    Toolboard V1.0 error
    1.9k
    • tecnoundefined
      tecno @PaulHew
      @paulhew
      Need to config toolboard for
      Hotend = OUT 0
      Thermistor = TEMP 0
      Hotend fan = OUT 2
      Part fan = OUT 1
      IR Probe = IO 3
      PaulHewundefined 1 Reply Last reply Reply Quote 0
      • PaulHewundefined
        PaulHew @tecno
        @tecno I have made a start for you. I know nothing about how an IR probe works, but you can use this as a template to work from.
        config.json
        Download the file
        In the first page of the RRF config tool there is a 'Use existing configuration', select that and then select the above JSON file. and tweak to you hearts content.
        tecnoundefined 1 Reply Last reply Reply Quote 0
        • tecnoundefined
          tecno @PaulHew
          @paulhew
          Thanks Paul, appreciated.
          • tecnoundefined
            tecno
            M303 H1 S250
            Error: M303: remote heater auto tune not implemented
            Is it not possible to PID tune my hotend via Toolboard ?
            How can I get going without PID?
            Before I got CAN to work it show -273°C and now n/a
            • PaulHewundefined
              PaulHew @tecno
              @tecno Config.g please......
              Also M115 and a M115 B121
              I suspect a bad connection on the temp. Have you wired it into temp0 on the toolboard?
              Are you in the UK?
              • tecnoundefined
                tecno @PaulHew
                @paulhew
                M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
                M307 H0 R0.211 C620.5 D1.28 S1.00 V24.1 ; disable bang-bang mode for the bed heater and set PWM limit
                M308 S1 P"121.temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
                M950 H1 C"121.out0" T1 ; create nozzle heater output on out2 and map it to sensor 1
                M307 H1 B1 ; disable bang-bang mode for heater and set PWM limit B0 S1.00
                M950 F0 C"121.out2" Q500 ; create fan 0 on pin out5 and set its frequency
                M950 F1 C"121.out1" Q500 ; create fan 1 on pin out6 and set its frequency
                M950 F2 C"out3" Q500 ; create fan 2 on pin out3 and set its frequency
                M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
                m115
                FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2-beta3.2+1 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2020-11-15
                M115 B121
                Duet TOOL1LC firmware version 3.3RC2 (2021-05-11 14:59:50)
                Will take a look on the thermistor
                No this old fart is located s/w of Stockholm on the country side in Sweden
                • PaulHewundefined
                  PaulHew @tecno
                  @tecno said in Toolboard V1.0 error:
                  Your Mini 5+ board has not been updated.
                  Delete the uf2 in system and upload again and when it asks if you want to update, click 'Yes' !!
                  Lets get that issue sorted 1st.
                  Then make sure your hotend temp probe is connected correctly to 'temp0'
                  • tecnoundefined
                    tecno @PaulHew
                    @paulhew
                    M115
                    Still the same, downloaded 3rd time
                    • tecnoundefined
                      tecno
                      M950 H1 C"121.out0" T1 changed to T0
                      So now thermistor is OK
                      Still no M303 for T0
                      • PaulHewundefined
                        PaulHew @tecno
                        @tecno No, until you get the updated firmware on the Mini.....
                        Reboot the board, either using e-stop or power off, wait 10 secs, then on again.
                        If M115 still reports the beta....
                        Use a different browser, Firefox maybe or Edge. Never trusted Chrome......
                        Download this, it is the same file that is on the Github
                        https://www.dropbox.com/s/csixik6j89bsaiq/Duet3Firmware_Mini5plus.uf2?dl=0
                        Using a browser other than Chrome, upload to the board using the 'Upload System Files' button.
                        Sorry, for teaching you to suck eggs, but after 3 years of running Duet boards, I have never had an issue!
                        Without the latter firmware the M303 will not work on a remote board.
                        • tecnoundefined
                          tecno @PaulHew
                          @paulhew
                          OK, so FF did download the same as before
                          Your dropbox same same
                          There is somthing fischy going on. Maybe update via browser is not working OK?
                            jay_s_uk @tecno
                            @tecno IIRC, there was an issue updating the mini from 3.2beta3.2
                            You need to recover your board as described here https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Duet_3_Mini_5_WiFi_Ethernet
                            tecnoundefined 1 Reply Last reply Reply Quote 1
                            • tecnoundefined
                              tecno @jay_s_uk
                              @jay_s_uk
                              Now next issues as the update via USB is OK
                              1. Homing Z not working = Z0 is way up and goes up for ever try setting Z0 evern higher.
                              2. No heater working on hotend
                              PaulHewundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
                              • PaulHewundefined
                                PaulHew @tecno
                                @tecno are there any messages in the console relating to heater issues?
                                As previously mentioned, I know nothing about your type of Z probe, I am afraid
                                • tecnoundefined
                                  tecno @PaulHew
                                  @paulhew
                                  Nothing else than the fault in picture.
                                  I think rc42 is the man behind this probe. It did work connected directly to Mini 5 before.
                                  Is there a way to check endstops if they are open or closed?
                                    jay_s_uk @tecno
                                    @tecno sounds like you need to flip the S value on M569 for the driver you've assigned to Z. Or you need to edit your homing files or endstop position.
                                    And for the heater fault you probably need to PID tune your hotend.
                                    PaulHewundefined tecnoundefined 3 Replies Last reply Reply Quote 0
                                    • PaulHewundefined
                                      PaulHew @jay_s_uk
                                      m119 gives endstop status
                                      • tecnoundefined
                                        tecno @jay_s_uk
                                        @jay_s_uk
                                        Sorry but M303 goes nowhere
                                        • tecnoundefined
                                          tecno @PaulHew
                                          @paulhew
                                          Found it, sorry but I am so new to RepRap so all these commands are twisting myt head 😉
                                          m119
                                          Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop
                                          Above says that there is something wrong in config.
                                          • tecnoundefined
                                            tecno @jay_s_uk
                                            @jay_s_uk said in Toolboard V1.0 error:
                                            M564 and I can move Z as intended -25 goes down below 0
