    IDEX CoreXY, With Only 2 Motors.
    60
    11.0k
    • oliofundefined
      oliof
      Just to chime in on the alleged h-bot racking -- that all seems to go back to an old Hackaday posting where the author later admitted to using low quality belts and self-made cantilevered pulleys. I am poised to assume the claims about h-bot being terrible are a bit overblown in practice.
      hackinistratorundefined 1 Reply Last reply Reply Quote 1
      • hackinistratorundefined
        hackinistrator @oliof
        @oliof of course it is .
        many industrial motion systems use h bot . startasys used hbot in their printers . it all depends how rigid your design is .
        o_lampeundefined 1 Reply Last reply Reply Quote 3
        • o_lampeundefined
          o_lampe @hackinistrator
          @hackinistrator
          In this special case it's the equal belt tension that keeps the crossbar in line. Also the tension shouldn't be too low.
          • o_lampeundefined
            o_lampe
            Here's a little teaser of the dummy U-carrier waiting to be connected and mapped.
            It's an IDEY CoreXY BTW...just in case someone has a clue how to run this.
            • o_lampeundefined
              o_lampe
              I found this in the wiki, but there is also a K11=MarkForge type of kinematics, but no further explanation. I guess it's trial&error time , as usual...
              CoreXY with extra Markforge U axis (see https://forum.duet3d.com/post/136554 )
              M669 K1 X1:1:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
              • o_lampeundefined
                o_lampe
                @RichardDuke
                It's alive πŸ˜€
                The kinematic is the same as MarkForge (M669 K11) but I had to modify it, because my crossbeam is the Y-axis.
                I've called it simple-IDEX or s-idex and linked the video to this thread.
                Here's a short video with a fixed dummy U-axis.
                Next I'll fix the Y-axis and work on the reversed kinematic.
                RichardDukeundefined 1 Reply Last reply Reply Quote 0
                  Phaedrux Moderator @o_lampe
                  @o_lampe said in IDEX CoreXY, With Only 2 Motors.:
                  @RichardDuke said in IDEX CoreXY, With Only 2 Motors.:
                  The kinematics of this directly correspond to that of Markforged, except at every toolchange, both X and Y motor logic is swapped and reversed.
                  Is it possible to do the swap during a tool change? What does the firmware do in that case? There are some restrictions to the stepper parameters, IMHO some require a reboot? @Phaedrux ??
                  Nothing requires a reboot to configure. Everything can be done on the fly. The only reason DWC suggests a reboot after changing config.g is so that your changes can be applied. Could also be accomplished by sending M98 P"config.g" to execute the file as a macro.
                  Some changes may have a quality impact if executed during a print, but if done stationary no problems should arise.
                  • RichardDukeundefined
                    RichardDuke @o_lampe
                    @RichardDuke
                    It's alive πŸ˜€
                    Soooooo..... that is awesome! You're a superstar for testing this out! What an wicked post to wake up too.
                    I guess I am going to have to start ordering some parts and join in on the SIDEX action!
                    Richard
                    • o_lampeundefined
                      o_lampe @RichardDuke
                      @RichardDuke
                      Goooooood MORNING!
                      I thought about the name of the new born baby, maybe locked IDEX describes it better?
                      I also have found a way to include the lock and a small servo to my X-carriers. Will photoshop the idea for all of us to discuss.
                      I printed two things yesterday, expecting to see more overshooting at the corners, where the single belt has to catch all the moving mass, but a test cube was practically identical to a formerly printed one.
                      The second doesn't show any signs of difference, but I'll inspect it again in bright sunlight today. Still unsure how racking would show? Lost steps and screeching carriers?
                      The only downside is, I was so proud about the small frame with regards to the print area, but now the second carrier eats up a lot of space. Maybe I have to order a few longer 2040 extrusions and reassemble the whole frame.
                      • o_lampeundefined
                        o_lampe
                        Here's the basic idea of a servo-locked carrier. The servo arm should be at top_dead_center when the carrier is locked. This way we can switch it off when not needed.
                        I'm not sure if the small 9gram servo can pull the PETG-hook away from the carrier, but the other servos I have are 60gram standard servos ready to rip the hook off if necessary πŸ˜‰
                        PS: @Phaedrux why are my pictures always rotated 90Β° CCW, when I upload them the first time?
                        The 60gram Servo looks more like it.
                          T3P3Tony administrators @o_lampe
                          possibly because they are saved rotated, but your phone "unrotates" them for display?
                          • 3DPrintingWorldundefined
                            3DPrintingWorld
                            I also have a (dual) Markforged printer and to weigh in a little on the racking issue. I agree with @fcwilt, two Y-axis belts is a good idea or you have to have a very ridged bearing setup like on the Mark one.
                            Notice the solid one piece gantry with two bearing on each end spaced apart to keep it from skewing. This allows them to get away with just one Y-axis drive. Personally I think its better to add another belt to keep it square considering it does not add any moving weight like additional bearings and a heavy gantry. If you want a IDEX though, it makes more sense to double up on the markforged, which will also equal out the racking forces.
