    Toolboard V1.0 error
    1.9k
    • PaulHewundefined
      PaulHew @tecno
      @tecno I have made a start for you. I know nothing about how an IR probe works, but you can use this as a template to work from.
      config.json
      Download the file
      In the first page of the RRF config tool there is a 'Use existing configuration', select that and then select the above JSON file. and tweak to you hearts content.
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @PaulHew
        @paulhew
        Thanks Paul, appreciated.
        • tecnoundefined
          tecno
          M303 H1 S250
          Error: M303: remote heater auto tune not implemented
          Is it not possible to PID tune my hotend via Toolboard ?
          How can I get going without PID?
          Before I got CAN to work it show -273°C and now n/a
          PaulHewundefined 1 Reply Last reply Reply Quote 0
          • PaulHewundefined
            PaulHew @tecno
            @tecno Config.g please......
            Also M115 and a M115 B121
            I suspect a bad connection on the temp. Have you wired it into temp0 on the toolboard?
            Are you in the UK?
            • tecnoundefined
              tecno @PaulHew
              @paulhew
              M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
              M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
              M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
              M308 S1 P"121.temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
              M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
              M307 H1 B1 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
              M950 F0 C"121.out2" Q500 ; create fan 0 on pin out5 and set its frequency
              M950 F1 C"121.out1" Q500 ; create fan 1 on pin out6 and set its frequency
              M950 F2 C"out3" Q500 ; create fan 2 on pin out3 and set its frequency
              M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
              m115
              FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-beta3.2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-11-15
              M115 B121
              Duet TOOL1LC firmware version 3.3RC2 (2021-05-11 14:59:50)
              Will take a look on the thermistor
              No this old fart is located s/w of Stockholm on the country side in Sweden
              • PaulHewundefined
                PaulHew @tecno
                @tecno said in Toolboard V1.0 error:
                Your Mini 5+ board has not been updated.
                Delete the uf2 in system and upload again and when it asks if you want to update, click 'Yes' !!
                Lets get that issue sorted 1st.
                Then make sure your hotend temp probe is connected correctly to 'temp0'
                • tecnoundefined
                  tecno @PaulHew
                  @paulhew
                  M115
                  Still the same, downloaded 3rd time
                  • tecnoundefined
                    tecno
                    M950 H1 C"121.out0" T1 changed to T0
                    So now thermistor is OK
                    Still no M303 for T0
                    • PaulHewundefined
                      PaulHew @tecno
                      @tecno No, until you get the updated firmware on the Mini.....
                      Reboot the board, either using e-stop or power off, wait 10 secs, then on again.
                      If M115 still reports the beta....
                      Use a different browser, Firefox maybe or Edge. Never trusted Chrome......
                      Download this, it is the same file that is on the Github
                      https://www.dropbox.com/s/csixik6j89bsaiq/Duet3Firmware_Mini5plus.uf2?dl=0
                      Using a browser other than Chrome, upload to the board using the 'Upload System Files' button.
                      Sorry, for teaching you to suck eggs, but after 3 years of running Duet boards, I have never had an issue!
                      Without the latter firmware the M303 will not work on a remote board.
                      • tecnoundefined
                        tecno @PaulHew
                        @paulhew
                        OK, so FF did download the same as before
                        Your dropbox same same
                        There is somthing fischy going on. Maybe update via browser is not working OK?
                          jay_s_uk @tecno
                          @tecno IIRC, there was an issue updating the mini from 3.2beta3.2
                          You need to recover your board as described here https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
                          tecnoundefined 1 Reply Last reply Reply Quote 1
                          • tecnoundefined
                            tecno @jay_s_uk
                            @jay_s_uk
                            Now next issues as the update via USB is OK
                            1. Homing Z not working = Z0 is way up and goes up for ever try setting Z0 evern higher.
                            2. No heater working on hotend
                            PaulHewundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                            • PaulHewundefined
                              PaulHew @tecno
                              @tecno are there any messages in the console relating to heater issues?
                              As previously mentioned, I know nothing about your type of Z probe, I am afraid
                              • tecnoundefined
                                tecno @PaulHew
                                @paulhew
                                Nothing else than the fault in picture.
                                I think rc42 is the man behind this probe. It did work connected directly to Mini 5 before.
                                Is there a way to check endstops if they are open or closed?
                                  jay_s_uk @tecno
                                  @tecno sounds like you need to flip the S value on M569 for the driver you've assigned to Z. Or you need to edit your homing files or endstop position.
                                  And for the heater fault you probably need to PID tune your hotend.
                                  PaulHewundefined tecnoundefined 3 Replies Last reply Reply Quote 0
                                  • PaulHewundefined
                                    PaulHew @jay_s_uk
                                    m119 gives endstop status
                                    • tecnoundefined
                                      tecno @jay_s_uk
                                      @jay_s_uk
                                      Sorry but M303 goes nowhere
                                      • tecnoundefined
                                        tecno @PaulHew
                                        @paulhew
                                        Found it, sorry but I am so new to RepRap so all these commands are twisting myt head 😉
                                        m119
                                        Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                                        Above says that there is something wrong in config.
                                        • tecnoundefined
                                          tecno @jay_s_uk
                                          @jay_s_uk said in Toolboard V1.0 error:
                                          M564 and I can move Z as intended -25 goes down below 0
                                          • PaulHewundefined
                                            PaulHew @tecno
                                            @tecno so hold one of the endstops and send the command again
