    IDEX CoreXY, With Only 2 Motors.
    60
    11.0k
    • oliofundefined
      oliof
      Why don't you build a toolchanger while you are at it? Your idea already basically is one, only the tool stays on the X carriage when parked ....
      • o_lampeundefined
        o_lampe @RichardDuke
        @RichardDuke said in IDEX CoreXY, With Only 2 Motors.:
        The kinematics of this directly correspond to that of Markforged, except at every toolchange, both X and Y motor logic is swapped and reversed.
        Is it possible to do the swap during a tool change? What does the firmware do in that case? There are some restrictions to the stepper parameters, IMHO some require a reboot? @Phaedrux ??
        • RichardDukeundefined
          RichardDuke @fcwilt
          I guess the main idea behind this was to try implement indipendent dual extrusion to an existing platform without heavily modifying the original design. If it works, it would potentially be possible to a second carriage to just about any CoreXY printer.
          @fcwilt yes the Voron is a CoreXY, designed for minimal racking, but with this modification the racking could become an issue as the gantry would now be pulled in the Y direction from opposite ends of the rail. It could potentiality be overcome with alternative belt routing, but that will require a design overhaul, in which case id probably look to just add an extra motor and belt anyway ๐Ÿ˜œ
          @oliof a toolchanger could be an option, the coupling of the tools sound like it could be challenging though. Id probably look to retrofit the e3d carriage and park the tools off the gantry though.
          @o_lampe I have had a conversation with Tony from Duet who doesn't think there will be an issue, but we will cross that path later.
          Richard
          fcwiltundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @RichardDuke
            @RichardDuke
            I wish you hadn't put the idea in my head of converting my MarkForged style printer into a IDEX unit.
            Like I don't already have enough projects! ๐Ÿ˜‰
            Fredereick
            RichardDukeundefined 1 Reply Last reply Reply Quote 0
              RichardDuke @fcwilt
              @fcwilt you and me both! I haven't even finished tuning my recent Cartesian IDEX build and I'm already looking for something else!
              Richard
              • o_lampeundefined
                I disagree.
                The B-belt is passive during Y-moves, but it is still there and it's tension makes all the difference.
                Both ends of the crossbar are wrapped in belts, that's important for the constraint.
                My CoreXY is easy to modify with your idea. I'll print a second carrier-dummy and try it out today.
                I could need some help with the kinematic-matrix.
                • o_lampeundefined
                  o_lampe
                  @ all
                  what would be a good testprint to show (the absence off) racking?
                  • oliofundefined
                    oliof
                    Just to chime in on the alleged h-bot racking -- that all seems to go back to an old Hackaday posting where the author later admitted to using low quality belts and self-made cantilevered pulleys. I am poised to assume the claims about h-bot being terrible are a bit overblown in practice.
                    hackinistratorundefined 1 Reply Last reply Reply Quote 1
                    • hackinistratorundefined
                      hackinistrator @oliof
                      @oliof of course it is .
                      many industrial motion systems use h bot . startasys used hbot in their printers . it all depends how rigid your design is .
                      o_lampeundefined 1 Reply Last reply Reply Quote 3
                      • o_lampeundefined
                        o_lampe @hackinistrator
                        @hackinistrator
                        In this special case it's the equal belt tension that keeps the crossbar in line. Also the tension shouldn't be too low.
                        • o_lampeundefined
                          o_lampe
                          Here's a little teaser of the dummy U-carrier waiting to be connected and mapped.
                          It's an IDEY CoreXY BTW...just in case someone has a clue how to run this.
                          • o_lampeundefined
                            o_lampe
                            I found this in the wiki, but there is also a K11=MarkForge type of kinematics, but no further explanation. I guess it's trial&error time , as usual...
                            CoreXY with extra Markforge U axis (see https://forum.duet3d.com/post/136554 )
                            M669 K1 X1:1:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
                            • o_lampeundefined
                              o_lampe
                              @RichardDuke
                              It's alive ๐Ÿ˜€
                              The kinematic is the same as MarkForge (M669 K11) but I had to modify it, because my crossbeam is the Y-axis.
                              I've called it simple-IDEX or s-idex and linked the video to this thread.
                              Here's a short video with a fixed dummy U-axis.
                              Next I'll fix the Y-axis and work on the reversed kinematic.
