    Duet 3 SBC DCS has stopped
    Beta Firmware
    8
    80
    4.5k
    • dhusoloundefined
      dhusolo
      Sure. Should I use the getting started link or manually flash? I've tried compiling the firmware myself but with no success which is why I used the instructions in the link
        jay_s_uk @dhusolo
        @dhusolo that should be all you need to follow to move over to the unstable branch.
        There's no need to use the erase button to load the firmware as it will be updated as part of the upgrade process
        • dhusoloundefined
          dhusolo
          I thought i did it correct but I got this error
          pi@duet3:~ $ sudo apt-get install duetsoftwareframework
          Reading package lists... Done
          Building dependency tree
          Reading state information... Done
          The following additional packages will be installed:
            duetcontrolserver duetruntime duetsd duettools duetwebcontrol duetwebserver
            reprapfirmware
          The following packages will be upgraded:
            duetcontrolserver duetruntime duetsd duetsoftwareframework duettools
            duetwebcontrol duetwebserver reprapfirmware
          8 upgraded, 0 newly installed, 0 to remove and 118 not upgraded.
          Need to get 34.0 MB of archives.
          After this operation, 0 B of additional disk space will be used.
          Do you want to continue? [Y/n] y
          Get:1 https://pkg.duet3d.com unstable/armv7 armhf duetsoftwareframework armhf 3.2.0-beta3 [2,034 B]
          Get:2 https://pkg.duet3d.com unstable/armv7 armhf duetsd all 1.1.0 [2,102 B]
          Get:3 https://pkg.duet3d.com unstable/armv7 armhf duettools armhf 3.2.0-beta3 [62.2 kB]
          Get:4 https://pkg.duet3d.com unstable/armv7 armhf duetcontrolserver armhf 3.2.0-beta3 [226 kB]
          Get:5 https://pkg.duet3d.com unstable/armv7 armhf duetruntime armhf 3.2.0-beta3 [28.9 MB]
          Get:6 https://pkg.duet3d.com unstable/armv7 armhf duetwebserver armhf 3.2.0-beta3 [83.9 kB]
          Get:7 https://pkg.duet3d.com unstable/armv7 armhf duetwebcontrol all 3.2.0-beta3 [3,507 kB]
          Get:8 https://pkg.duet3d.com unstable/armv7 armhf reprapfirmware all 3.2.0-beta3-1 [1,260 kB]
          Fetched 34.0 MB in 19s (1,813 kB/s)
          Reading changelogs... Done
          (Reading database ... 79179 files and directories currently installed.)
          Preparing to unpack .../0-duetsoftwareframework_3.2.0-beta3_armhf.deb ...
          Unpacking duetsoftwareframework (3.2.0-beta3) over (3.1.1) ...
          Preparing to unpack .../1-duetsd_1.1.0_all.deb ...
          Unpacking duetsd (1.1.0) over (1.0.6) ...
          Preparing to unpack .../2-duettools_3.2.0-beta3_armhf.deb ...
          Unpacking duettools (3.2.0-beta3) over (3.1.1) ...
          Preparing to unpack .../3-duetcontrolserver_3.2.0-beta3_armhf.deb ...
          Unpacking duetcontrolserver (3.2.0-beta3) over (3.1.1) ...
          Preparing to unpack .../4-duetruntime_3.2.0-beta3_armhf.deb ...
          Unpacking duetruntime (3.2.0-beta3) over (3.1.1) ...
          Preparing to unpack .../5-duetwebserver_3.2.0-beta3_armhf.deb ...
          Unpacking duetwebserver (3.2.0-beta3) over (3.1.0) ...
          Preparing to unpack .../6-duetwebcontrol_3.2.0-beta3_all.deb ...
          Unpacking duetwebcontrol (3.2.0-beta3) over (3.1.1) ...
          Preparing to unpack .../7-reprapfirmware_3.2.0-beta3-1_all.deb ...
          Unpacking reprapfirmware (3.2.0-beta3-1) over (3.1.1-1) ...
          Setting up duetruntime (3.2.0-beta3) ...
          Setting up duetcontrolserver (3.2.0-beta3) ...
          Installing new version of config file /opt/dsf/conf/config.json ...
          Creating group dsf with gid 995.
          Creating user dsf (n/a) with uid 995 and gid 995.
          Setting up duettools (3.2.0-beta3) ...
          Setting up duetwebserver (3.2.0-beta3) ...
          Setting up duetsoftwareframework (3.2.0-beta3) ...
