    Independently leveled Z axis Issue
    6.7k
    • 3DPrintingWorldundefined
      3DPrintingWorld @mrenz999
      @mrenz999 The BLV is very nice! 👍
      That's the part that throws me, how is it possible that you can switch the motors but it still corrects to the same plane....
      I think I'm just going to have to bite the bullet and try a new boards, I'm running out of ideas.
      fcwiltundefined mrenz999undefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @martin7404
        @martin7404 said in Independently leveled Z axis Issue:
        It is sorted in wierd way , new board is on the way
        PS it is not sorted U is moving during printing with X even all the X,Yand U motors are now on DUEX
        Well having the Z steppers on the Duex wasn't part of the problem in the first place.
        • fcwiltundefined
          fcwilt @3DPrintingWorld
          @3DPrintingWorld said in Independently leveled Z axis Issue:
          How about doing G29 with just a 4 point grid covering most of the bed and posting a screen snap of the height map?
          It's possible to level the bed as far as the 2, 3 or 4 points controlled by the steppers and still have twist to the bed.
          A 4 point height map will reveal such twist.
          • mrenz999undefined
            mrenz999 @3DPrintingWorld
            @3DPrintingWorld The interesting part is we are both having the same weird twist in the same direction. Very weird to me.
            • fcwiltundefined
              fcwilt @mrenz999
              @mrenz999 said in Independently leveled Z axis Issue:
              Can you also create a 4 point height map covering most of the bed and post a screen shot of it here?
              • mrenz999undefined
                mrenz999 @fcwilt
                @fcwilt Sure. I will do that in the next 15 - 20 mins
                • mrenz999undefined
                  mrenz999 @fcwilt
                  @fcwilt What is the correct procedure for getting a 4 point height map ? 410x410 Bed ? lol
                  • fcwiltundefined
                    fcwilt @mrenz999
                    Great.
                    I have a MarkForged style printer with 3 Z steppers and even though the leveling appeared to work the 4 point height map still showed a "twist" along the X axis.
                    It turned out the the Y rails (left and right) were not in the same plane which gave the appearance of the bed being "twisted" - which it wasn't.
                    • mrenz999undefined
                      mrenz999
                      Measuring the bed to nozzle it appears and is without question twisted. But if you tell me how to do a 4 point height map I will do one now.
                      • fcwiltundefined
                        fcwilt @mrenz999
                        On my printer where X=0 and Y=0 is at the center of the 300 x 300 bed I used something like this:
                        M557 X-130:130 Y-130:130 P2:2 ; define 4 point mesh for G29
                        Your values will depend on the X and Y offsets of your probe and the min/max values of your X and Y axes. Just try to keep the probe area centered on the bed.
                        mrenz999undefined 3DPrintingWorldundefined 2 Replies Last reply Reply Quote 0
                        • mrenz999undefined
                          mrenz999 @fcwilt
                            3DPrintingWorld @fcwilt
                            Thanks @fcwilt, think you finally helped me realize my issue. Only four points makes the map much easier to understand.
                            When I first ran the mesh the left back corner was really low. I have a glass plate on top of a sheet magnet. I am only using glass because I wanted to verify the bed was flat.
                            I'm clipping down the bed in the back center left and front center right. I moved both clips to center right and reran the mesh and the low corner goes away!
                            Upon further inspection of the magnetic sheet shows small cracks where it starts to turn blue in the first map. I think these crack are causing the issue. I'll remove the magnet an put the glass directly on the bed tomorrow and give it a try.
                            mrenz999undefined 1 Reply Last reply Reply Quote 1
                            • mrenz999undefined
                              @3DPrintingWorld In your bed.g do you have it do multiple probes per point ? If so how do you accomplish that ?
                              fcwiltundefined 3DPrintingWorldundefined 2 Replies Last reply Reply Quote 0
                              • fcwiltundefined
                                fcwilt @mrenz999
                                @mrenz999 Thanks.
                                The is an extreme version of what my height map looked like.
                                Is this what the frame of your printer looks like?
                                • mrenz999undefined
                                  mrenz999
                                  Yes thats the one 🙂 Except I have 3 z motors. 2 on the right side and 1 on the left
                                  • fcwiltundefined
                                    fcwilt @mrenz999
                                    Read up about the A and S parameters of M558.
                                    If A = 10 and S=0.01 the process will probe each point up to 10 times trying to get two consecutive readings with 0.01.
                                    If it fails to do that it will average all 10 readings.
                                    mrenz999undefined 1 Reply Last reply Reply Quote 0
                                    • mrenz999undefined
                                      mrenz999 @fcwilt
                                      @fcwilt Perfect. Thank you. Does it matter where in the M558 I put that ?
                                      • fcwiltundefined
                                        fcwilt @mrenz999
                                        And the linear guides are on the underside of the top most frame pieces?
                                        • fcwiltundefined
                                          fcwilt @mrenz999
                                          No just add them to your current M558 command.
                                          • mrenz999undefined
                                            mrenz999 @fcwilt
