Missing Steps - Cant Print SpreadCycle StealthChop tuning help
286
32.1k
    SputnikOC3d
    Patience of a saint on display here ... I think its high time to seriously consider a new board with a different driver type. Since Duet 2 would be going backwards - revision' ly ... the 6HC seems a proper choice for the customer - having dealt with So Much effort to make this work. Personally, thats where Id be at this point.
      dc42 administrators @carcamerarig
      @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
      Any updates to the reporting please.
      @carcamerarig, thanks for the reports.
      1. Do the layer shifts always occur in the X direction? Can you tell whether the bangs always occur on X moves?
      2. Please run M569.2 P# R6 for # = 0 to 4. Do this before you start printing, and after you have started and banging has occurred. The values I expect back are:
      19/04/2021, 21:21:53 m569.2 p4 r6
      Register 0x06 value 0x21000040
      19/04/2021, 21:21:48 m569.2 p3 r6
      Register 0x06 value 0x2100004c
      19/04/2021, 21:21:42 m569.2 p2 r6
      Register 0x06 value 0x21000048
      19/04/2021, 21:21:33 m569.2 p1 r6
      Register 0x06 value 0x21000044
      19/04/2021, 21:21:27 m569.2 p0 r6
      If you have the Mini2+ installed as well then P5 should return the same as P1, and P6 the same as P2. If the board is working properly then the returned values should be constant, even while the machine is printing.
      EDIT: I was wrong, the values will change during printing. In particular, the P0 value may be 0x21000040 as above, or 0x21000240. Similarly for the others. You may occasionally get other values. What I am particularly interested in is whether the readings ever end in C0, C4 etc. instead of 40, 44 etc.
      undefined 2 Replies Last reply 19 Apr 2021, 20:28 Reply Quote 0
        carcamerarig @dc42
        @dc42 I don't have a mini2+ only mini5 in standalone at the moment. Give me an hour ill have the results posted up.
        undefined 1 Reply Last reply 19 Apr 2021, 20:40 Reply Quote 0
          @carcamerarig, whatever the result of that test, I would like to try replacing your board. Expect an email from Duet3 asking for your delivery details. Is your board WiFi or Ethernet?
            carcamerarig @dc42
            Straightaway pre print I have 4c on driver 3, normal??
            Date Event
            M569.2 P0.4 R6 Register 0x06 value 0x21000040
            M569.2 P0.3 R6 Register 0x06 value 0x2100004c
            M569.2 P0.2 R6 Register 0x06 value 0x21000048
            M569.2 P0.1 R6 Register 0x06 value 0x21000044
            M569.2 P0.0 R6 Register 0x06 value 0x21000040
            undefined 1 Reply Last reply 19 Apr 2021, 20:58 Reply Quote 0
              @carcamerarig, yes those are the normal values. It's for the second-to-last digit that I am interested in values other than 4, in particular C. It may possibly change value when the chip has warmed up.
              undefined undefined 2 Replies Last reply 19 Apr 2021, 21:04 Reply Quote 0
                dc42 administrators @dc42
                PS - I just spotted another register that I would like to know the value of after banging occurs, so please can you also send this command:
                M569.1 P# R111
                for values of # that cover at least the axis motors.