          To modify config files consider adding yourself to the dsf groupd: # usermod -a -G dsf <username>
          Setting up duetwebcontrol (3.2.0-beta3) ...
          Setting up duetsd (1.1.0) ...
          Setting up reprapfirmware (3.2.0-beta3-1) ...
          Sending update request to DCS... Error: Failed to send update request
          Unhandled exception. System.Threading.Tasks.TaskCanceledException: A task was canceled.
             at DuetAPIClient.BaseConnection.PerformCommand[T](BaseCommand command, CancellationToken cancellationToken) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetAPIClient/BaseConnection.cs:line 188
             at DuetControlServer.Program.CheckForAnotherInstance() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 305
             at DuetControlServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Program.cs:line 84
             at DuetControlServer.Program.<Main>(String[] args)
            jay_s_uk @dhusolo
            @dhusolo
            Are you still able to connect to the board via DWC?
            If you can confirm the firmware version using 3.1.1
            If it's still 3.1.1, send M997 B0
            I would be interested to see if you get any errors reported
            dhusoloundefined 1 Reply Last reply Reply Quote 0
            • dhusoloundefined
              dhusolo @jay_s_uk
              @jay_s_uk
              I had to start DCS and DWS manually but I was able to get to the web interface.
              M122 "DSF"
              === Duet Control Server ===
              Duet Control Server v3.2.0-beta3
              Code buffer space: 4096
              Full transfers per second: 32.68
              11/8/2020, 2:58:59 PM```
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.2-beta3 running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-956L2-G43S8-6J9D0-3S46T-9U2LF
              Used output buffers: 1 of 40 (10 max)
              Static ram: 122124
              Dynamic ram: 137508 of which 0 recycled
              Never used RAM 132560, free system stack 185 words
              Tasks: Linux(ready,131) HEAT(blocked,362) CanReceiv(blocked,948) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,66) MAIN(running,1300) IDLE(ready,19)
              Owned mutexes: HTTP(MAIN)
              Last reset 00:09:17 ago, cause: software
              Last software reset details not available
              Error status: 0x00
              MCU temperature: min 25.3, current 26.2, max 26.4
              Supply voltage: min 0.3, current 0.3, max 0.3, under voltage events: 0, over voltage events: 0, power good: no
              12V rail voltage: min 0.1, current 0.2, max 0.2, under voltage events: 0
              Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
              Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
              Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
              Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
              Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
              Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max 0/0
              Date/time: 2020-11-08 14:58:59
              Slowest loop: 743.08ms; fastest: 0.16ms
              === Storage ===
              Free file entries: 10
              === MainDDARing ===
              Scheduled moves 0, completed moves 0, StepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              === AuxDDARing ===
              Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === CAN ===
              Messages sent 0, send timeouts 0, longest wait 0ms for type 0, free CAN buffers 47
              === SBC interface ===
              State: 0, failed transfers: 1
              Last transfer: 14ms ago
              RX/TX seq numbers: 17902/17903
              SPI underruns 0, overruns 0
              Number of disconnects: 0, IAP RAM available 0x20aa0
              Buffer RX/TX: 0/0-0
              Full transfers per second: 32.56
                jay_s_uk @dhusolo
                @dhusolo well at least you're back on the latest firmware.
                @chrishamm any comments on the error above whilst updating?
                • dhusoloundefined
                  dhusolo
                  More of a status update: I've started the same print again but I don't load any filament. I didn't want to waste the filament if it's going to cancel on me again.
                  However I can now hear some strange jerky movements. I have a coreXY so it's hard to narrow down what stepper it's coming from especially since there's no filament going through it.
                  • oliofundefined
                    oliof
                    I think my recent post about issues with 3.2b3 are very similar to this issue.
                      Phaedrux Moderator @dhusolo
                      @dhusolo Thanks for the update. In the meantime are you able to downgrade to 3.1.1 and use standalone mode to get back printing reliably?
                      A Former User? dhusoloundefined 2 Replies Last reply Reply Quote 0
                        A Former User @Phaedrux
                        @Phaedrux said in Duet 3 SBC DCS has stopped:
                        Oh the irony.....
                        • dhusoloundefined
                          dhusolo @Phaedrux
                          @Phaedrux I'm going to attempt to go back to RRF 3.1.1 with RPI since issues with connecting are resolved. Doesn't make a lot of sense that it was working previously for 3 months without any issue.
                          If that brings the same symptoms I'll run it in standalone until RRF 3.2 is stable. At least I know the board isn't bad
                            Phaedrux Moderator @A Former User
                            @CaLviNx It's not irony because no one ever disagreed with you.
