    Z axis: ball screws vs belts
    3D Printing General Chat
    15
    40
    7.2k
    • o_lampeundefined
      o_lampe @3DPMicro
      @3dpmicro said in Z axis: ball screws vs belts:
      And lastly it's good practice to consider using whole steps when setting resolution as micro stepping once was shown to be far from accurate. Maybe that's changed with the new drivers in the last few years but I doubt the motors have.
      The counterweight idea is interesting.
      I'm using a mix of 3x cheap ballscrews and a belt reduction with a single motor. The bed never drops, but I have 2500steps/mm at 16:1 microstepping. I'm sure, with three motors, it will not drop either with belt reduction or without.
      I reduced u-stepping to 4:1 once but than the mesh-leveling moves of the Z-motor turned from the common sizzling/hissing sound to farting.
      3DPMicroundefined 1 Reply Last reply Reply Quote 0
      • 3DPMicroundefined
        3DPMicro @o_lampe
        @o_lampe what is the lead on your ballscrews?
        Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        • o_lampeundefined
          o_lampe @3DPMicro
          @3dpmicro
          1204 from robotdigg
          • cdl1701yahoo.comundefined
            cdl1701yahoo.com @mrehorstdmd
            @mrehorstdmd I am using ball screws with a 300x300x10 bed and they do not drop when the motors are disengaged, but, the bed does move easily when pressed with I would say about a pounds worth of pressure.
            • 3DPMicroundefined
              3DPMicro @cdl1701yahoo.com
              @cdl1701yahoo-com how many ballscrews and what is the lead?
              • fmaundefined
                fma @sebkritikel
                @sebkritikel said in Z axis: ball screws vs belts:
                I believe your next problem will be potentially destroying a driver on your board from the back EMF.
                I never destroyed a driver, even by moving hard the gantry.
                Have a look at this vidéo (from quebec): https://www.youtube.com/watch?v=PCpfXJV89WA
                Frédéric
                • fulgundefined
                  fulg
                  @fma said in Z axis: ball screws vs belts:
                  It depends on your driver... Twice I have killed a TMC2100 by moving an axis while unpowered (and not fast either). Granted those were the old Waterott boards, you can buy an extra board to protect them now.
                  I have not blown a driver otherwise, and not for lack of trying. But it can happen (if rarely) depending on your hardware.
                  On an unrelated note: I think I remember you from the ORDBot days, do I? 😉
                  VORON V2 CoreXY + Duet3 Mini5+ Ethernet v1.0 with Mini2+ expansion, VORON V0 CoreXY + Duet2 Maestro
                  zaptaundefined fmaundefined 2 Replies Last reply Reply Quote 0
                  • zaptaundefined
                    zapta @fulg
                    @fulg said in Z axis: ball screws vs belts:
                    Some boards such as SKR use small driver modules that can be easily replaced with no tools. Not as elegant and dense but functional.
                    fulgundefined 1 Reply Last reply Reply Quote 0
                    • fulgundefined
                      fulg @zapta
                      @zapta I believe Waterott was actually the first provider of Trinamic drivers in Pololu Stepstick form-factor (with the chip on the back side so you could put the heatsink on the correct side of the PCB!), but the lack of physical space means no protection diodes. They are easy to replace but they are also quite fragile, at least the TMC2100 model.
                      • Dad003undefined
                        Dad003
                        to get good quality you will have ot spend a lot for a good ballscrew , belt is cheaper but platform will go down when not powered , i went from cheap leadscrew to belt and belt made my printer 1000x better on Z for quality
                        fmaundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                        • fmaundefined
                          fma @fulg
                          Yes! What a memory!!!
                          Frédéric
                          • fmaundefined
                            fma @Dad003
                            @dad003 said in Z axis: ball screws vs belts:
                            Good to read that!
                            Frédéric
                            timcurtis67undefined 1 Reply Last reply Reply Quote 0
                            • fcwiltundefined
                              fcwilt @Dad003
                              Not necessarily. I have 3 Z steppers with 5 to 1 integral planetary gear boxes. The bed does not drop when power is removed.
                              Dad003undefined 1 Reply Last reply Reply Quote 0
                              • Dad003undefined
                                Dad003 @fcwilt
                                @fcwilt i have 2x60mm nema 17 in a pulley box going from 20>60:20>60 , but i know my platform that hold the bed is heavy which is why it goes down when off
                                • timcurtis67undefined
                                  timcurtis67 @fma
                                  @fma
                                  I have a 450mm X 450mm bed (.250" thick) on 2 lead screws with 8mm travel per revolution. They are the 4 start style lead screws. I drive it with a nema 23 stepper.
                                  No issues with the bed dropping when the power is off but I can push it down with some slight pressure.
                                  • mrehorstdmdundefined
                                    mrehorstdmd @timcurtis67
                                    The 30:1 worm gear reducer stops the 3.5 kg bed assembly (tested to 4kg additional load) in my printer from dropping when power is off, and I can't make it drop by pushing down on it. It has one motor, driven by the Duet board driver, and two belts that do the lifting. Worm gears FTW! There are no sync issues, and the bed is in in tram at all times. No sensors, no extra motor drivers, no extra wiring, no configuration issues. It all "just works" every time. The only downside is that I can't make youtube videos of it. There's just no excitement at all...
                                    o_lampeundefined zaptaundefined 2 Replies Last reply Reply Quote 1
                                    • o_lampeundefined
                                      o_lampe @mrehorstdmd
                                      @mrehorstdmd
                                      I remember your worm drive was quite expensive and not easy to get outside U.S.
                                      What was it's name? Rhino-something...
                                      • zaptaundefined
                                        zapta @mrehorstdmd
                                        @mrehorstdmd said in Z axis: ball screws vs belts:
                                        no extra wiring...
                                        It was replaced with extra belting. 😉
                                          mrehorstdmd @o_lampe
                                          @o_lampe https://www.ebay.com/itm/Rino-Motorized-Rotary-Table-Stage-CNC-4th-Axis-Sherline-Milling-Engraver-Router/191714031261?epid=711126295&hash=item2ca30bf69d:g:A7UAAOSwPhdVB2f0
                                          $108 shipped. You get the motor and worm drive already integrated. Compare that to the cost of a motor and brake, or buying a motor and separate gear box. This type seems to work fine, too, and can be bought via aliexpress in whatever country you're in: https://www.ebay.com/itm/NEMA17-Turbine-Worm-Gear-Stepper-motor-Hybrid-2-Phase-4-wires/324001642095?hash=item4b7000b66f:g:HTMAAOSwEGVd50j1
                                          @zapta Yes, belts instead of wires and connectors. How often have you heard of wiring problems vs how often have you heard of belts failing? I suppose ineptitude in wiring can translate to ineptitude in mechanics, so they're probably even by that measure.
                                          • zaptaundefined
                                            zapta @mrehorstdmd
                                            Chances are your printer has many more wires than belts so more room for failure. 😉
                                            BTW, I just started to collect parts for a Voron V2.4. If I got it correctly, the design has 8 (eight) belts and 16 puleys/idlers just for the Z movement, so belting can be fun.
