    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    34.8k
    • carcamerarigundefined
      carcamerarig
      @dc42 @droftarts
      What gives?
      droftartsundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @carcamerarig
        @carcamerarig looks like the reporting isn’t working as @dc42 expects. He’ll need to look at this.
          @carcamerarig actually, I think it’s just a typo, and the E should be an R. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_2_Read_or_write_stepper_driver_register
          So send M569.2 P# R0
          carcamerarigundefined 1 Reply Last reply Reply Quote 0
            carcamerarig @droftarts
            @droftarts @dc42
            2 bangs / layer shifts, new reporting below, please advise if you can see the issue within the reporting.
            m122
            RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+2 (2021-04-15 16:55:30) running on Duet 3 Mini5plus WiFi (standalone mode)
            Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD
            Used output buffers: 3 of 40 (18 max)
            Static ram: 100104
            Dynamic ram: 106340 of which 32 recycled
            Never used RAM 34372, free system stack 132 words
            Tasks: NETWORK(ready,233) HEAT(delaying,318) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,334) TMC(notifyWait,105) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,266)
            Owned mutexes: WiFi(NETWORK)
            Last reset 00:01:20 ago, cause: power up
            Last software reset at 2021-04-18 12:27, reason: User, GCodes spinning, available RAM 34372, slot 2
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU revision 3, ADC conversions started 95990, completed 95989, timed out 0, errs 0
            Step timer max interval 2246
            Supply voltage: min 23.5, current 23.5, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/1910/1910, gc cycles 0
            Driver 0: position 39400, standstill, SG min/max 0/428, read errors 0, write errors 0, ifcnt 16, reads 4210, writes 16, timeouts 0, DMA errors 0
            Driver 1: position 19000, standstill, SG min/max 0/338, read errors 0, write errors 0, ifcnt 15, reads 4210, writes 15, timeouts 0, DMA errors 0
            Driver 2: position 20000, standstill, SG min/max 0/274, read errors 0, write errors 0, ifcnt 13, reads 4212, writes 13, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 4214, writes 11, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, SG min/max 0/276, read errors 0, write errors 0, ifcnt 14, reads 4211, writes 14, timeouts 0, DMA errors 0
            Driver 5: position 0, assumed not present
            Driver 6: position 0, assumed not present
            Date/time: 2021-04-18 13:04:31
            Cache data hit count 138727319
            Slowest loop: 1000.11ms; fastest: 0.07ms
            === Storage ===
            Free file entries: 8
            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
            DMs created 83, maxWait 21893ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
            === AuxDDARing ===
            Bed heaters = 0 -1, chamberHeaters = -1 -1
            Heater 0 is on, I-accum = 0.0
            Heater 1 is on, I-accum = 0.1
            Segments left: 0
            Movement lock held by File
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is doing "M116 P0" in state(s) 0 24, running macro
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Filament sensors ===
            Extruder 0 sensor: ok
            === CAN ===
            Messages queued 742, send timeouts 738, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
            Last cancelled message type 4514 dest 127
            === Network ===
            Slowest loop: 129.66ms; fastest: 0.00ms
            HTTP sessions: 1 of 8
            - WiFi -
            Network state is active
            WiFi firmware version 1.25beta0
            WiFi MAC address f4:cf:a2:6f:e9:78
            WiFi Vcc 3.36, reset reason Power up
            WiFi flash size 2097152, free heap 24696
            WiFi IP address 192.168.1.226
            WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            18/04/2021, 13:09:09	M569.2 P0.4 R0
            Register 0x00 value 0x000001c0
            18/04/2021, 13:09:04	M569.2 P0.3 R0
            18/04/2021, 13:09:00	M569.2 P0.2 R0
            18/04/2021, 13:08:56	M569.2 P0.1 R0
            18/04/2021, 13:08:50	M569.2 P0.0 R0
            18/04/2021, 13:08:38	Resume state saved
            18/04/2021, 13:05:10	M569.2 P0.4 R0
            18/04/2021, 13:05:05	M569.2 P0.3 R0
            18/04/2021, 13:05:01	M569.2 P0.2 R0
            18/04/2021, 13:04:55	M569.2 P0.1 R0
            18/04/2021, 13:04:52	M569.2 P0.0 R0
            m122
            Used output buffers: 3 of 40 (26 max)
            Static ram: 100104
            Tasks: NETWORK(ready,232) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,266)
            Last reset 00:06:09 ago, cause: power up