                            • dhusoloundefined
                              dhusolo
                              Can confirm going back to 3.1.1. the bug is still present. No idea why it appeared months after the original upload and weeks after any update to my config.
                              I did notice under Linux interface it shows a failed transfer, some bit loss and a SPI underrun
                              	M122
                              RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                              Used output buffers: 1 of 40 (12 max)
                              Static ram: 154604
                              Dynamic ram: 163392 of which 140 recycled
                              Exception stack ram used: 584
                              Never used ram: 74496
                              Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1384) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,2672) IDLE(ready,76)
                              Owned mutexes:
                              Last reset 03:06:26 ago, cause: power up
                              Last software reset at 2020-11-09 16:57, reason: User, spinning module LinuxInterface, available RAM 77008 bytes (slot 1)
                              Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
                              Error status: 0
                              MCU temperature: min 34.4, current 37.6, max 39.2
                              Supply voltage: min 24.2, current 24.5, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
                              12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
                              Driver 0: standstill, reads 55804, writes 22 timeouts 0, SG min/max 0/193
                              Driver 1: standstill, reads 55797, writes 30 timeouts 0, SG min/max 0/1023
                              Driver 2: standstill, reads 55797, writes 30 timeouts 0, SG min/max 0/1023
                              Driver 3: standstill, reads 55794, writes 34 timeouts 0, SG min/max 0/1023
                              Driver 4: standstill, reads 55794, writes 34 timeouts 0, SG min/max 0/1023
                              Driver 5: standstill, reads 55795, writes 34 timeouts 0, SG min/max 0/1023
                              Date/time: 2020-11-09 20:05:07
                              Slowest loop: 9.46ms; fastest: 0.14ms
                              === Storage ===
                              Hiccups: 0(0), FreeDm: 375, MinFreeDm: 317, MaxWait: 669637ms
                              Bed compensation in use: mesh, comp offset -0.024
                              === MainDDARing ===
                              Scheduled moves: 169139, completed moves: 169139, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
                              === AuxDDARing ===
                              Segments left: 0
                              HTTP* is ready with "M122" in state(s) 0
                              File* is idle in state(s) 0
                              Queue* is idle in state(s) 0
                              Daemon* is idle in state(s) 0
                              === Network ===
                              Slowest loop: 1.44ms; fastest: 0.01ms
                              HTTP sessions: 0 of 8
                              - Ethernet -
                              State: disabled
                              Error counts: 0 0 0 0 0
                              === Filament sensors ===
                              Extruder 0 sensor: ok
                              === CAN ===
                              Messages sent 44905, longest wait 0ms for type 0
                              === Linux interface ===
                              Last transfer: 17ms ago
                              RX/TX seq numbers: 36691/32296
                              SPI underruns 1, overruns 0
                              Buffer RX/TX: 0/0-0
                              Duet Control Server v3.1.1
                              Daemon:
                              Finishing macro daemon.g, started by system
                              > Next stack level
                              Full transfers per second: 32.48
                                The irony is that time and effort has been needlessly expended in a vain attempt to fix an issue that the reason for (at this point of time) is evidently unknown when, instead of trying to fix it, the smart approach would have been to just go standalone in the first place which would have resulted in getting the machine printing again, and printing is the whole point of the exercise.
                                Phaedruxundefined dhusoloundefined 2 Replies Last reply Reply Quote 0
                                  @CaLviNx It must be difficult going through life with such superior intellect. How do you manage to survive amongst us?
                                  • dhusoloundefined
                                    dhusolo @A Former User
                                    @CaLviNx seriously stop commenting. I do beta testing and bug fixing for a living. I took the steps I did for a reason. Everyone else has been trying to help while all you've been doing is throwing jabs in and out of this thread. I don't need you to tell me what the "smart approach" is because "the whole point of the exercise" is to figure out what happened and to see if I could fix it, not applying a band-aid.
                                    • chrishammundefined
                                      chrishamm administrators
                                      To get back to the topic: I think the previously reported problems should be fixed in 3.2.0-b3.2. Feel free to test this again.
                                      Duet software engineer
                                        Trust me dealing with such stupidity on a daily basis is tiresome.....
                                        • dhusoloundefined
                                          dhusolo @chrishamm
                                          @chrishamm That did fix the issue but after updating to 3.2.b3 I started to have jerky movements while printing that wasn't present before the update
                                            chrishamm administrators @dhusolo
                                            @dhusolo Please confirm that the installed RRF version is 3.2.0-beta3.2 and not 3.2.0-beta3.
