    Duet 3 Mini 5+ : Initial announcement
    288
    31.0k
    • whopping pochardundefined
      whopping pochard
      Gentlepersons, start your engines! ๐Ÿ˜„
      Ok, time to start thinking seriously about printer I need to build next so as to justify one of these...
      Chrissundefined 1 Reply Last reply Reply Quote 0
      • Chrissundefined
        Chriss @whopping pochard
        @whopping-pochard The engine is running at 6k rpm since 2 month already. The frame is ready, the extrudors are on there way.... You are a bit behind... ๐Ÿ˜„
        • elmoretundefined
          elmoret
          Just got them in:
          https://www.filastruder.com/products/duet-3-mini-5?_pos=1&_sid=5b64cc6b9&_ss=r
          • oliofundefined
            oliof
            Now to wait for a European reseller to stock them (-:
            • Chrissundefined
              Chriss @oliof
              @oliof Me too. I hope that E3D will list them soon.
              I would not like to parcel something from overseas, tat will be to much tax hazel. I hope that E3D will ship before we see the hard brexit ...
              elmoretundefined 1 Reply Last reply Reply Quote 0
              • Mosherundefined
                Mosher
                What about the driver extension boards for mini 5+, when will these boards will be available? As i will be installing it on Voron V2, i need 7 drivers.
                  T3P3Tony administrators @Mosher
                  @Mosher January. We have everything ready to go at the assembler, they many even start before they break for Christmas and New year's
                  Mosherundefined 1 Reply Last reply Reply Quote 0
                  • Mosherundefined
                    Mosher @T3P3Tony
                    @T3P3Tony is it like maestro expansion board? With 2 TMC2209s? Can i read about it somewhere?
                    Thank you
                    • elmoretundefined
                      elmoret @Chriss
                      @Chriss E3D plans to list on Monday
                      Chrissundefined 1 Reply Last reply Reply Quote 1
                      • Chrissundefined
                        Chriss @elmoret
                        @elmoret Thanks for the update! I can stop the frequent refresh on there website than. ๐Ÿ˜‰
                        I hope that it will path the boarder before the brexit than.
                        • Chrissundefined
                          Chriss @Chriss
                          I hope that they are still counting there stock:
                            Yes they have not put the stock up yet!
                            • oc_geekundefined
                              oc_geek
                              Hi i would have a question on the expansion card(s) for the Mini 5+
                              Have to run 7x Drivers so i'm i getting it right that i would need 2x Duet 3 Toolboards (via CAN) ?
                              EDIT: i found the answer in the electrical connection documentation -> Mini 2+ expansion card
                                A Former User
                                Is there already information how many DHTยดs will be supported? I suspect that is related to the number of SPI that are accessible? Regards, Lucas
                                • Thaliosundefined
                                  Thalios
                                  Should get mine dec 31st from filastruder.com.
                                  It will go in a Ender 3 Pro stock with BL touch.
                                  I'll try to do a nice writeup and how to.
                                  Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                                  Heavily modified Ender 3 Pro (Duet 3 6HC)
                                  Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                                  CR-10S Pro V2 (Duet 3 Mini 5+)
                                  and a bunch of SLA printers..
                                  lodgerundefined 1 Reply Last reply Reply Quote 0
                                  • lodgerundefined
                                    lodger @Thalios
                                    @Thalios How can you get it in the US before we can get one in the UK...lol . How dare E3d Have a holiday at this time of year......lol
                                      A Former User @lodger
                                      @lodger said in Duet 3 Mini 5+ : Initial announcement:
                                      mine has been sitting in "customs" since the 23rd and i just know it wont arrive before the 1st then they are going to try and shaft me on vat and duty as brexshit came into full play, then the fight begins.
                                      • jchodakowskiundefined
                                        jchodakowski
                                        Is there a board DXF available for creating a mount?
                                          A Former User @jchodakowski
                                          @jchodakowski said in Duet 3 Mini 5+ : Initial announcement:
                                          the dimensions should suffice
                                          jchodakowskiundefined Chrissundefined jbarrosundefined 4 Replies Last reply Reply Quote 1
                                            jchodakowski @A Former User
                                            @CaLviNx thanks!
