    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    36.3k
      droftarts administrators @alankilian
      @alankilian both @T3P3Tony and I have one, but don’t have all the parts yet. Waiting for screens to come from China.
      The other difficulty is reproducing it. In 6 hours of testing with @carcamerarig’s machine (admittedly not printing, mostly just movement) it didn’t happen once. I’ll be setting up my printer as close as possible to his, and running his Gcode, hopefully on Tuesday, if @dc42 doesn’t fix it first!
        droftarts administrators @Argo
        @argo it’s possible. A driver shutdown due to heat could cause a bang like that. But id be surprised if it did it without reporting it.
        If it’s the X axis on his machine, which I think is on driver 0, this is closest to the Mosfets for bed and hotend, which may be getting hot. His board is also in an enclosure, can’t remember if there was a fan. Worth trying with the cover off and a fan pointing at it, perhaps.
        carcamerarigundefined 1 Reply Last reply Reply Quote 0
        • carcamerarigundefined
          carcamerarig @droftarts
          @droftarts
          The 1st bang was within 2 minutes on the 2nd layer, is it even possible to heat up that fast? I have had bangs on the travel move immediately after the purge line.
            @droftarts said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
            @carcamerarig hmm, yes, very disappointing, sorry this still isn’t resolved. As you seem to be able to reproduce the problem very reliably, can you update to the firmware from this post https://forum.duet3d.com/post/226010 and report using the commands @dc42 says? The only way we’re going to be able to fix it is to catch the fault in reporting.
            Just the .uf2 file Ian?
              droftarts administrators @carcamerarig
              @carcamerarig yes, ignore the .map file. I also don’t think it’s to do with heat, but it came up earlier in the thread.
              Argoundefined 1 Reply Last reply Reply Quote 0
              • Argoundefined
                Argo @droftarts
                @droftarts
                I'm running out of plausible explanations tbh.
                With the CoreXY setup it might be an issue with the Mini 2 stepper expansion board using all channels but @carcamerarig and I almost have the same printer and you could personally check mechanical issues. I guess you checked that first before storming into a day of air-printing.
                Those parts are the same for our printers:
                24v PSU
                1.8 LDO motors X/Y/Z
                Bondtech extruder
                same dimensions of the print bed
                same bed heater
                only difference: his frame uses other extrusions and he has 10mm rods and not 8mm rods for X/Y/Z.
                I gave him my config.g which you also saw and checked when he was visiting you.
                Unfortunately the MCU temperature is not readable via software but depending on the load the MCU should already reach it's working temperature after a short period of time under heavy load. But I do not know how much load a typical print generates.
                Yes it's just a wild guess but what else can it be when the same board is working in a almost identical printer? Also the stepper motors worked perfectly in his previous setup with an EINSY 8 bit board.
                I think he tried the last 3-4 weeks (nights) to solve the issues. To rule out any hardware issue, couldn't you from Duet send him a 100% verified working Mini5+ board and he sends in his board to verify? With a typical hardware store infrared sensor you can't really measure possible hot spots on a chip.
                We have at least still two people with skipping layer problems regardless of the used mode (Stealth/Spread). The Mini5+ is still a young product and I guess the sale figures are still low because of the global situation but I've seen "many" with failed SD card slot in the forum (even the replacement board isn't sure to have no issues) so I wouldn't rule out a hardware problem. You've verified and seen the printer so why not.
                He's gone so far and ordered a SKR 1.4 board because he just wants to print something. =(
                Me at the other hand just ordered another Mini5+ (+ 2 stepper expansion) because I still trust in the quality Duet usually delivers in terms of hardware and software.
                When the replacement board is also having issues at his place we might have to get a ghost detector to check whether or not his place is cursed for 3D printing. 😵
                  @argo I understand the frustration. I do feel a bit dumb for not trying a proper print when we were testing, but we were time-constrained. I would have gladly given him my board, but because we couldn’t reproduce it, I couldn’t prove my board would be any better than his.
                  We very much appreciate the community support trying to fix the issue. As @carcamerarig knows, I don’t have a stock of boards to send out; replacement in this instance is a decision for @dc42 or @T3P3Tony . But equally, I wouldn’t want @carcamerarig to go through the hassle of changing his board, only for the same thing to happen, because we haven’t been able reproduce the issue in testing. So there is currently no ‘known-good’ boards.
