    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • carlos_lemaundefined
      carlos_lema @JohnOCFII
      @JohnOCFII Much appreciated!
      • Nellorundefined
        Nellor
        Has anyone successfully running the Reppanel at a Duet3?
        I experienced the following problem. The display doesn't start (applying 24V to the Duet) when connected to the 5V supplied by the Duet - in my case just the connector IO_0.
        When I reset the Lolin32 afterwards with it's reset button it works immediately like expected. When I plug/unplug the connector IO_0 it starts as well.
        I can reproduce this with a spare Duet3 just supplying 24V and Reppanel connected.
        It must have something to to with the rising 5V voltage of the Duet and the power on reset of the Lolin. The board just doesn't reset properly at boot-up.
        I fixed it by applying 10uF to extend the time constant of the R-C combination for boot-up reset. Former 10k+1uF->0.01s, now 10k+10uF->0.1s.
        Now it starts like it should...
        2021-02-26 17_00_35-LOLOIN32_Schaltplan.png (1183×883).pngIMG_20210226_165821~2.jpg
        Now my question - is there already a software reset at start-up or could an additional software reset be implemented?
        • seeul8erundefined
          seeul8er
          @Nellor Nice investigation!
          I did not implement a software reset on startup. Maybe the ESP-Firmware does one. Should be no problem adding one additionally.
          If you want a quick fix try adding:
          esp_restart()
          somewhere here. That should not slow down the boot time too much.
          • JohnOCFIIundefined
            JohnOCFII
            I finally finished and published my RepPanel case. I used this as a good time to learn a bit about FreeCAD. The FreeCAD design file is included in the Thing.
            https://www.thingiverse.com/thing:4822626
            • izemanundefined
              izeman
              @pcr tried to PM you, but maybe I'm stupid and can only find the chat option, or have not enough privilige as a new user to PM.
              So I wanted to ask if you got a PCB left to ship to me. Please contact me. Thanks!
              I also looked for the correct option for ordering the display and would aks someone to confirm this is correct. See attached picture. Thanks!
                Phaedrux Moderator @izeman
                @izeman said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                Not stupid at all. The chat option is the PM option.
                izemanundefined 1 Reply Last reply Reply Quote 0
                • izemanundefined
                  izeman @Phaedrux
                  @phaedrux Can someone please help me in regards to the display options so I can order? So I can order.
                  • PCRundefined
                    PCR
                    • izemanundefined
                      izeman
                      Thanks PCR. This is much appreciated, and for sure will help others in the future as well. Now I can order with confidence 🙂
                      • zaptaundefined
                        zapta @seeul8er
                        @seeul8er, can you make this firmware running on this hardware (esp32, 3.5", capacitive touch) ? It's not cheap but may be a simple solution for people that don't want to mess with electronics.
                        https://www.tindie.com/products/dustinwattsnl/esp32-touchdown/
                        BTW, the price of buydisplay.com TFT screens went up significantly due to the global semiconductor shortage.
                        seeul8erundefined 1 Reply Last reply Reply Quote 0
                        • seeul8erundefined
                          seeul8er @zapta
                          @zapta I know the touchdown project. As far as hardware is concerned it should work just fine. You will need to re-configure the SPI-Pins (meaning you will need to recompile the project).
                          I have some ideas on a custom board but found no time to get familiar with electronics design, yet.
                          zaptaundefined 2 Replies Last reply Reply Quote 0
                          • zaptaundefined
                            zapta @seeul8er
                            @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                            According to the designer, it uses the 3.5 LCD CTP option from here:
                            https://www.aliexpress.com/item/32862869103.html
                            Less expensive than the buydisplay one and allows a single PCB and thin design compare to the buydisplay's panel.
                            Edit: I ordered a couple of those to play with.
                            • seeul8erundefined
                              seeul8er
                              RepPanel v1.1.1 is released
                              Changelog:
                              • Fixed crash when no filament is specified
                              • Macro and Job listings are now sorted by modification date
                              • Fixed filament load/unload error if no tool was selected previously
                              • Rebased to custom branch of lvgl (seeul8er)
                              • Compiled for release/performance
                              jay_s_ukundefined JohnOCFIIundefined 2 Replies Last reply Reply Quote 0
                                jay_s_uk @seeul8er
                                @seeul8er any chance of SBC support?
                                  JohnOCFII @seeul8er
                                  @seeul8er Great to see an updated release!
                                  Is there a concern of panel burn-in if the display is RepPanel is left energized for 24 hours? Would a timed screen blank (awakened with touch) be a useful addition?
                                  Also -- sometimes touch input is sensed immediately -- other times I have to press an item four or five times for it to register. Any ideas on what would cause that, or ways to troubleshoot?
                                  Thanks!
                                  John
                                  • seeul8erundefined
                                    seeul8er
                                    @jay_s_uk Not sure what the issue is there. Does Duet Web Control work with a SBC/Pi? RepPanel uses the same API (the older one though) so it should work just fine. Sadly I do not have a Duet3 to test it.
                                    @JohnOCFII
                                    Yes burn-in can be an issue. I always turn mine off if I do not need it. The idea of a screen saver is not new. I'll look into that.
                                    I do have the same issue with the touch screen. Sometimes I need to click twice. Maybe it's a driver issue. I'll add it to the list.
                                    For the rest: Is there anything else you would like to see with RepPanel? I might find the time to implement some stuff or even get a custom board design working (not sure about that one yet). Feel free to post here or add an issue in the Github Repository. You can also vote for your favourite one.
                                    Feature wishlist:
                                    • Screen Saver/Power Saver mode
                                    • Improved touch control
                                    • Check Duet + SBC support
                                    • Fix bug: No job displaying on the screen when starting a new job (workaround: go back to main and re-enter "Jobs")
                                    • Listing more than 16 entries per directory
                                    • Use Object Model and new RRF3 API calls instead of the old ones
                                    jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                                      jay_s_uk @seeul8er
                                      @seeul8er it needs to support the newer API to work with SBC/Duet combinations. it uses machine/status rather than rr_status. At the moment, it doesn't work.
                                      A good example of the two differences can be found here https://github.com/HaythamB/TAMV/blob/master/DuetWebAPI.py
                                      If you have an LPC or STM32 board, you could always setup a test environment https://teamgloomy.github.io/ to get it working
                                      fractalengineerundefined 1 Reply Last reply Reply Quote 1
                                      • fractalengineerundefined
                                        fractalengineer @jay_s_uk
                                        @jay_s_uk Hey mate!
                                        I just found out about this project right here, ESP32 Touchdown that interfaces the more easy to find, bare capacitive touchscreen with a simple ESP32 module and adds usb3, battery and power management all at once.
                                        Do you think your soft could be portable to this hardware?
                                        I would have built one of your RepPanels last year already if it wasn't for the lack of availability of that capacitive screen in my area of Taiwan.
                                        This would def make it easier on that aspect
                                        Cheers!
                                        Railcore II ZL
                                        jay_s_ukundefined zaptaundefined 2 Replies Last reply Reply Quote 0
                                          jay_s_uk @fractalengineer
                                          @fractalengineer it's not my project. It's @seeul8er you want
                                          • zaptaundefined
                                            zapta @fractalengineer
                                            @fractalengineer, you may find this useful
                                            https://forum.duet3d.com/topic/15198/reppanel-a-diy-alternative-to-the-paneldue-with-wifi-support/213?_=1623794459279
                                            Esp32 Touchdown with its single PCB form factor is easy to integrate in a case, and 200 new ones are coming to the market 😉 https://www.youtube.com/watch?v=YHzU_GXCIkQ