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU revision 3, ADC conversions started 427660, completed 427659, timed out 0, errs 0
            Step timer max interval 75162
            Supply voltage: min 23.4, current 23.6, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/798/744, gc cycles 4
            Driver 0: position 2000, standstill, SG min/max 0/470, read errors 0, write errors 0, ifcnt 20, reads 14529, writes 4, timeouts 0, DMA errors 0
            Driver 1: position 0, standstill, SG min/max 2/452, read errors 0, write errors 0, ifcnt 19, reads 14529, writes 4, timeouts 0, DMA errors 0
            Driver 2: position 4077, standstill, SG min/max 0/192, read errors 0, write errors 0, ifcnt 17, reads 14529, writes 4, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, SG min/max 0/426, read errors 0, write errors 0, ifcnt 13, reads 14531, writes 2, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, SG min/max 0/198, read errors 0, write errors 0, ifcnt 18, reads 14530, writes 4, timeouts 0, DMA errors 0
            Date/time: 2021-04-18 13:09:19
            Cache data hit count 525126543
            Slowest loop: 100.47ms; fastest: 0.07ms
            === Storage ===
            Free file entries: 9
            SD card longest read time 99.5ms, write time 5.0ms, max retries 0
            DMs created 83, maxWait 126070ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 438, completed moves 438, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 9, 0], CDDA state -1
            === AuxDDARing ===
            Heater 0 is on, I-accum = 0.3
            Heater 1 is on, I-accum = 0.4
            Segments left: 0
            Movement lock held by null
            File is doing "G1 X71.895 Y40.877 E0.88464" in state(s) 0
            === CAN ===
            Messages queued 2597, send timeouts 2597, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
            === Network ===
            Slowest loop: 202.94ms; fastest: 0.08ms
            - WiFi -
            Failed messages: pending 0, notready 0, noresp 1
            WiFi flash size 2097152, free heap 24584
            WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
            18/04/2021, 13:16:03	M569.2 P0.4 R0
            18/04/2021, 13:15:56	M569.2 P0.3 R0
            18/04/2021, 13:15:52	M569.2 P0.2 R0
            18/04/2021, 13:15:47	M569.2 P0.1 R0
            18/04/2021, 13:15:39	M569.2 P0.0 R0
            M122
            Used output buffers: 12 of 40 (27 max)
            Static ram: 100104
            Tasks: NETWORK(ready,222) HEAT(delaying,294) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,266)
            Last reset 00:13:08 ago, cause: power up
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU revision 3, ADC conversions started 904380, completed 904379, timed out 0, errs 0
            Step timer max interval 71916
            Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/918/864, gc cycles 9
            Driver 0: position 2000, standstill, SG min/max 0/508, read errors 0, write errors 0, ifcnt 20, reads 20898, writes 0, timeouts 0, DMA errors 0
            Driver 1: position 0, standstill, SG min/max 0/430, read errors 0, write errors 0, ifcnt 19, reads 20899, writes 0, timeouts 0, DMA errors 0
            Driver 2: position 4477, standstill, SG min/max 0/268, read errors 0, write errors 0, ifcnt 17, reads 20898, writes 0, timeouts 0, DMA errors 0
            Driver 3: position 0, standstill, SG min/max 0/486, read errors 0, write errors 0, ifcnt 13, reads 20898, writes 0, timeouts 0, DMA errors 0
            Driver 4: position 0, standstill, SG min/max 0/268, read errors 0, write errors 0, ifcnt 18, reads 20898, writes 0, timeouts 0, DMA errors 0
            Date/time: 2021-04-18 13:16:19
            Cache data hit count 1088363188
            Slowest loop: 95.98ms; fastest: 0.07ms
            === Storage ===
            SD card longest read time 38.3ms, write time 5.0ms, max retries 0
            DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
            === MainDDARing ===
            Scheduled moves 4986, completed moves 4986, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 118, 0], CDDA state -1
            === AuxDDARing ===
            Heater 1 is on, I-accum = 0.5
            Segments left: 0
            File is doing "G1 X71.333 Y69.865 E0.99279" in state(s) 0
            === CAN ===
            Messages queued 3778, send timeouts 3778, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
            Last cancelled message type 30 dest 127
            === Network ===
            Slowest loop: 290.58ms; fastest: 0.08ms
            Responder states: HTTP(0) HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            - WiFi -
            WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
            Socket states: 4 2 0 0 0 0 0 0
              carcamerarig
              Any updates to the reporting please.
              droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                @carcamerarig I’m testing tomorrow on my machine, parenting today. Haven’t heard back from @dc42 yet.