                  My feeling is that it’s a similar issue to the 0V issue; that there is an issue with SPI and/or DMA that the firmware can work around, once we know what that issue is. The only way to find it is to test firmware with sufficient reporting to find the issue on a machine that exhibits the fault.
                    carcamerarig
                    Appreciate the thoughts and assistance on this issue guys, Chris, Steve from the USA and Ray from NZ, Ben from Germany have all put in a solid 3 weeks on this with me and 2 of which have been til 4am because of the time zones, Ian has the best part of a day plus David’s late involvement. It’s a lot of effort from guys I never even met before and I’m humbled with everyone’s tenacity with it, I did order an SKR but it now feels like I’d be letting the side down if I quit and fit it. I’ll start doing some reporting on the latest fw when I get out of bed (being lazy today)
                    I know Chris is going to get his new mini board fired up soon so that will be another instance in the loop also, what I don’t get is why some other units aren’t showing the same issues?
                      carcamerarig
                      @dc42 @droftarts
                      What gives?
                      droftartsundefined 2 Replies Last reply Reply Quote 0
                        @carcamerarig looks like the reporting isn’t working as @dc42 expects. He’ll need to look at this.
                          @carcamerarig actually, I think it’s just a typo, and the E should be an R. See https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_2_Read_or_write_stepper_driver_register
                          So send M569.2 P# R0
                            @droftarts @dc42
                            2 bangs / layer shifts, new reporting below, please advise if you can see the issue within the reporting.
                            m122
                            RepRapFirmware for Duet 3 Mini 5+ version 3.3beta2+2 (2021-04-15 16:55:30) running on Duet 3 Mini5plus WiFi (standalone mode)
                            Board ID: Z9NZN-A296U-D65J0-40KM4-LY03Z-ZPQPD
                            Used output buffers: 3 of 40 (18 max)
                            Static ram: 100104
                            Dynamic ram: 106340 of which 32 recycled
                            Never used RAM 34372, free system stack 132 words
                            Tasks: NETWORK(ready,233) HEAT(delaying,318) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(notifyWait,334) TMC(notifyWait,105) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,266)
                            Owned mutexes: WiFi(NETWORK)
                            Last reset 00:01:20 ago, cause: power up
                            Last software reset at 2021-04-18 12:27, reason: User, GCodes spinning, available RAM 34372, slot 2
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Aux1 errors 0,0,0
                            MCU revision 3, ADC conversions started 95990, completed 95989, timed out 0, errs 0
                            Step timer max interval 2246
                            Supply voltage: min 23.5, current 23.5, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/1910/1910, gc cycles 0
                            Driver 0: position 39400, standstill, SG min/max 0/428, read errors 0, write errors 0, ifcnt 16, reads 4210, writes 16, timeouts 0, DMA errors 0
                            Driver 1: position 19000, standstill, SG min/max 0/338, read errors 0, write errors 0, ifcnt 15, reads 4210, writes 15, timeouts 0, DMA errors 0
                            Driver 2: position 20000, standstill, SG min/max 0/274, read errors 0, write errors 0, ifcnt 13, reads 4212, writes 13, timeouts 0, DMA errors 0
                            Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 11, reads 4214, writes 11, timeouts 0, DMA errors 0
                            Driver 4: position 0, standstill, SG min/max 0/276, read errors 0, write errors 0, ifcnt 14, reads 4211, writes 14, timeouts 0, DMA errors 0
                            Driver 5: position 0, assumed not present
                            Driver 6: position 0, assumed not present
                            Date/time: 2021-04-18 13:04:31
                            Cache data hit count 138727319
                            Slowest loop: 1000.11ms; fastest: 0.07ms
                            === Storage ===
                            Free file entries: 8
                            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                            DMs created 83, maxWait 21893ms, bed compensation in use: none, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                            === AuxDDARing ===
                            Bed heaters = 0 -1, chamberHeaters = -1 -1
                            Heater 0 is on, I-accum = 0.0
                            Heater 1 is on, I-accum = 0.1
                            Segments left: 0
                            Movement lock held by File
                            HTTP is idle in state(s) 0
                            Telnet is idle in state(s) 0
                            File is doing "M116 P0" in state(s) 0 24, running macro
                            USB is idle in state(s) 0
                            Aux is idle in state(s) 0
                            Trigger is idle in state(s) 0
                            Queue is idle in state(s) 0
                            LCD is idle in state(s) 0
                            SBC is idle in state(s) 0
                            Daemon is idle in state(s) 0
                            Aux2 is idle in state(s) 0
                            Code queue is empty.