                undefined 1 Reply Last reply 19 Apr 2021, 21:06 Reply Quote 0
                  carcamerarig @dc42
                  Pre-print
                  M122
                  RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+2 (2021-04-15 16:55:30) running on Duet 3 Mini5plus WiFi (standalone mode)
                  Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD
                  Used output buffers: 3 of 40 (17 max)
                  Static ram: 100104
                  Dynamic ram: 106340 of which 32 recycled
                  Never used RAM 34372, free system stack 180 words
                  Tasks: NETWORK(ready,225) HEAT(delaying,316) CanReceiv(notifyWait,944) CanSender(notifyWait,371) CanClock(notifyWait,334) TMC(notifyWait,105) MAIN(running,426) IDLE(ready,20) AIN(notifyWait,266)
                  Owned mutexes: WiFi(NETWORK)
                  Last reset 00:09:06 ago, cause: power up
                  Last software reset at 2021-04-18 12:27, reason: User, GCodes spinning, available RAM 34372, slot 2
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  Aux1 errors 0,0,0
                  MCU revision 3, ADC conversions started 651063, completed 651062, timed out 0, errs 0
                  Step timer max interval 1360
                  Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/830/830, gc cycles 6
                  Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 28722, writes 10, timeouts 0, DMA errors 0
                  Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 28723, writes 9, timeouts 0, DMA errors 0
                  Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 28722, writes 9, timeouts 0, DMA errors 0
                  Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 28722, writes 9, timeouts 0, DMA errors 0
                  Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 28722, writes 10, timeouts 0, DMA errors 0
                  Driver 5: position 0, assumed not present
                  Driver 6: position 0, assumed not present
                  Date/time: 2021-04-19 21:52:13
                  Cache data hit count 964430935
                  Slowest loop: 9.18ms; fastest: 0.10ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 0.9ms, write time 5.2ms, max retries 0
                  === MainDDARing ===
                  === AuxDDARing ===
                  Bed heaters = 0 -1, chamberHeaters = -1 -1
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty.
                  === Filament sensors ===
                  Extruder 0 sensor: ok
                  === CAN ===
                  Messages queued 4914, send timeouts 4912, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                  Last cancelled message type 4514 dest 127
                  === Network ===
                  Slowest loop: 43.54ms; fastest: 0.00ms
                  HTTP sessions: 1 of 8
                  - WiFi -
                  Network state is active
                  WiFi firmware version 1.25beta0
                  WiFi MAC address f4:cf:a2:6f:e9:78
                  WiFi Vcc 3.36, reset reason Power up
                  WiFi flash size 2097152, free heap 25016
                  WiFi IP address 192.168.1.226
                  WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem
                  Clock register 00002002
                  1st bang on travel move between shapes 1st layer
                  Date Event
                  M569.2 P0.4 R6 Register 0x06 value 0x21000240
                  M569.2 P0.3 R6 Register 0x06 value 0x2100024c
                  M569.2 P0.2 R6 Register 0x06 value 0x21000248
                  M569.2 P0.1 R6 Register 0x06 value 0x21000244
                  M569.2 P0.0 R6 Register 0x06 value 0x21000240
                  M122
                  Used output buffers: 3 of 40 (26 max)
                  Static ram: 100104
                  Never used RAM 34372, free system stack 134 words
                  Tasks: NETWORK(ready,225) HEAT(delaying,294) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,361) IDLE(ready,20) AIN(notifyWait,266)
                  Last reset 00:18:39 ago, cause: power up
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  Aux1 errors 0,0,0
                  MCU revision 3, ADC conversions started 1311292, completed 1311291, timed out 0, errs 0
                  Step timer max interval 75117
                  Supply voltage: min 23.4, current 23.5, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/486/432, gc cycles 13
                  Driver 0: position 2000, standstill, SG min/max 0/464, read errors 0, write errors 0, ifcnt 20, reads 28912, writes 10, timeouts 0, DMA errors 0
                  Driver 1: position 0, standstill, SG min/max 0/454, read errors 0, write errors 0, ifcnt 19, reads 28912, writes 10, timeouts 0, DMA errors 0
