    Duet2 ethernet and 12864 display using ST7567
    42
    3.8k
    • rilotundefined
      rilot
      OK, I got it working apart from the backlight. I'm guessing that the DuetWifi doesn't support the NEOPixel RGB. We have a connection for it though in the pinout for connecting the Mini 12864.
        droftarts administrators @rilot
        @rilot can you control it using M150? This from the Duet 3 Mini 5+ section:
        When using a version 2.1 controller, the colours of the three Neopixel LEDs built into the display can be set using the M150 command with LED type parameter X2.
        rilotundefined CNCModellerundefined 2 Replies Last reply Reply Quote 0
        • rilotundefined
          rilot @droftarts
          @droftarts I'm using a Duet2Wifi and M150 results in a Command not supported error. This is with 3.2.2
          CNCModellerundefined 1 Reply Last reply Reply Quote 0
          • CNCModellerundefined
            CNCModeller @rilot
            @rilot said in Duet2 ethernet and 12864 display using ST7567:
            Same here on Duet Ethernet... no baclight and M150 "Command Not Supported"
            At least its working, I can now look at a custom menu set.
            I built a little connector conversion board to address custom the loom requirements, see below.
            Thanks for the help folks 🙂
            Cheers
            BPM
            Polar Duet3 Mini + 1HCL
            https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
            Wanhao D4S: Duet2
            https://forum.duet3d.com/post/296755
            K40 Laser, Duet2
            https://forum.duet3d.com/post/312082
            Wanhao D5S
            https://www.youtube.com/CNCModellerUK
              CNCModeller @droftarts
              @droftarts @dc42
              Hi guys, it there any information on @rilot and my issue re Duet Ethernet / WiFi and the 12864 display doesn't have a working backlight and M150 "Command Not Supported".
              Any thoughts would be much appreciated.
              All the best
              Barry M
              Wanhao D4S: Duet2
              K40 Laser, Duet2
              Wanhao D5S
              • fulgundefined
                fulg
                @cncmodeller M150 is not supported on Duet2 due to lack of memory. There are some details in this thread but it is hard to follow. That thread specifically says V2.1 of the display (the one with a NeoPixel) does not work on Duet2.
                I can confirm a Fysetc V1.2 12864 display works on Duet2 with RRF 3.2.2, you just need a custom wiring loom. I have since moved on to a Mini5+ where the V2.1 is natively supported.
                VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                CNCModellerundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
                  CNCModeller @fulg
                  @fulg said in Duet2 ethernet and 12864 display using ST7567:
                  Thanks for the heads up.
                  As I've got one of the 2.1 displays now, perhaps I can drive the neopixel from a separate Arduino using the neopixel library? I just want a backlight running.
                  If so do we know which pin is the neopixel data pin? It's not obvious to me from the fysetc page.
                  http://wiki.fysetc.com/Mini12864_Panel/
                  Many thanks
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                  gloomyandyundefined 1 Reply Last reply Reply Quote 0
                  • gloomyandyundefined
                    gloomyandy @CNCModeller
                    @cncmodeller The schematic for the display is here: https://github.com/FYSETC/FYSETC-Mini-12864-Panel/blob/master/hardware/V2.1/Mini12864(RGB)V2.1_sch.pdf
                    Looks like the Neopixel control signal is the "Red" pin 5 on EXP1
                      CNCModeller @gloomyandy
                      @gloomyandy said in Duet2 ethernet and 12864 display using ST7567:
                      Thanks @gloomyandy I'll give it a go and report back.
                      Wanhao D4S: Duet2
                      K40 Laser, Duet2
                      Wanhao D5S
                      • o_lampeundefined
                        o_lampe @fulg
                        This statement frightens me. I'm planning on writting big(ger) meta command macros for Duet2.
                        Now I'm afraid they don't fit....or is the Neopixel library so huge?
                          droftarts administrators @o_lampe
                          @o_lampe it’s running out of flash ROM space for the firmware, not RAM. Your macros should be fine.
                          @CNCModeller I have asked @dc42 if he can add Neopixel support to Duet 2; the other forum post suggested he was going to look into it, and I don’t see a reply about lacking memory (though I know it is tight). If it isn’t possible, I’ll update the documentation to say that only boards with single colour backlight (ie v1.2 of Fysetc 12864 LCD) are supported.
                            @droftarts thanks for the update! It's usable now but not great. I'll hang on for an update from @dc42 but can always fall back on a separate Arduino if required.
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
                            rilotundefined 1 Reply Last reply Reply Quote 0
                            • rilotundefined
                              rilot @CNCModeller
                              @cncmodeller I'm using a seperate Arduino to drive the backlight. Works fine.
                                CNCModeller @rilot
                                @rilot good to know, thanks.
                                Wanhao D4S: Duet2
                                K40 Laser, Duet2
                                Wanhao D5S
                                • o_lampeundefined
                                  o_lampe @rilot
                                  I have some ATMega44 chips soldered on a small SOP16 PCB(*), would they be powerful enough to drive the Neopixel?
                                  Can you compile your program with Atmega44 selected?
                                  Does it switch the backlight on/off, when I push the button on the LCD?
                                  *) It's the green PCB (Pololu stepper driver footprint)
                                  • Topherundefined
                                    Topher
                                    I just picked up a Mini5+. Sticker on the back says V1.0 and connected to the Fysetc 12864 display with included 2811 RGB drivers. After adding M918 P2 E2 and M150 X1 Q3000000 to my config file, the LCD works just fine, but nothing on the side of M150 controlling the screens LED's. Any ideas?
                                      jay_s_uk @Topher
                                      @leckietech
                                      Which firmware?
                                      And which version of fysetc screen?
                                      Topherundefined 1 Reply Last reply Reply Quote 0
                                        Firmware 3.3beta3 will support a short string of Neopixels on Duet WiFi and Ethernet.
                                        • Topherundefined
                                          Topher @dc42
                                          @dc42 said in Duet2 ethernet and 12864 display using ST7567:
                                          I will give this a try when I get to work tomorrow, thanks. Will this firmware allow the M300 to play tones with wifi2? Currently, it just sends DC out to the piezo for the set duration but no oscillation.
                                          • Topherundefined
                                            Topher @jay_s_uk
                                            @jay_s_uk said in Duet2 ethernet and 12864 display using ST7567:
                                            @leckietech
                                            Which firmware?
                                            Im running RRF 3.2.2 with 12864 display using ST7567 and its got 3 on board 2811 drivers:
                                            https://www.aliexpress.com/item/32862853197.html?spm=a2g0s.9042311.0.0.5d614c4doODGv6