                            === Filament sensors ===
                            Extruder 0 sensor: ok
                            === CAN ===
                            Messages queued 742, send timeouts 738, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
                            Last cancelled message type 4514 dest 127
                            === Network ===
                            Slowest loop: 129.66ms; fastest: 0.00ms
                            HTTP sessions: 1 of 8
                            - WiFi -
                            Network state is active
                            WiFi firmware version 1.25beta0
                            WiFi MAC address f4:cf:a2:6f:e9:78
                            WiFi Vcc 3.36, reset reason Power up
                            WiFi flash size 2097152, free heap 24696
                            WiFi IP address 192.168.1.226
                            WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Clock register 00002002
                            18/04/2021, 13:09:09	M569.2 P0.4 R0
                            Register 0x00 value 0x000001c0
                            18/04/2021, 13:09:04	M569.2 P0.3 R0
                            18/04/2021, 13:09:00	M569.2 P0.2 R0
                            18/04/2021, 13:08:56	M569.2 P0.1 R0
                            18/04/2021, 13:08:50	M569.2 P0.0 R0
                            18/04/2021, 13:08:38	Resume state saved
                            18/04/2021, 13:05:10	M569.2 P0.4 R0
                            18/04/2021, 13:05:05	M569.2 P0.3 R0
                            18/04/2021, 13:05:01	M569.2 P0.2 R0
                            18/04/2021, 13:04:55	M569.2 P0.1 R0
                            18/04/2021, 13:04:52	M569.2 P0.0 R0
                            m122
                            Used output buffers: 3 of 40 (26 max)
                            Static ram: 100104
                            Tasks: NETWORK(ready,232) HEAT(delaying,298) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,266)
                            Last reset 00:06:09 ago, cause: power up
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Aux1 errors 0,0,0
                            MCU revision 3, ADC conversions started 427660, completed 427659, timed out 0, errs 0
                            Step timer max interval 75162
                            Supply voltage: min 23.4, current 23.6, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/798/744, gc cycles 4
                            Driver 0: position 2000, standstill, SG min/max 0/470, read errors 0, write errors 0, ifcnt 20, reads 14529, writes 4, timeouts 0, DMA errors 0
                            Driver 1: position 0, standstill, SG min/max 2/452, read errors 0, write errors 0, ifcnt 19, reads 14529, writes 4, timeouts 0, DMA errors 0
                            Driver 2: position 4077, standstill, SG min/max 0/192, read errors 0, write errors 0, ifcnt 17, reads 14529, writes 4, timeouts 0, DMA errors 0
                            Driver 3: position 0, standstill, SG min/max 0/426, read errors 0, write errors 0, ifcnt 13, reads 14531, writes 2, timeouts 0, DMA errors 0
                            Driver 4: position 0, standstill, SG min/max 0/198, read errors 0, write errors 0, ifcnt 18, reads 14530, writes 4, timeouts 0, DMA errors 0
                            Date/time: 2021-04-18 13:09:19
                            Cache data hit count 525126543
                            Slowest loop: 100.47ms; fastest: 0.07ms
                            === Storage ===
                            Free file entries: 9
                            SD card longest read time 99.5ms, write time 5.0ms, max retries 0
                            DMs created 83, maxWait 126070ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 438, completed moves 438, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 9, 0], CDDA state -1
                            === AuxDDARing ===
                            Heater 0 is on, I-accum = 0.3
                            Heater 1 is on, I-accum = 0.4
                            Segments left: 0
                            Movement lock held by null
                            File is doing "G1 X71.895 Y40.877 E0.88464" in state(s) 0
                            === CAN ===
                            Messages queued 2597, send timeouts 2597, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                            === Network ===
                            Slowest loop: 202.94ms; fastest: 0.08ms
                            - WiFi -
                            Failed messages: pending 0, notready 0, noresp 1
                            WiFi flash size 2097152, free heap 24584
                            WiFi signal strength -41dBm, mode 802.11n, reconnections 0, sleep mode modem
                            18/04/2021, 13:16:03	M569.2 P0.4 R0
                            18/04/2021, 13:15:56	M569.2 P0.3 R0
                            18/04/2021, 13:15:52	M569.2 P0.2 R0
                            18/04/2021, 13:15:47	M569.2 P0.1 R0
                            18/04/2021, 13:15:39	M569.2 P0.0 R0
                            M122
                            Used output buffers: 12 of 40 (27 max)
                            Static ram: 100104
                            Tasks: NETWORK(ready,222) HEAT(delaying,294) CanReceiv(notifyWait,944) CanSender(notifyWait,357) CanClock(delaying,334) TMC(notifyWait,105) MAIN(running,312) IDLE(ready,20) AIN(notifyWait,266)
                            Last reset 00:13:08 ago, cause: power up
                            Error status: 0x00
                            Aux0 errors 0,0,0
                            Aux1 errors 0,0,0
                            MCU revision 3, ADC conversions started 904380, completed 904379, timed out 0, errs 0
                            Step timer max interval 71916
                            Heap OK, handles allocated/used 99/2, heap memory allocated/used/recyclable 2048/918/864, gc cycles 9
                            Driver 0: position 2000, standstill, SG min/max 0/508, read errors 0, write errors 0, ifcnt 20, reads 20898, writes 0, timeouts 0, DMA errors 0
