to fix an issue that the reason for (at this point of time) is evidently unknown when, instead of trying to fix it, the smart approach would have been to just go standalone in the first place which would have resulted in getting the machine printing again, and printing is the whole point of the exercise.
                      Phaedruxundefined dhusoloundefined 2 Replies Last reply Reply Quote 0
                        @CaLviNx It must be difficult going through life with such superior intellect. How do you manage to survive amongst us?
                        • dhusoloundefined
                          dhusolo @A Former User
                          @CaLviNx seriously stop commenting. I do beta testing and bug fixing for a living. I took the steps I did for a reason. Everyone else has been trying to help while all you've been doing is throwing jabs in and out of this thread. I don't need you to tell me what the "smart approach" is because "the whole point of the exercise" is to figure out what happened and to see if I could fix it, not applying a band-aid.
                          • chrishammundefined
                            chrishamm administrators
                            To get back to the topic: I think the previously reported problems should be fixed in 3.2.0-b3.2. Feel free to test this again.
                            Duet software engineer
                            dhusoloundefined 1 Reply Last reply Reply Quote 0
                              Trust me dealing with such stupidity on a daily basis is tiresome.....
                              • dhusoloundefined
                                dhusolo @chrishamm
                                @chrishamm That did fix the issue but after updating to 3.2.b3 I started to have jerky movements while printing that wasn't present before the update
                                  chrishamm administrators @dhusolo
                                  @dhusolo Please confirm that the installed RRF version is 3.2.0-beta3.2 and not 3.2.0-beta3.
                                  • dhusoloundefined
                                    dhusolo @chrishamm
                                    @chrishamm can confirm it was 3.2.b3
                                    M122
                                    RepRapFirmware for Duet 3 MB6HC version 3.2-beta3.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                    Used output buffers: 1 of 40 (10 max)
                                    Static ram: 122236
                                    Dynamic ram: 139164 of which 24 recycled
                                    Never used RAM 130768, free system stack 200 words
                                    Tasks: Linux(ready,97) HEAT(blocked,296) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,54) MAIN(running,1189) IDLE(ready,19)
                                    Owned mutexes: HTTP(MAIN)
                                    Last reset 00:00:20 ago, cause: software
                                    Last software reset at 2020-11-16 16:14, reason: User, GCodes spinning, available RAM 130768, slot 0
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu
                                    Error status: 0x00
                                    MCU temperature: min 38.3, current 38.7, max 38.8
                                    Supply voltage: min 24.6, current 24.7, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                                    12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0
                                    Driver 0: position 0, standstill, reads 35729, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 1: position 0, standstill, reads 35730, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 2: position 0, standstill, reads 35731, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 3: position 0, standstill, reads 35732, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 4: position 0, standstill, reads 35733, writes 14 timeouts 0, SG min/max 0/0
                                    Driver 5: position 0, standstill, reads 35733, writes 14 timeouts 0, SG min/max 0/0
                                    Date/time: 2020-11-16 16:14:56
                                    Slowest loop: 1.42ms; fastest: 0.19ms
                                    === Storage ===
                                    === MainDDARing ===
                                    Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                    === AuxDDARing ===
                                    Segments left: 0
                                    File is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    === CAN ===
                                    Messages sent 55, send timeouts 55, longest wait 0ms for type 0, free CAN buffers 47
                                    === SBC interface ===
                                    State: 0, failed transfers: 0
                                    Last transfer: 20ms ago
                                    RX/TX seq numbers: 440/442
                                    SPI underruns 0, overruns 0
                                    Number of disconnects: 0, IAP RAM available 0x20a30
                                    Buffer RX/TX: 0/0-0
                                    Duet Control Server v3.2.0-beta3
                                    Full transfers per second: 30.36
                                      @dhusolo What triggers are you using? Can you share the corresponding macro files?
                                      • dhusoloundefined
                                        dhusolo @chrishamm
                                        @chrishamm Actually I'm not actively using the trigger anymore. That was originally configured for RRF2 as a shutdown button. trigger2.g might exist but it's not defined in config.g.
                                        I've tried printing with 3.2.b3 to see if the jerky movements come back. So far it hasn't. It's a different model and it's slower speeds so i'm wondering if the print speeds had been related to why it was doing it. I'm going to try that other file again to see if I can replicate it. If I can at my normal print speeds I'll slow it down to see if it happens again.
                                        • dhusoloundefined
                                          dhusolo @chrishamm
                                          @chrishamm I ran the print that had the jerky movement after updating and it seemed like it printed normally.
                                          I made sure I followed the getting started link verbatim. Originally I didn't use Etcher or the Raspberry Pi Imager program to write the image. I used a program called USB Image Tool because i've been using it for years. This time I used the Raspberry Pi Imager. The only other thing I can think I did different was I don't remember changing the buffer size before
                                          echo "options spidev bufsiz=8192" | sudo tee /etc/modprobe.d/spidev.conf
                                          • dhusoloundefined
                                            dhusolo
                                            Well it happened again while running 3.2.b3. It has been printing pretty good the last week. Over night the print cancelled but it just stopped printing. The heaters are still at temp and the head was in the same position on the print, it didn't run pause.g.
                                            When I started DWC on my PC the print status was still printing. I pressed pause and that's when it ran pause.g. I tried to resume the print and it said cannot print no file selected
                                            m122
                                            Static ram: 122236
                                            Dynamic ram: 139788 of which 64 recycled
                                            Never used RAM 130104, free system stack 118 words
                                            Tasks: Linux(ready,67) HEAT(blocked,295) CanReceiv(blocked,948) CanSender(blocked,343) CanClock(blocked,352) TMC(blocked,18) MAIN(running,669) IDLE(ready,19)
                                            Last reset 14:24:35 ago, cause: software
                                            Last software reset at 2020-11-22 19:53, reason: User, GCodes spinning, available RAM 130104, slot 2
                                            Error status: 0x00
                                            MCU temperature: min 35.4, current 37.2, max 38.3
                                            Supply voltage: min 24.2, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                                            Driver 0: position 200, standstill, reads 25360, writes 21 timeouts 0, SG min/max 0/202
                                            Driver 1: position -200, standstill, reads 25349, writes 33 timeouts 0, SG min/max 0/1023
                                            Driver 2: position 5843, standstill, reads 25350, writes 33 timeouts 0, SG min/max 0/1023
                                            Driver 3: position 0, standstill, reads 25350, writes 33 timeouts 0, SG min/max 0/1023
                                            Driver 4: position 0, standstill, reads 25351, writes 33 timeouts 0, SG min/max 0/1023
                                            Driver 5: position 0, standstill, reads 25352, writes 33 timeouts 0, SG min/max 0/1023
                                            Date/time: 2020-11-23 10:17:46
                                            Slowest loop: 278.17ms; fastest: 0.09ms
                                            === Storage ===
                                            Hiccups: 0(0), FreeDm: 375, MinFreeDm: 354, MaxWait: 10418300ms
                                            === MainDDARing ===
                                            Scheduled moves 480277, completed moves 480277, StepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state -1
                                            === AuxDDARing ===
                                            Segments left: 0
                                            === CAN ===
                                            Messages sent 207659, send timeouts 207659, longest wait 0ms for type 0, free CAN buffers 47
                                            Last transfer: 19ms ago
                                            RX/TX seq numbers: 27088/26081
                                            SPI underruns 3, overruns 0
                                            Buffer RX/TX: 0/0-0
                                            Full transfers per second: 32.32
