    Toolboard V1.0 error
    1.9k
    • PaulHewundefined
      PaulHew @tecno
      @tecno Did you change the CAN address of the toolboard when you first installed it?
      If so, what address did you give it? If you cannot remember....
      Try M115 B121 or M115 B10 or M115 B21
      I suspect the LED is not flashing as the Mini does not know what the address of the toolboard is.
      Please post your config.g
      P.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @PaulHew
        @paulhew
        😞 Bad CAN cable connection
        M115 B121
        Duet TOOL1LC firmware version 3.3RC2 (2021-05-11 14:59:50)
        Now that I have CAN working I need to change Hotend , fan , X-min and Probe parameters .
        ; Configuration file for Duet 3 Mini 5+ (firmware version 3)
        ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon May 10 2021 11:46:06 GMT+0200 (centraleuropeisk sommartid)
        M550 P"DUET / CHIRON" ; set printer name
        M551 P"bengt" ; set password
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S1 ; enable FTP
        M586 P2 S1 ; enable Telnet
        ; WAIT FOR CAN
        G4 S1 ;wait for expansion boards to start
        M569 P0 S0 ; physical drive 0.0 goes //forwards
        M569 P1 S0 ; physical drive 0.1 goes forwards
        M569 P2 S1 ; physical drive 0.2 goes forwards
        M569 P3 S0 ; physical drive 0.3 goes forwards
        M569 P4 S0 ; physical drive 0.3 goes forwards
        M584 X2 Y1 Z3:4 E0 ; set drive mapping
        M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
        M84 S30 ; Set idle timeout
        M208 X400 Y400 Z450 S0 ; set axis maxima
        M574 X1 S1 P"!^io3.in" ; configure active-high endstop for low end on X via pin ^io3.in
        M574 Y1 S1 P"!^io0.in" ; configure active-high endstop for low end on Y via pin ^io0.in
        M574 Z1 S1 P"^io6.in" ;
        M558 P1 X0 Y0 Z1 H3 F200 T5000 R0 ; P"!^io6.in"
        M557 X15:400 Y15:400 S20 ; define mesh grid
        M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
        M307 H0 R0.209 C688.7 D1.31 S1.00 V24.2 ; disable bang-bang mode for the bed heater and set PWM limit
        M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
        M950 H1 C"out2" T1 ; create nozzle heater output on out2 and map it to sensor 1
        M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
        M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
        M950 F2 C"out3" Q500 ; create fan 2 on pin out3 and set its frequency
        M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
        T0 ; select first tool
        11
        PaulHewundefined 1 Reply Last reply Reply Quote 0
        • PaulHewundefined
          PaulHew @tecno
          @tecno That CAN connection has to be bulletproof. Good find!
          So what items are going to be connected to the toolboard?
          I ask as there is no reference to anything on the toolboard in your config.g
          I presume it is a Anycubic Chiron, guessing from the name of the board!
          Might be worth you going through the online config again and adding the toolboard and assigning probably the hotend heater, its thermistor and fans and anything else that will be residing / connected on the toolboard.
          • tecnoundefined
            tecno @PaulHew
            @paulhew
            Need to config toolboard for
            Hotend = OUT 0
            Thermistor = TEMP 0
            Hotend fan = OUT 2
            Part fan = OUT 1
            IR Probe = IO 3
            • PaulHewundefined
              PaulHew @tecno
              @tecno I have made a start for you. I know nothing about how an IR probe works, but you can use this as a template to work from.
              config.json
              Download the file
              In the first page of the RRF config tool there is a 'Use existing configuration', select that and then select the above JSON file. and tweak to you hearts content.
              • tecnoundefined
                tecno @PaulHew
                @paulhew
                Thanks Paul, appreciated.
                • tecnoundefined
                  tecno
                  M303 H1 S250
                  Error: M303: remote heater auto tune not implemented
                  Is it not possible to PID tune my hotend via Toolboard ?
                  How can I get going without PID?
