    Pictures of water-cooling
    Example setups and prints
    15
    36
    3.4k
    • piperswundefined
      pipersw
      thanks !
      • fmaundefined
        fma
        Guys, could you put links of the pump/tank/etc... you are using? Thanks!
        Frédéric
        tech-ratonundefined 1 Reply Last reply Reply Quote 0
        • DaBitundefined
          DaBit
          I am using a Laing DDC pump. Advantage of that one over the average aquarium pump is it's ability to produce some pressure, allowing the use of 4mm O.D. tubing to distribute the liquid.
          Makes a quite compact setup:
          Pump is not very visible in this picture unfortunately, but it is mounted on a bit of plastic at the left bottom side of the frame:
          My coolant reservoir is an old brake fluid container, nothing fancy. 'Radiator' is currently a unbranded generic Chinese 40x40mm copper waterblock attached to the aluminium frame; works well enough and saves another fan.
          • tech-ratonundefined
            tech-raton @fma
            @fma
            For my delta, i use:
            https://www.amazon.fr/dp/B00VHPADRW/ref=cm_sw_r_cp_apa_i_9IBeEbVMHC36G
            For my corexy, i use:
            This one
            The main problem with these pump are the diameter of the hoses. You will need some adapters.
            • fmaundefined
              fma
              Thanks for links. These pumps with integrated tanks are easier to install.
              Do you know if the Yosoo has a brushless motor, like the SC-300T? Is it possible to under-volt them, to slow them down?
              Frédéric
                tech-raton @fma
                @fma i connected them on the fan connectors. I use the pwm at 60% and both pumps work great. But i can't tell if the motor is brushed or brushless
                • fmaundefined
                  fma
                  Thanks! The SC-300T is brushless, as written on the pump body.
                  Frédéric
                  • piperswundefined
                    pipersw
                    For the SC-300T, what is the operating temperature ?
                    I didn't find it.
                    • laelundefined
                      lael @Nuramori
                      @nuramori Where did you source your self-sealing valves you've got installed on your liquid lines? They look like they would be quite helpful if you ever needed to do hotend maintenance etc.
                      deckingmanundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                      • laelundefined
                        lael @tech-raton
                        @tech-raton I noticed it looks like you are running a silicone hose over some ptfe / similar tube into the quick disconnect fittings. Have you had any leakages or spills from the overlapping union?
                        • o_lampeundefined
                          o_lampe
                          Re: watercooled hotends. One of the most simple design is this. Not sure if it was long term tested, but quite inspiriring.
                          Zatsit delta
                          laelundefined 1 Reply Last reply Reply Quote 0
                            deckingman @lael
                            @lael The self sealing valves look like these https://www.ebay.co.uk/itm/174905154309?hash=item28b928db05:g:KZkAAOSwv91hI4tk. I bought the 6mm version but be warned, one of them leaked!!
                            I also had some leaks after attaching silicone hose to rigid "non barbed" tubing so I use clips (the spring type).
                            laelundefined 1 Reply Last reply Reply Quote 1
                            • Nxt-1undefined
                              Nxt-1
                              If you are looking for high quality quick disconnects I can highly recommend the ones from Koolance. Being full metal, they are quite heavy which might be an important factor for some. They also are not exactly cheap but they do work wonders, have disconnect leakage in the order of a couple little drops and have never failed me.
                              I have a set of QD3 series in my machine but they do offer others as well. https://koolance.com/help-quick-disconnect-shutoff-couplings
                              Duet3D and delta printer enthousiast. Buildlog
                              Looking for Duet3D configuration support, check out Nxt-3D
                              deckingmanundefined laelundefined 2 Replies Last reply Reply Quote 1
                                deckingman @Nxt-1
                                @nxt-1 Thanks for the recommendation - I'll take a look at them.
                                • GeneRisiundefined
                                  GeneRisi @Nuramori
                                  @nuramori Really nice setup! Is the Nimble a sidewinder or a V3 ?
                                  Nuramoriundefined 1 Reply Last reply Reply Quote 0
                                  • Nuramoriundefined
                                    Nuramori @lael
                                    @lael said in Pictures of water-cooling:
                                    They are Colder medical quick disconnects that are dripless.
                                    PLCD16006 Quick-Disconnect Panel-Mount Hose Barb Fitting Body; Valved, 3/8" Tube ID, Acetal
                                    • Nuramoriundefined
                                      Nuramori @GeneRisi
                                      @generisi that’s an old build. I ended up designing my own extruder and that’s been combined with a slice liquid mosquito.extruder
                                      https://imgur.com/a/Gnz00ez
                                      • laelundefined
                                        lael @Nuramori
                                        @nuramori Wow, not cheap. Are they good?
                                        • laelundefined
                                          lael @deckingman
                                          @deckingman kind of like an oetiker / stepless ear clamp?
                                          https://www.ebay.com/itm/184506863154?hash=item2af5774e32:g:hU0AAOSwXCVcXil7
                                          • laelundefined
                                            lael @o_lampe
                                            @o_lampe that is very interesting. Not sure I would trust it... but interesting.
