Independently leveled Z axis Issue
6.8k
    mrenz999
    Measuring the bed to nozzle it appears and is without question twisted. But if you tell me how to do a 4 point height map I will do one now.
      fcwilt @mrenz999
      @mrenz999 said in Independently leveled Z axis Issue:
      @fcwilt What is the correct procedure for getting a 4 point height map ? 410x410 Bed ? lol
      On my printer where X=0 and Y=0 is at the center of the 300 x 300 bed I used something like this:
      M557 X-130:130 Y-130:130 P2:2 ; define 4 point mesh for G29
      Your values will depend on the X and Y offsets of your probe and the min/max values of your X and Y axes. Just try to keep the probe area centered on the bed.
      undefined undefined 2 Replies Last reply 9 Mar 2021, 01:33 Reply Quote 0
        mrenz999 @fcwilt
        undefined 1 Reply Last reply 9 Mar 2021, 01:46 Reply Quote 0
          3DPrintingWorld @fcwilt
          Thanks @fcwilt, think you finally helped me realize my issue. Only four points makes the map much easier to understand.
          When I first ran the mesh the left back corner was really low. I have a glass plate on top of a sheet magnet. I am only using glass because I wanted to verify the bed was flat.
          I'm clipping down the bed in the back center left and front center right. I moved both clips to center right and reran the mesh and the low corner goes away!
          Upon further inspection of the magnetic sheet shows small cracks where it starts to turn blue in the first map. I think these crack are causing the issue. I'll remove the magnet an put the glass directly on the bed tomorrow and give it a try.
          undefined 1 Reply Last reply 9 Mar 2021, 01:39 Reply Quote 1
            mrenz999 @3DPrintingWorld
            @3DPrintingWorld In your bed.g do you have it do multiple probes per point ? If so how do you accomplish that ?
            undefined undefined 2 Replies Last reply 9 Mar 2021, 01:48 Reply Quote 0
              fcwilt @mrenz999
              @mrenz999 Thanks.
              The is an extreme version of what my height map looked like.
              Is this what the frame of your printer looks like?
                mrenz999
                Yes thats the one 🙂 Except I have 3 z motors. 2 on the right side and 1 on the left
                undefined 1 Reply Last reply 9 Mar 2021, 01:49 Reply Quote 0
                  fcwilt @mrenz999
                  Read up about the A and S parameters of M558.
                  If A = 10 and S=0.01 the process will probe each point up to 10 times trying to get two consecutive readings with 0.01.
                  If it fails to do that it will average all 10 readings.
                    mrenz999 @fcwilt
                    @fcwilt Perfect. Thank you. Does it matter where in the M558 I put that ?
                    undefined 1 Reply Last reply 9 Mar 2021, 01:50 Reply Quote 0
                      fcwilt @mrenz999
                      And the linear guides are on the underside of the top most frame pieces?
                        fcwilt @mrenz999
                        No just add them to your current M558 command.
                        undefined 1 Reply Last reply 9 Mar 2021, 01:51 Reply Quote 0
                          mrenz999 @fcwilt
                          undefined undefined 2 Replies Last reply 9 Mar 2021, 01:53 Reply Quote 0
                            fcwilt @mrenz999
                            @mrenz999
                            Sorry but I cannot tell where they are from that picture - I may be looking right at them and just not seeing them.
                            So where are the left and right linear guides mounted?
                            undefined 1 Reply Last reply 9 Mar 2021, 01:55 Reply Quote 0
                              mrenz999 @fcwilt
                              @fcwilt So the left one is in the middle of the bed on the X axis. The 2 on the right are at the corners of the bed frame. The bed frame sits on the attachment to the linear guide mounts
                              undefined 1 Reply Last reply 9 Mar 2021, 01:56 Reply Quote 0
                                fcwilt @mrenz999
                                Sorry I was not clear - I meant the Y axis guides - the ones running front to back on each side.
                                undefined 1 Reply Last reply 9 Mar 2021, 01:58 Reply Quote 0
                                  mrenz999 @fcwilt
                                  @fcwilt gotcha. The are underneath
                                  undefined 1 Reply Last reply 9 Mar 2021, 02:05 Reply Quote 0
                                    3DPrintingWorld @mrenz999
                                    I created a macro that heats the bed, calls out the mesh, homes, does the mesh, saves the mesh, then turns the bed off. I started at 10:10, then S= was my max travel minus 10. Plus you have to add/subtract your probe to nozzle offset.
                                    M140 S60
                                    M557 X10:365 Y10:290 S300:270
                                    G28
                                    G29 S0
                                    G29 S3
                                    M140 S0
                                    undefined 1 Reply Last reply 9 Mar 2021, 02:07 Reply Quote 0
                                      fcwilt @mrenz999
                                      @mrenz999
                                      Great.
                                      Did you print out those "tools" designed to help align the frame pieces?
                                      I didn't have such tools and after seeing my 4 point height map I realized that my left and right Y axis guides were not in the same plane meaning the frame pieces were not in the same plane.
                                      I closely examined the left and right frame pieces where they joined the four vertical pieces at the top and found that they were at slightly different heights, with the left piece being low in the rear and right piece being high in the front.
                                      We are talking fractions of a mm but it was enough to generate a "twisted" height map - though not as bad as yours.
                                      Perhaps you are having the same problem.
                                        @mrenz999
                                        Looks like one of your bearings is not attached?
                                        ![0_1615255538626_bearing.png](Uploading 100%)
                                          mrenz999 @fcwilt
                                          @fcwilt Perhaps. I did print the tool but things move so I will recheck them.
                                          Is there a way to add the a and s parameter to your bed.g when doing the leveling so it does multiple probes ?
                                          undefined 1 Reply Last reply 9 Mar 2021, 02:09 Reply Quote 0
                                          78 out of 113