                One suggestion: can you swap the driver the X and Y axis motors are connected to, then change M584 to reflect this change? It looked like the X axis skipping in the last pictures, so it would be good to see if doing this affects the behaviour.
                  carcamerarig
                  bang
                  • SputnikOC3dundefined
                    SputnikOC3d
                    Patience of a saint on display here ... I think its high time to seriously consider a new board with a different driver type. Since Duet 2 would be going backwards - revision' ly ... the 6HC seems a proper choice for the customer - having dealt with So Much effort to make this work. Personally, thats where Id be at this point.
                      dc42 administrators @carcamerarig
                      @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                      @carcamerarig, thanks for the reports.
                      1. Do the layer shifts always occur in the X direction? Can you tell whether the bangs always occur on X moves?
                      2. Please run M569.2 P# R6 for # = 0 to 4. Do this before you start printing, and after you have started and banging has occurred. The values I expect back are:
                      19/04/2021, 21:21:53 	m569.2 p4 r6
                      Register 0x06 value 0x21000040
                      19/04/2021, 21:21:48 	m569.2 p3 r6
                      Register 0x06 value 0x2100004c
                      19/04/2021, 21:21:42 	m569.2 p2 r6
                      Register 0x06 value 0x21000048
                      19/04/2021, 21:21:33 	m569.2 p1 r6
                      Register 0x06 value 0x21000044
                      19/04/2021, 21:21:27 	m569.2 p0 r6
                      If you have the Mini2+ installed as well then P5 should return the same as P1, and P6 the same as P2. If the board is working properly then the returned values should be constant, even while the machine is printing.
                      EDIT: I was wrong, the values will change during printing. In particular, the P0 value may be 0x21000040 as above, or 0x21000240. Similarly for the others. You may occasionally get other values. What I am particularly interested in is whether the readings ever end in C0, C4 etc. instead of 40, 44 etc.
                      carcamerarigundefined 2 Replies Last reply Reply Quote 0
                        carcamerarig @dc42
                        @dc42 I don't have a mini2+ only mini5 in standalone at the moment. Give me an hour ill have the results posted up.
                          @carcamerarig, whatever the result of that test, I would like to try replacing your board. Expect an email from Duet3 asking for your delivery details. Is your board WiFi or Ethernet?
                            carcamerarig @dc42
                            Straightaway pre print I have 4c on driver 3, normal??
                            Date	Event
                            M569.2 P0.4 R6 Register 0x06 value 0x21000040
                            M569.2 P0.3 R6 Register 0x06 value 0x2100004c
                            M569.2 P0.2 R6 Register 0x06 value 0x21000048
                            M569.2 P0.1 R6 Register 0x06 value 0x21000044
                            M569.2 P0.0 R6 Register 0x06 value 0x21000040
                              @carcamerarig, yes those are the normal values. It's for the second-to-last digit that I am interested in values other than 4, in particular C. It may possibly change value when the chip has warmed up.
                              dc42undefined carcamerarigundefined 2 Replies Last reply Reply Quote 0
                                dc42 administrators @dc42
                                PS - I just spotted another register that I would like to know the value of after banging occurs, so please can you also send this command:
                                M569.1 P# R111
                                for values of # that cover at least the axis motors.
                                  carcamerarig @dc42
                                  Pre-print
                                  M122
                                  Used output buffers: 3 of 40 (17 max)
                                  Static ram: 100104
                                  Never used RAM 34372, free system stack 180 words
                                  Tasks: NETWORK(ready,225) HEAT(delaying,316) CanReceiv(notifyWait,944) CanSender(notifyWait,371) CanClock(notifyWait,334) TMC(notifyWait,105) MAIN(running,426) IDLE(ready,20) AIN(notifyWait,266)
                                  Last reset 00:09:06 ago, cause: power up
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  Aux1 errors 0,0,0
                                  MCU revision 3, ADC conversions started 651063, completed 651062, timed out 0, errs 0
                                  Step timer max interval 1360
                                  Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/830/830, gc cycles 6
                                  Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 28722, writes 10, timeouts 0, DMA errors 0
                                  Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 28723, writes 9, timeouts 0, DMA errors 0
                                  Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 28722, writes 9, timeouts 0, DMA errors 0
                                  Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 28722, writes 9, timeouts 0, DMA errors 0
                                  Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 28722, writes 10, timeouts 0, DMA errors 0
                                  Date/time: 2021-04-19 21:52:13
                                  Cache data hit count 964430935
                                  Slowest loop: 9.18ms; fastest: 0.10ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 0.9ms, write time 5.2ms, max retries 0
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  File is idle in state(s) 0
                                  === CAN ===