                            I think its a good thought, but I'm not sure I understand the purpose of locking the carriages to save a stepper. You would just be adding more moving weight, as the second motor on a dual markforged is parked on the frame.
                            You are welcome to check out my project, it might give you some ideas at the very least. https://github.com/3dprintingworld/MULDEX
                            RichardDukeundefined o_lampeundefined 2 Replies Last reply Reply Quote 1
                              RichardDuke @3DPrintingWorld
                              I think the purpose of this would mostly be an effective way to add independent dual extrusion to an existing CoreXY printer, without the need to redesign a lot of key components.
                              Nice work on Muldex btw, it was the only DIY build IDEX printer I could find, and I do like it, but I thought it would be interesting to see what other options could potentially be possible.
                              Quite partial to the fixed bed, gantry z movement, and well designed form factor with no wasted space of the Voron, When I started looking over the design, I noticed there was no easy method to add additional belts and motors, not without redesigning all of the major components. That’s when I had the idea for a servo lock. It’s not flash, it’s relatively simple, but I think the concept of having only two motors responsible for the xy movement of two separate carriages, and how the firmware must interact to make it so is very intriguing, and perhaps this will spark other ideas.
                              I think racking will boil down to how tightly build a gantry design is. Its hard to say without testing, and I dont know how racking would present itself in a print, possibly out of square corners, or misaligned layers. I think the best gauge would just be to see if you can feel for any play when trying to rock the gantry.
                              Richard
                              3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
                                3DPrintingWorld @RichardDuke
                                @RichardDuke Got it, I love the thought. I would love to see what you come up with.
                                BTW... Have you thought about swamping carriages, maybe it would fit your application better? You park a carriage at each end of X axis gantry. Then your tool can pick up either carriage. This might be easier to incorporate into an existing corexy design.
                                  @3DPrintingWorld
                                  It has crossed my mind, but it would require a coupler that was fairly acurate. I think I would probably end up with a result much like the toolchanger and park the tools off the carriage instead.
                                  It just seemed so easy to throw on another carriage without much modification!
                                  Richard
                                  3DPrintingWorldundefined denisvdbundefined 2 Replies Last reply Reply Quote 0
                                    @RichardDuke Seems simple enough, I guess you never know for sure unless you try!
                                    • o_lampeundefined
                                      o_lampe
                                      @RichardDuke
                                      In case of the Voron it seems, you'd fit the whole extruder with only two screws to the carrier? You would loose the screws, that otherwise hold the belt-clamp.
                                      Is there a way to use countersunk screws, like I did?
                                      I'm trying to find a way to switch the locks without servos.
                                      Just by moving against the far end of the printer, both carriers would simultanously push a springloaded switch, that toggles their lock/unlock hooks. Not sure yet, how to do this but it's there
                                      RichardDukeundefined 2 Replies Last reply Reply Quote 0
                                        @o_lampe I have redesigned it so there are two cap screws and 2 c/sunk screws. The c/sunk ones are just hiding behind the belts. There is also an additional linear rail on the underside of the 2020 extrusion so in total, 8 bolts per carriage, a bit extreme. Edited* the belt clamps are secured with seperate bolts that run parallel to the gantry. They are not shown in the image, but it all still fits.
                                        I too have been thinking about alternative locking mechanisms. I think the most ideal solution will be some kind of bushing in the carriage, that a machined shaft is inserted into to pin it in place. Its going to be crucial that the parked carriage has no movement otherwise this will translate into the print quality.
                                        I have been scouring AliExpress for various bits of hardware that could be potential candidates but struggling to find something suitable. I did come across some small form 12v door latch solenoids that I liked the idea of, but I would be positive the solenoid pin will have some amount of play.
                                        I figure if you can have 2 servos, latch/unlatch the carriages, you should be able to rig both latches to a single central servo with some actuator rods ect. But your idea of a full mechanical solution is a neat idea, I will have to give it some more thought, I’m not sure if it’s possible though as there will likely be a moment where both carriages must simultaneously move together which would likely loose the Y position, although this could be rectified with a home between tool change.
                                        Richard
                                          You know what, I have done some finger paintings on my phone in bed, which I am not quite prepared to publish haha, but I think this may actually be possible. I will sketch something better in the morning
                                          Richard
                                          • o_lampeundefined
                                            Keep your hands over the blanket they say πŸ˜‰
                                            Here's a first design to play with. Needs some beefing up, but the springloaded steelball snaps the switch nicely from one side to the other. And the springload is not important for the lock, just to make sure it stays in place.open_lock.jpg closed_lock.jpg
                                            I agree with the need for absolute locking. My idea is to add another (strong) spring that pushes the carrier against the hook. I already found the place for the spring in my design, but have no spring that fits.
                                            The parking procedure is:
                                            • move the carrier against the limit and a bit beyond
                                            • move the whole beam towards the far end of the printer
                                            • toggle the lock(s) by pushing the switch into the toggler (not designed yet)
                                            • change the kinematics and continue printing
