PWM to 10V via e0heater always gives 10V
CNC
9
29
1.9k
    cjm @larsw
    @larsw A point to note is that if the photos of your converter board on the web are correct, it uses an opto-isolator with a choice of two series resistor values (selected by the jumpers) to match either 5V or 12V-24V.
    The pull-up resistor used in @alankilian’s approach is in series with the opto-isolator’s input resistor and so has to have a low enough value to pass sufficient current to turn on the opto-isolator.
    The 2K or 4K values mentioned by @alankilian connected to the heater supply voltage should be fine.
    However, some opto-isolators have low efficiency so, if you find you’re not getting reliable results, you might want to try setting the board’s jumper to 5V mode.
    undefined 1 Reply Last reply 30 Jul 2021, 08:02 Reply Quote 1
      dc42 administrators @cjm
      @cjm I agree, from the photo it appears that it has an opto isolator for the input. So why is there continuity between the PWM input ground and the output ground?
      undefined 1 Reply Last reply 30 Jul 2021, 13:26 Reply Quote 0
        alankilian @dc42
        @dc42 I think I found a picture of the back of the board, and indeed, both the input and output GND connections are to the same net!
        Ref: Link.
        (And in this photo, PWM might also be shorted to ground Ha ha)
        undefined 1 Reply Last reply 2 Aug 2021, 12:27 Reply Quote 0
          EducatingSavvas @larsw
          @larsw I tried to use a similar type for an older CNC controller of mine and didn't have any luck. I eventually found and used this type which worked:
          Available from the usual places.
          undefined 1 Reply Last reply 29 Aug 2021, 21:27 Reply Quote 0
            zapta
            As a side note, this board reminds me of a similar project by egon.net https://forum.duet3d.com/topic/21680/designing-a-pwm-to-analog-mini-board-for-fans
              larsw @cjm
              @cjm I tried the pull resistor (4.7k) and it worked perfectly.
              Only issue now is, that the 0-10V output max'es out at 8.6V, but I read somewhare that the converter - even though the specs says VIN 12V to 24V needs least 14,6V to reach 10V in output signal, and my powersupply is 12,8V.
              8,6V is close enough - my spindle reaches to max speed at 9V.
              undefined undefined 2 Replies Last reply 2 Aug 2021, 13:24 Reply Quote 0
                dc42 administrators @alankilian
                @alankilian they've made a mistake with that design IMO, by sharing the ground plane with both ground pins even though the input is optically isolated.
                I would be tempted to cut the 4 fingers that join each of the pins I have marked to the ground plane, and connect them together with a wire instead.
                  alankilian @larsw
                  @larsw said in PWM to 10V via e0heater always gives 10V:
                  That's GREAT news!
                  Thanks for keeping up with our ideas and letting us know you got it working.
                  If you want to get to 9 Volts, you can try adjusting the potentiometer on the board.
                  undefined 1 Reply Last reply 3 Aug 2021, 10:46 Reply Quote 0
                    cjm @larsw
                    @larsw Good news! Glad to hear it’s all working now…
                      larsw @alankilian
                      @alankilian said in PWM to 10V via e0heater always gives 10V:
                      I hope somebody else can use these findings. The converter seems to be pretty common.
                      This is with the potentioneter at max, but as I said - good enough.
                        baird1fa @EducatingSavvas
                        @educatingsavvas
                        I just wired up one of these and it works too.
                        One thing to note is that using less than 3000hz seems to result in the generation of a 0-10v signal that the VFD sees as oscillating and then it changes frequencies a lot. It ramps up and down 10’s of hertz.