                  Driver 2: position 4077, standstill, SG min/max 0/272, read errors 0, write errors 0, ifcnt 17, reads 28914, writes 8, timeouts 0, DMA errors 0
                  Driver 3: position 0, standstill, SG min/max 0/458, read errors 0, write errors 0, ifcnt 13, reads 28918, writes 4, timeouts 0, DMA errors 0
                  Driver 4: position 0, standstill, SG min/max 0/268, read errors 0, write errors 0, ifcnt 18, reads 28914, writes 8, timeouts 0, DMA errors 0
                  Date/time: 2021-04-19 22:01:46
                  Cache data hit count 1754991793
                  Slowest loop: 999.77ms; fastest: 0.07ms
                  === Storage ===
                  Free file entries: 9
                  SD card longest read time 98.0ms, write time 11.6ms, max retries 0
                  DMs created 83, maxWait 558251ms, bed compensation in use: mesh, comp offset 0.000
                  === MainDDARing ===
                  Scheduled moves 438, completed moves 438, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 9, 1], CDDA state -1
                  === AuxDDARing ===
                  Heater 0 is on, I-accum = 0.3
                  Heater 1 is on, I-accum = 0.4
                  Segments left: 0
                  File is doing "G1 X71.895 Y40.877 E0.88464" in state(s) 0
                  === CAN ===
                  Messages queued 5175, send timeouts 5173, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                  Last cancelled message type 30 dest 127
                  === Network ===
                  Slowest loop: 199.40ms; fastest: 0.08ms
                  - WiFi -
                  Failed messages: pending 0, notready 0, noresp 1
                  video uploading
                    carcamerarig @dc42
                    @dc42 said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                    M569.1 P# R111
                    M569.1 P0.4 R111
                    Driv
                    19/04/2021, 22:06:07 M569.1 P0.3 R111
                    Dri
                    19/04/2021, 22:06:03 M569.1 P0.2 R111
                    Dr
                    19/04/2021, 22:05:59 M569.1 P0.1 R111
                    D
                    19/04/2021, 22:05:55 M569.1 P0.0 R111
                    undefined 1 Reply Last reply 19 Apr 2021, 21:07 Reply Quote -1
                      @carcamerarig, I'm sorry, that should have been M569.2 P# R111. The response should be something like this:
                      19/04/2021, 22:03:10 m569.2 p0 r111
                      Register 0x6f value 0x800200c0
                      Preferably run it several times on the X driver while the machine is printing, in case it only happens when the driver is warm due to driving the motor.
                      undefined 3 Replies Last reply 19 Apr 2021, 21:08 Reply Quote 0
                        carcamerarig @dc42
                        M569.2 P# R111.
                        Date Event
                        19/04/2021, 22:08:38 M569.2 P0.0 R111
                        Register 0x6f value 0xc0060000
                        19/04/2021, 22:08:34 M569.2 P0.1 R111
                        19/04/2021, 22:08:29 M569.2 P0.2 R111
                        19/04/2021, 22:08:24 M569.2 P0.3 R111
                        19/04/2021, 22:08:20 M569.2 P0.4 R111
                          carcamerarig @dc42
                          link text
                          undefined undefined 2 Replies Last reply 19 Apr 2021, 21:25 Reply Quote 0
                            @carcamerarig, thanks for the video. What am I supposed to be looking/listening for? I don't know how your machine is supposed to sound.
                              carcamerarig @dc42
                              Bang 2
                              19/04/2021, 22:26:53 M569.2 P0.0 R111
                              19/04/2021, 22:26:48 M569.2 P0.1 R111
                              19/04/2021, 22:26:44 M569.2 P0.2 R111
                              19/04/2021, 22:26:40 M569.2 P0.3 R111
                              19/04/2021, 22:26:36 M569.2 P0.4 R111
                              19/04/2021, 22:26:29 M569.2 P0.4 R6
                              19/04/2021, 22:26:26 M569.2 P0.3 R6
                              19/04/2021, 22:26:23 M569.2 P0.2 R6
                              19/04/2021, 22:26:19 M569.2 P0.1 R6
                              19/04/2021, 22:26:14 M569.2 P0.0 R6
                              M122
                              Used output buffers: 3 of 40 (31 max)
                              Static ram: 100104
                              Never used RAM 34372, free system stack 114 words
                              Tasks: NETWORK(ready,224) HEAT(delaying,294) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,361) IDLE(ready,20) AIN(notifyWait,266)
                              Last reset 00:43:49 ago, cause: power up
                              Error status: 0x00
                              Aux0 errors 196,196,196
