    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    31.0k
    • seeul8erundefined
      seeul8er
      @chimaeragh As Sindarius already stated: RepPanel is self contained and runs on the ESP32.
      Sadly I do not have the time or motivation to make a port for CNC applications. CNCs require quiet a lot more manual control over the heads position. I also think that because of that a bigger display (coupled with a more powerfull MCU) would be adequate which probably requires a complete rewirte of the code.
      • leewaaundefined
        leewaa
        Hi there @PCR any boards pcb boards left ?
        • PCRundefined
          PCR
          yes 18x or so 😉
          • leewaaundefined
            leewaa
            Oh cool, I would be interested in one!
            Is there some kind of dedicated page documenting the things I would need to get it running. I'm running the Duet 3 v1.01
            • carlos_lemaundefined
              carlos_lema
              Hi there @PCR I am interested on a set = (PCB, GPIO Headers + ESP32), send me payment details — shipping to NYC 10023.
              Also, I might have missed it—where is the repo for the firmware? I am building a PCB making printer (trace, solder paste & drill) that requires some modification to GUI.
              JohnOCFIIundefined 1 Reply Last reply Reply Quote 0
              • JohnOCFIIundefined
                JohnOCFII @carlos_lema
                @carlos_lema said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                The link was in the first note -- but not necessarily obvious as a link: https://github.com/seeul8er/RepPanel_ESP32
                carlos_lemaundefined 1 Reply Last reply Reply Quote 0
                  carlos_lema @JohnOCFII
                  @JohnOCFII Much appreciated!
                  • Nellorundefined
                    Nellor
                    Has anyone successfully running the Reppanel at a Duet3?
                    I experienced the following problem. The display doesn't start (applying 24V to the Duet) when connected to the 5V supplied by the Duet - in my case just the connector IO_0.
                    When I reset the Lolin32 afterwards with it's reset button it works immediately like expected. When I plug/unplug the connector IO_0 it starts as well.
                    I can reproduce this with a spare Duet3 just supplying 24V and Reppanel connected.
                    It must have something to to with the rising 5V voltage of the Duet and the power on reset of the Lolin. The board just doesn't reset properly at boot-up.
                    I fixed it by applying 10uF to extend the time constant of the R-C combination for boot-up reset. Former 10k+1uF->0.01s, now 10k+10uF->0.1s.
                    Now it starts like it should...
                    2021-02-26 17_00_35-LOLOIN32_Schaltplan.png (1183×883).pngIMG_20210226_165821~2.jpg
                    Now my question - is there already a software reset at start-up or could an additional software reset be implemented?
                    • seeul8erundefined
                      seeul8er
                      @Nellor Nice investigation!
                      I did not implement a software reset on startup. Maybe the ESP-Firmware does one. Should be no problem adding one additionally.
                      If you want a quick fix try adding:
                      esp_restart()
                      somewhere here. That should not slow down the boot time too much.
                        JohnOCFII
                        I finally finished and published my RepPanel case. I used this as a good time to learn a bit about FreeCAD. The FreeCAD design file is included in the Thing.
                        https://www.thingiverse.com/thing:4822626
                        • izemanundefined
                          izeman
                          @pcr tried to PM you, but maybe I'm stupid and can only find the chat option, or have not enough privilige as a new user to PM.
                          So I wanted to ask if you got a PCB left to ship to me. Please contact me. Thanks!
                          I also looked for the correct option for ordering the display and would aks someone to confirm this is correct. See attached picture. Thanks!
                            Phaedrux Moderator @izeman
                            @izeman said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                            Not stupid at all. The chat option is the PM option.
                            izemanundefined 1 Reply Last reply Reply Quote 0
                            • izemanundefined
                              izeman @Phaedrux
                              @phaedrux Can someone please help me in regards to the display options so I can order? So I can order.
                              • PCRundefined
                                PCR
                                • izemanundefined
                                  izeman
                                  Thanks PCR. This is much appreciated, and for sure will help others in the future as well. Now I can order with confidence 🙂
                                  • zaptaundefined
                                    zapta @seeul8er
                                    @seeul8er, can you make this firmware running on this hardware (esp32, 3.5", capacitive touch) ? It's not cheap but may be a simple solution for people that don't want to mess with electronics.
                                    https://www.tindie.com/products/dustinwattsnl/esp32-touchdown/
                                    BTW, the price of buydisplay.com TFT screens went up significantly due to the global semiconductor shortage.
                                    seeul8erundefined 1 Reply Last reply Reply Quote 0
                                    • seeul8erundefined
                                      seeul8er @zapta
                                      @zapta I know the touchdown project. As far as hardware is concerned it should work just fine. You will need to re-configure the SPI-Pins (meaning you will need to recompile the project).
                                      I have some ideas on a custom board but found no time to get familiar with electronics design, yet.
                                      zaptaundefined 2 Replies Last reply Reply Quote 0
                                      • zaptaundefined
                                        zapta @seeul8er
                                        @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                                        According to the designer, it uses the 3.5 LCD CTP option from here:
                                        https://www.aliexpress.com/item/32862869103.html
                                        Less expensive than the buydisplay one and allows a single PCB and thin design compare to the buydisplay's panel.
                                        Edit: I ordered a couple of those to play with.
                                        • seeul8erundefined
                                          seeul8er
                                          RepPanel v1.1.1 is released
                                          Changelog:
                                          • Fixed crash when no filament is specified
                                          • Macro and Job listings are now sorted by modification date
                                          • Fixed filament load/unload error if no tool was selected previously
                                          • Rebased to custom branch of lvgl (seeul8er)
                                          • Compiled for release/performance
                                          jay_s_ukundefined JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                                            jay_s_uk @seeul8er
                                            @seeul8er any chance of SBC support?