                            Driver 1: position 0, standstill, SG min/max 0/430, read errors 0, write errors 0, ifcnt 19, reads 20899, writes 0, timeouts 0, DMA errors 0
                            Driver 2: position 4477, standstill, SG min/max 0/268, read errors 0, write errors 0, ifcnt 17, reads 20898, writes 0, timeouts 0, DMA errors 0
                            Driver 3: position 0, standstill, SG min/max 0/486, read errors 0, write errors 0, ifcnt 13, reads 20898, writes 0, timeouts 0, DMA errors 0
                            Driver 4: position 0, standstill, SG min/max 0/268, read errors 0, write errors 0, ifcnt 18, reads 20898, writes 0, timeouts 0, DMA errors 0
                            Date/time: 2021-04-18 13:16:19
                            Cache data hit count 1088363188
                            Slowest loop: 95.98ms; fastest: 0.07ms
                            === Storage ===
                            SD card longest read time 38.3ms, write time 5.0ms, max retries 0
                            DMs created 83, maxWait 0ms, bed compensation in use: mesh, comp offset 0.000
                            === MainDDARing ===
                            Scheduled moves 4986, completed moves 4986, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 118, 0], CDDA state -1
                            === AuxDDARing ===
                            Heater 1 is on, I-accum = 0.5
                            Segments left: 0
                            File is doing "G1 X71.333 Y69.865 E0.99279" in state(s) 0
                            === CAN ===
                            Messages queued 3778, send timeouts 3778, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                            Last cancelled message type 30 dest 127
                            === Network ===
                            Slowest loop: 290.58ms; fastest: 0.08ms
                            Responder states: HTTP(0) HTTP(4) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                            - WiFi -
                            WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
                            Socket states: 4 2 0 0 0 0 0 0
                              carcamerarig
                              Any updates to the reporting please.
                              droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                @carcamerarig I’m testing tomorrow on my machine, parenting today. Haven’t heard back from @dc42 yet.
                                One suggestion: can you swap the driver the X and Y axis motors are connected to, then change M584 to reflect this change? It looked like the X axis skipping in the last pictures, so it would be good to see if doing this affects the behaviour.
                                  carcamerarig
                                  bang
                                  • SputnikOC3dundefined
                                    SputnikOC3d
                                    Patience of a saint on display here ... I think its high time to seriously consider a new board with a different driver type. Since Duet 2 would be going backwards - revision' ly ... the 6HC seems a proper choice for the customer - having dealt with So Much effort to make this work. Personally, thats where Id be at this point.
                                      dc42 administrators @carcamerarig
                                      @carcamerarig said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                                      @carcamerarig, thanks for the reports.
                                      1. Do the layer shifts always occur in the X direction? Can you tell whether the bangs always occur on X moves?
                                      2. Please run M569.2 P# R6 for # = 0 to 4. Do this before you start printing, and after you have started and banging has occurred. The values I expect back are:
                                      19/04/2021, 21:21:53 	m569.2 p4 r6
                                      Register 0x06 value 0x21000040
                                      19/04/2021, 21:21:48 	m569.2 p3 r6
                                      Register 0x06 value 0x2100004c
                                      19/04/2021, 21:21:42 	m569.2 p2 r6
                                      Register 0x06 value 0x21000048
                                      19/04/2021, 21:21:33 	m569.2 p1 r6
                                      Register 0x06 value 0x21000044
                                      19/04/2021, 21:21:27 	m569.2 p0 r6
                                      If you have the Mini2+ installed as well then P5 should return the same as P1, and P6 the same as P2. If the board is working properly then the returned values should be constant, even while the machine is printing.
                                      EDIT: I was wrong, the values will change during printing. In particular, the P0 value may be 0x21000040 as above, or 0x21000240. Similarly for the others. You may occasionally get other values. What I am particularly interested in is whether the readings ever end in C0, C4 etc. instead of 40, 44 etc.
                                      carcamerarigundefined 2 Replies Last reply Reply Quote 0
                                        carcamerarig @dc42
                                        @dc42 I don't have a mini2+ only mini5 in standalone at the moment. Give me an hour ill have the results posted up.
                                          @carcamerarig, whatever the result of that test, I would like to try replacing your board. Expect an email from Duet3 asking for your delivery details. Is your board WiFi or Ethernet?
                                            carcamerarig @dc42
                                            Straightaway pre print I have 4c on driver 3, normal??
                                            Date	Event
                                            M569.2 P0.4 R6 Register 0x06 value 0x21000040
                                            M569.2 P0.3 R6 Register 0x06 value 0x2100004c
                                            M569.2 P0.2 R6 Register 0x06 value 0x21000048
                                            M569.2 P0.1 R6 Register 0x06 value 0x21000044
                                            M569.2 P0.0 R6 Register 0x06 value 0x21000040