                              Aux1 errors 0,0,0
                              MCU revision 3, ADC conversions started 3047110, completed 3047109, timed out 0, errs 0
                              Step timer max interval 68683
                              Supply voltage: min 23.4, current 23.8, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/846/792, gc cycles 31
                              Driver 0: position 2000, standstill, SG min/max 0/504, read errors 0, write errors 0, ifcnt 20, reads 10590, writes 0, timeouts 0, DMA errors 0
                              Driver 1: position 0, standstill, SG min/max 0/472, read errors 0, write errors 0, ifcnt 19, reads 10590, writes 0, timeouts 0, DMA errors 0
                              Driver 2: position 5357, standstill, SG min/max 0/270, read errors 0, write errors 0, ifcnt 17, reads 10591, writes 0, timeouts 0, DMA errors 0
                              Driver 3: position 0, standstill, SG min/max 0/500, read errors 0, write errors 0, ifcnt 13, reads 10590, writes 0, timeouts 0, DMA errors 0
                              Driver 4: position 0, standstill, SG min/max 0/276, read errors 0, write errors 0, ifcnt 18, reads 10590, writes 0, timeouts 0, DMA errors 0
                              Date/time: 2021-04-19 22:26:56
                              Cache data hit count 3893796876
                              Slowest loop: 99.60ms; fastest: 0.07ms
                              === Storage ===
                              SD card longest read time 91.0ms, write time 5.2ms, max retries 0
                              DMs created 83, maxWait 1ms, bed compensation in use: mesh, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 17314, completed moves 17314, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 243, 0], CDDA state -1
                              === AuxDDARing ===
                              Segments left: 0
                              File is doing "G1 X172.095 Y53.241 F10800.000" in state(s) 0
                              === CAN ===
                              Messages queued 13590, send timeouts 13590, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                              === Network ===
                              Slowest loop: 199.90ms; fastest: 0.08ms
                              - WiFi -
                              Failed messages: pending 0, notready 0, noresp 2
                              WiFi flash size 2097152, free heap 21864
                              link text
                              undefined undefined 2 Replies Last reply 19 Apr 2021, 21:30 Reply Quote 0
                                Phaedrux Moderator @carcamerarig
                                link text
                                That one seems pretty normal for rapid back and forth on a bed slinger. I don't see the big clunk like on your other videos.
                                undefined 1 Reply Last reply 19 Apr 2021, 21:33 Reply Quote 0
                                  link text
                                  This one you can definitely hear the clunk on travel.
                                    @carcamerarig, thanks! The M569.2 R111 results show that the drivers are running in stealthChop mode. Therefore, the issue could be due to stealthChop/spreadCycle changeover. What M569 V parameter are you using? Are you still getting banging if you set spreadCycle mode instead?
                                    undefined 1 Reply Last reply 19 Apr 2021, 21:35 Reply Quote 0
                                      carcamerarig @Phaedrux
                                      @phaedrux that 1st one was the wrong video lol, my bad.... so many damn videos now Ive shared the wrong one, it was the same as the last video definitely a bang.
                                        carcamerarig @dc42
                                        Yes its happening in all modes, at the moment its still as it was configured from Ian's
                                        ; Drive Mappings
                                        M569 P0.0 S0 D3 V0 ; Drive 0: X Axis
                                        M569 P0.1 S0 D3 V0 ; Drive 1: Y Axis
                                        M569 P0.2 S0 D3 V0 ; Drive 2: Z Axis
                                        M569 P0.3 S0 D3 V0 ; Drive 3: E Axis
                                        M569 P0.4 S0 D3 V0 ; Drive 4: E1 used for Z1
                                        undefined 1 Reply Last reply 19 Apr 2021, 21:38 Reply Quote 0
                                          OK, please try setting spreadCycle (D2 in the M569 command, once you have finished stall homing). If/when you are sure that banging has occurred, send the M569.2 P# R111 commands again, while it is still printing.
                                          undefined 1 Reply Last reply 19 Apr 2021, 21:57 Reply Quote 0
                                          236 out of 286
