    Z axis: ball screws vs belts
    3D Printing General Chat
    15
    40
    7.2k
    • Dad003undefined
      Dad003
      to get good quality you will have ot spend a lot for a good ballscrew , belt is cheaper but platform will go down when not powered , i went from cheap leadscrew to belt and belt made my printer 1000x better on Z for quality
      fmaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • fmaundefined
        fma @fulg
        @fulg said in Z axis: ball screws vs belts:
        On an unrelated note: I think I remember you from the ORDBot days, do I? 😉
        Yes! What a memory!!!
        Frédéric
        • fmaundefined
          fma @Dad003
          @dad003 said in Z axis: ball screws vs belts:
          Good to read that!
          Frédéric
          timcurtis67undefined 1 Reply Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @Dad003
            Not necessarily. I have 3 Z steppers with 5 to 1 integral planetary gear boxes. The bed does not drop when power is removed.
            Dad003undefined 1 Reply Last reply Reply Quote 0
            • Dad003undefined
              Dad003 @fcwilt
              @fcwilt i have 2x60mm nema 17 in a pulley box going from 20>60:20>60 , but i know my platform that hold the bed is heavy which is why it goes down when off
              • timcurtis67undefined
                timcurtis67 @fma
                @fma
                I have a 450mm X 450mm bed (.250" thick) on 2 lead screws with 8mm travel per revolution. They are the 4 start style lead screws. I drive it with a nema 23 stepper.
                No issues with the bed dropping when the power is off but I can push it down with some slight pressure.
                • mrehorstdmdundefined
                  mrehorstdmd @timcurtis67
                  The 30:1 worm gear reducer stops the 3.5 kg bed assembly (tested to 4kg additional load) in my printer from dropping when power is off, and I can't make it drop by pushing down on it. It has one motor, driven by the Duet board driver, and two belts that do the lifting. Worm gears FTW! There are no sync issues, and the bed is in in tram at all times. No sensors, no extra motor drivers, no extra wiring, no configuration issues. It all "just works" every time. The only downside is that I can't make youtube videos of it. There's just no excitement at all...
                  o_lampeundefined zaptaundefined 2 Replies Last reply Reply Quote 1
                  • o_lampeundefined
                    o_lampe @mrehorstdmd
                    @mrehorstdmd
                    I remember your worm drive was quite expensive and not easy to get outside U.S.
                    What was it's name? Rhino-something...
                    • zaptaundefined
                      zapta @mrehorstdmd
                      @mrehorstdmd said in Z axis: ball screws vs belts:
                      no extra wiring...
                      It was replaced with extra belting. 😉
                        mrehorstdmd @o_lampe
                        @o_lampe https://www.ebay.com/itm/Rino-Motorized-Rotary-Table-Stage-CNC-4th-Axis-Sherline-Milling-Engraver-Router/191714031261?epid=711126295&hash=item2ca30bf69d:g:A7UAAOSwPhdVB2f0
                        $108 shipped. You get the motor and worm drive already integrated. Compare that to the cost of a motor and brake, or buying a motor and separate gear box. This type seems to work fine, too, and can be bought via aliexpress in whatever country you're in: https://www.ebay.com/itm/NEMA17-Turbine-Worm-Gear-Stepper-motor-Hybrid-2-Phase-4-wires/324001642095?hash=item4b7000b66f:g:HTMAAOSwEGVd50j1
                        @zapta Yes, belts instead of wires and connectors. How often have you heard of wiring problems vs how often have you heard of belts failing? I suppose ineptitude in wiring can translate to ineptitude in mechanics, so they're probably even by that measure.
                        • zaptaundefined
                          zapta @mrehorstdmd
                          Chances are your printer has many more wires than belts so more room for failure. 😉
                          BTW, I just started to collect parts for a Voron V2.4. If I got it correctly, the design has 8 (eight) belts and 16 puleys/idlers just for the Z movement, so belting can be fun.
                          • tech-ratonundefined
                            tech-raton
                            I went the other route, with belts and counterweights...
                            1 kilo per belt.
                            Works nicely, no more falling without power.
                            I used brake cable for bike with wheels because the tubing had too much friction.
                            • zaptaundefined
                              zapta @tech-raton
                              It seems that belted Z is gaining traction in the desktop 3D printers world. For example, the Voron Switchwire, a bed slinger, uses a coreXY configuration for the X/Z plane, and then, not to mention the deltas.
                                mrehorstdmd @zapta
                                @zapta Wow! 8 belts to move Z! That's terrific, but wouldn't 10 be even better?
                                @tech-raton It's got a very steam-punk look to it!
                                tech-ratonundefined 1 Reply Last reply Reply Quote 0
                                • fmaundefined
                                  fma
                                  Does small gaz cylinders exist, like for car rear tail-board?
                                  Frédéric
                                    tech-raton @mrehorstdmd
                                    @mrehorstdmd
                                    The tubing isn't copper in my watercooling, but it will be...
                                    But i need to find a way to solve the galvanic corrosion.
                                    @fma said in Z axis: ball screws vs belts:
                                    Yep, you can find these in any length, but their power is different along the length.
                                    Think of them like a spring.
                                    • o_lampeundefined
                                      o_lampe @tech-raton
                                      @tech-raton said in Z axis: ball screws vs belts:
                                      Why not take brass instead? That's ~70% copper, without corrosion.
                                        tech-raton @o_lampe
                                        @o_lampe
                                        Copper tubing is easier to find than brass tube...