                                  Messages queued 4914, send timeouts 4912, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                                  === Network ===
                                  Slowest loop: 43.54ms; fastest: 0.00ms
                                  - WiFi -
                                  WiFi flash size 2097152, free heap 25016
                                  WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
                                  1st bang on travel move between shapes 1st layer
                                  Date	Event
                                  M569.2 P0.4 R6 Register 0x06 value 0x21000240
                                  M569.2 P0.3 R6 Register 0x06 value 0x2100024c
                                  M569.2 P0.2 R6 Register 0x06 value 0x21000248
                                  M569.2 P0.1 R6 Register 0x06 value 0x21000244
                                  M569.2 P0.0 R6 Register 0x06 value 0x21000240
                                  M122
                                  Static ram: 100104
                                  Never used RAM 34372, free system stack 134 words
                                  Tasks: NETWORK(ready,225) HEAT(delaying,294) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,361) IDLE(ready,20) AIN(notifyWait,266)
                                  Last reset 00:18:39 ago, cause: power up
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  Aux1 errors 0,0,0
                                  MCU revision 3, ADC conversions started 1311292, completed 1311291, timed out 0, errs 0
                                  Step timer max interval 75117
                                  Supply voltage: min 23.4, current 23.5, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/486/432, gc cycles 13
                                  Driver 0: position 2000, standstill, SG min/max 0/464, read errors 0, write errors 0, ifcnt 20, reads 28912, writes 10, timeouts 0, DMA errors 0
                                  Driver 1: position 0, standstill, SG min/max 0/454, read errors 0, write errors 0, ifcnt 19, reads 28912, writes 10, timeouts 0, DMA errors 0
                                  Driver 2: position 4077, standstill, SG min/max 0/272, read errors 0, write errors 0, ifcnt 17, reads 28914, writes 8, timeouts 0, DMA errors 0
                                  Driver 3: position 0, standstill, SG min/max 0/458, read errors 0, write errors 0, ifcnt 13, reads 28918, writes 4, timeouts 0, DMA errors 0
                                  Driver 4: position 0, standstill, SG min/max 0/268, read errors 0, write errors 0, ifcnt 18, reads 28914, writes 8, timeouts 0, DMA errors 0
                                  Date/time: 2021-04-19 22:01:46
                                  Cache data hit count 1754991793
                                  Slowest loop: 999.77ms; fastest: 0.07ms
                                  === Storage ===
                                  SD card longest read time 98.0ms, write time 11.6ms, max retries 0
                                  DMs created 83, maxWait 558251ms, bed compensation in use: mesh, comp offset 0.000
                                  === MainDDARing ===
                                  Scheduled moves 438, completed moves 438, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 9, 1], CDDA state -1
                                  === AuxDDARing ===
                                  Segments left: 0
                                  === CAN ===
                                  Messages queued 5175, send timeouts 5173, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                                  === Network ===
                                  Slowest loop: 199.40ms; fastest: 0.08ms
                                  - WiFi -
                                  video uploading
                                    carcamerarig @dc42
                                    @dc42 said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                                    M569.1 P# R111
                                    M569.1 P0.4 R111
                                    Driv
                                    19/04/2021, 22:06:07 M569.1 P0.3 R111
                                    Dri
                                    19/04/2021, 22:06:03 M569.1 P0.2 R111
                                    Dr
                                    19/04/2021, 22:05:59 M569.1 P0.1 R111
                                    D
                                    19/04/2021, 22:05:55 M569.1 P0.0 R111
                                    dc42undefined 1 Reply Last reply Reply Quote -1
                                      @carcamerarig, I'm sorry, that should have been M569.2 P# R111. The response should be something like this:
                                      19/04/2021, 22:03:10 	m569.2 p0 r111
                                      Register 0x6f value 0x800200c0
                                      Preferably run it several times on the X driver while the machine is printing, in case it only happens when the driver is warm due to driving the motor.
                                      carcamerarigundefined 3 Replies Last reply Reply Quote 0
                                        carcamerarig @dc42
                                        M569.2 P# R111.
                                        Date Event
                                        19/04/2021, 22:08:38 M569.2 P0.0 R111
                                        Register 0x6f value 0xc0060000
                                        19/04/2021, 22:08:34 M569.2 P0.1 R111
                                        19/04/2021, 22:08:29 M569.2 P0.2 R111
                                        19/04/2021, 22:08:24 M569.2 P0.3 R111
                                        19/04/2021, 22:08:20 M569.2 P0.4 R111
                                          carcamerarig @dc42
                                          link text
                                          dc42undefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                            @carcamerarig, thanks for the video. What am I supposed to be looking/listening for? I don't know how your machine is supposed to sound.
