    Enclosed printer water cooled motors
    37
    4.1k
    • roiki11undefined
      roiki11 @aprz
      @1997alex said in Enclosed printer water cooled motors:
      @Veti I've looked at the dyze cooling blocks but they only cover a small surface area of the motor.
      Cincinnati uses them in their SAAM HT and they seem to work fine.
      • aprzundefined
        aprz @Veti
        @Veti I ended getting 0.9 degree moons stepper motors and i'm hoping they can withstand the heat. A member on prusa forum did multiple test with moons motors and LDO motors and the moons out performed the LDO motors.
        https://forum.prusaprinters.org/forum/original-prusa-i3-mk3s-mk3-user-mods-octoprint-enclosures-nozzles-.../stepper-motor-upgrades-to-eliminate-vfa-s-vertical-fine-artifacts/
        • jens55undefined
          jens55 @aprz
          @Rushmere3D I've seen that video of his when i was searching for watercooling. His method of cooling is similar to dyze he really did a great job.
          I think his advise is dangerous and irresponsible but maybe that's just me .......
          aprzundefined 1 Reply Last reply Reply Quote 0
          • aprzundefined
            aprz @jens55
            @jens55 hahaha, i suppose.
            • Vetiundefined
              Veti @aprz
              yes i have read that article. heated chamber was not one criteria there though 🙂
              • mrehorstdmdundefined
                mrehorstdmd
                Does the rotor generate its own heat or does it get all its heat from the stators?
                Does applying a heatsink or water jacket to the motor's stators cool the rotor which is separated from the stators by an air gap?
                theruttmeisterundefined 1 Reply Last reply Reply Quote 0
                • theruttmeisterundefined
                  theruttmeister @mrehorstdmd
                  @mrehorstdmd
                  Yes.
                  Resistive losses will convert some of the magnetic flux into heat.
                  But generally things like the insulation and the lubricant in the bearings are the limiting factors (the solder if there is any now I think about it).
                  Most steppers are soft iron for both rotor and stators, iirc, which has a curie temp waaaaay above anything you are going to see.
                  Water cooling is going to protect at least 1 of the bearings and probably the wiring. Its not the most efficient way of doing things, but it works.
                  The next issue, if you are trying to get really hot is belt life. Gates only rate them to 80c iirc.
                  Isolate, substitute, verify.
                  JamesMundefined 1 Reply Last reply Reply Quote 0
                  • JamesMundefined
                    JamesM @theruttmeister
                    @theruttmeister Gates offers high temperature belts rated to 135C
                    https://www.filastruder.com/products/gates-2gt-belts-high-temperature-epdm
                    • whosrdaddyundefined
                      whosrdaddy
                      No need for a peltier to cool the hotend and steppers, A single rad with 120mm fan will exceed all needed cooling capabilities.
                      When I am done with my project, 5 steppers and 4 hotends will be cooled by a single cooling loop, (aiming for 80° chamber temps).
                      I use these on the steppers and do their job.
                        theruttmeister @JamesM
                        @JamesM said in Enclosed printer water cooled motors:
                        And going to 150c (for PEEK) means you need to look at silicone belts 😉
                        Vetiundefined 1 Reply Last reply Reply Quote 1
                        • Vetiundefined
                          Veti @theruttmeister
                          @theruttmeister said in Enclosed printer water cooled motors:
                          might was well go for a ball screw based system then.
                          • Nuramoriundefined
                            Nuramori
                            I am simply adding a water cooling loop and blocks at the motors.
                              A Former User @Veti
                              @Veti said in Enclosed printer water cooled motors:
                              how would you run ball screws on a Core-XY ?
                              And as i already said i am going for the simplest method of all, placing the motors outside the chamber (no active cooling required) and using high temp belts, i wont be printing peek
                              • Vetiundefined
                                Veti @A Former User
                                @CaLviNx said in Enclosed printer water cooled motors:
                                you cant, it would be a Cartesian printer.
                                see this as an example
                                https://www.thingiverse.com/thing:2929869