                  Before I got CAN to work it show -273°C and now n/a
                  • PaulHewundefined
                    PaulHew @tecno
                    @tecno Config.g please......
                    Also M115 and a M115 B121
                    I suspect a bad connection on the temp. Have you wired it into temp0 on the toolboard?
                    Are you in the UK?
                    • tecnoundefined
                      tecno @PaulHew
                      @paulhew
                      M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
                      M308 S1 P"121.temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                      M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
                      M307 H1 B1 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
                      M950 F0 C"121.out2" Q500 ; create fan 0 on pin out5 and set its frequency
                      M950 F1 C"121.out1" Q500 ; create fan 1 on pin out6 and set its frequency
                      m115
                      FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-beta3.2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-11-15
                      M115 B121
                      Will take a look on the thermistor
                      No this old fart is located s/w of Stockholm on the country side in Sweden
                      • PaulHewundefined
                        PaulHew @tecno
                        @tecno said in Toolboard V1.0 error:
                        Your Mini 5+ board has not been updated.
                        Delete the uf2 in system and upload again and when it asks if you want to update, click 'Yes' !!
                        Lets get that issue sorted 1st.
                        Then make sure your hotend temp probe is connected correctly to 'temp0'
                        • tecnoundefined
                          tecno @PaulHew
                          @paulhew
                          M115
                          Still the same, downloaded 3rd time
                          • tecnoundefined
                            tecno
                            M950 H1 C"121.out0" T1 changed to T0
                            So now thermistor is OK
                            Still no M303 for T0
                            • PaulHewundefined
                              PaulHew @tecno
                              @tecno No, until you get the updated firmware on the Mini.....
                              Reboot the board, either using e-stop or power off, wait 10 secs, then on again.
                              If M115 still reports the beta....
                              Use a different browser, Firefox maybe or Edge. Never trusted Chrome......
                              Download this, it is the same file that is on the Github
                              https://www.dropbox.com/s/csixik6j89bsaiq/Duet3Firmware_Mini5plus.uf2?dl=0
                              Using a browser other than Chrome, upload to the board using the 'Upload System Files' button.
                              Sorry, for teaching you to suck eggs, but after 3 years of running Duet boards, I have never had an issue!
                              Without the latter firmware the M303 will not work on a remote board.
                              • tecnoundefined
                                tecno @PaulHew
                                @paulhew
                                OK, so FF did download the same as before
                                Your dropbox same same
                                There is somthing fischy going on. Maybe update via browser is not working OK?
                                  jay_s_uk @tecno
                                  @tecno IIRC, there was an issue updating the mini from 3.2beta3.2
                                  You need to recover your board as described here https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
                                  tecnoundefined 1 Reply Last reply Reply Quote 1
                                  • tecnoundefined
                                    tecno @jay_s_uk
                                    @jay_s_uk
                                    Now next issues as the update via USB is OK
                                    1. Homing Z not working = Z0 is way up and goes up for ever try setting Z0 evern higher.
                                    2. No heater working on hotend
                                    PaulHewundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                                    • PaulHewundefined
                                      PaulHew @tecno
                                      @tecno are there any messages in the console relating to heater issues?
                                      As previously mentioned, I know nothing about your type of Z probe, I am afraid
                                      • tecnoundefined
                                        tecno @PaulHew
                                        @paulhew
                                        Nothing else than the fault in picture.
                                        I think rc42 is the man behind this probe. It did work connected directly to Mini 5 before.
                                        Is there a way to check endstops if they are open or closed?
                                          jay_s_uk @tecno
                                          @tecno sounds like you need to flip the S value on M569 for the driver you've assigned to Z. Or you need to edit your homing files or endstop position.
                                          And for the heater fault you probably need to PID tune your hotend.
                                          PaulHewundefined tecnoundefined 3 Replies Last reply Reply Quote 0
                                          • PaulHewundefined
                                            PaulHew @jay_s_uk
                                            m119 gives endstop status