                                Phaedrux Moderator @o_lampe
                                @o_lampe said in IDEX CoreXY, With Only 2 Motors.:
                                Nothing requires a reboot to configure. Everything can be done on the fly. The only reason DWC suggests a reboot after changing config.g is so that your changes can be applied. Could also be accomplished by sending M98 P"config.g" to execute the file as a macro.
                                Some changes may have a quality impact if executed during a print, but if done stationary no problems should arise.
                                  RichardDuke @o_lampe
                                  @RichardDuke
                                  It's alive ๐Ÿ˜€
                                  Soooooo..... that is awesome! You're a superstar for testing this out! What an wicked post to wake up too.
                                  I guess I am going to have to start ordering some parts and join in on the SIDEX action!
                                  Richard
                                  • o_lampeundefined
                                    @RichardDuke
                                    Goooooood MORNING!
                                    I thought about the name of the new born baby, maybe locked IDEX describes it better?
                                    I also have found a way to include the lock and a small servo to my X-carriers. Will photoshop the idea for all of us to discuss.
                                    I printed two things yesterday, expecting to see more overshooting at the corners, where the single belt has to catch all the moving mass, but a test cube was practically identical to a formerly printed one.
                                    The second doesn't show any signs of difference, but I'll inspect it again in bright sunlight today. Still unsure how racking would show? Lost steps and screeching carriers?
                                    The only downside is, I was so proud about the small frame with regards to the print area, but now the second carrier eats up a lot of space. Maybe I have to order a few longer 2040 extrusions and reassemble the whole frame.
                                    • o_lampeundefined
                                      o_lampe
                                      Here's the basic idea of a servo-locked carrier. The servo arm should be at top_dead_center when the carrier is locked. This way we can switch it off when not needed.
                                      I'm not sure if the small 9gram servo can pull the PETG-hook away from the carrier, but the other servos I have are 60gram standard servos ready to rip the hook off if necessary ๐Ÿ˜‰
                                      PS: @Phaedrux why are my pictures always rotated 90ยฐ CCW, when I upload them the first time?
                                      The 60gram Servo looks more like it.
                                        T3P3Tony administrators @o_lampe
                                        possibly because they are saved rotated, but your phone "unrotates" them for display?
                                        • 3DPrintingWorldundefined
                                          3DPrintingWorld
                                          I also have a (dual) Markforged printer and to weigh in a little on the racking issue. I agree with @fcwilt, two Y-axis belts is a good idea or you have to have a very ridged bearing setup like on the Mark one.
                                          Notice the solid one piece gantry with two bearing on each end spaced apart to keep it from skewing. This allows them to get away with just one Y-axis drive. Personally I think its better to add another belt to keep it square considering it does not add any moving weight like additional bearings and a heavy gantry. If you want a IDEX though, it makes more sense to double up on the markforged, which will also equal out the racking forces.
                                          I think its a good thought, but I'm not sure I understand the purpose of locking the carriages to save a stepper. You would just be adding more moving weight, as the second motor on a dual markforged is parked on the frame.
                                          You are welcome to check out my project, it might give you some ideas at the very least. https://github.com/3dprintingworld/MULDEX
                                          RichardDukeundefined o_lampeundefined 2 Replies Last reply Reply Quote 1
                                            RichardDuke @3DPrintingWorld
                                            I think the purpose of this would mostly be an effective way to add independent dual extrusion to an existing CoreXY printer, without the need to redesign a lot of key components.
                                            Nice work on Muldex btw, it was the only DIY build IDEX printer I could find, and I do like it, but I thought it would be interesting to see what other options could potentially be possible.
                                            Quite partial to the fixed bed, gantry z movement, and well designed form factor with no wasted space of the Voron, When I started looking over the design, I noticed there was no easy method to add additional belts and motors, not without redesigning all of the major components. Thatโ€™s when I had the idea for a servo lock. Itโ€™s not flash, itโ€™s relatively simple, but I think the concept of having only two motors responsible for the xy movement of two separate carriages, and how the firmware must interact to make it so is very intriguing, and perhaps this will spark other ideas.
                                            I think racking will boil down to how tightly build a gantry design is. Its hard to say without testing, and I dont know how racking would present itself in a print, possibly out of square corners, or misaligned layers. I think the best gauge would just be to see if you can feel for any play when trying to rock the gantry.
                                            Richard
                                            3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
