    Pictures of water-cooling
    Example setups and prints
    15
    36
    3.5k
    • fmaundefined
      fma
      Guys, could you put links of the pump/tank/etc... you are using? Thanks!
      Frédéric
      tech-ratonundefined 1 Reply Last reply Reply Quote 0
      • DaBitundefined
        DaBit
        I am using a Laing DDC pump. Advantage of that one over the average aquarium pump is it's ability to produce some pressure, allowing the use of 4mm O.D. tubing to distribute the liquid.
        Makes a quite compact setup:
        Pump is not very visible in this picture unfortunately, but it is mounted on a bit of plastic at the left bottom side of the frame:
        My coolant reservoir is an old brake fluid container, nothing fancy. 'Radiator' is currently a unbranded generic Chinese 40x40mm copper waterblock attached to the aluminium frame; works well enough and saves another fan.
        • tech-ratonundefined
          tech-raton @fma
          @fma
          For my delta, i use:
          https://www.amazon.fr/dp/B00VHPADRW/ref=cm_sw_r_cp_apa_i_9IBeEbVMHC36G
          For my corexy, i use:
          This one
          The main problem with these pump are the diameter of the hoses. You will need some adapters.
          • fmaundefined
            fma
            Thanks for links. These pumps with integrated tanks are easier to install.
            Do you know if the Yosoo has a brushless motor, like the SC-300T? Is it possible to under-volt them, to slow them down?
            Frédéric
              tech-raton @fma
              @fma i connected them on the fan connectors. I use the pwm at 60% and both pumps work great. But i can't tell if the motor is brushed or brushless
              • fmaundefined
                fma
                Thanks! The SC-300T is brushless, as written on the pump body.
                Frédéric
                • piperswundefined
                  pipersw
                  For the SC-300T, what is the operating temperature ?
                  I didn't find it.
                  • laelundefined
                    lael @Nuramori
                    @nuramori Where did you source your self-sealing valves you've got installed on your liquid lines? They look like they would be quite helpful if you ever needed to do hotend maintenance etc.
                    deckingmanundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
                    • laelundefined
                      lael @tech-raton
                      @tech-raton I noticed it looks like you are running a silicone hose over some ptfe / similar tube into the quick disconnect fittings. Have you had any leakages or spills from the overlapping union?
                      • o_lampeundefined
                        o_lampe
                        Re: watercooled hotends. One of the most simple design is this. Not sure if it was long term tested, but quite inspiriring.
                        Zatsit delta
                        laelundefined 1 Reply Last reply Reply Quote 0
                          deckingman @lael
                          @lael The self sealing valves look like these https://www.ebay.co.uk/itm/174905154309?hash=item28b928db05:g:KZkAAOSwv91hI4tk. I bought the 6mm version but be warned, one of them leaked!!
                          I also had some leaks after attaching silicone hose to rigid "non barbed" tubing so I use clips (the spring type).
                          laelundefined 1 Reply Last reply Reply Quote 1
                          • Nxt-1undefined
                            Nxt-1
                            If you are looking for high quality quick disconnects I can highly recommend the ones from Koolance. Being full metal, they are quite heavy which might be an important factor for some. They also are not exactly cheap but they do work wonders, have disconnect leakage in the order of a couple little drops and have never failed me.
                            I have a set of QD3 series in my machine but they do offer others as well. https://koolance.com/help-quick-disconnect-shutoff-couplings
                            Duet3D and delta printer enthousiast. Buildlog
                            Looking for Duet3D configuration support, check out Nxt-3D
                            deckingmanundefined laelundefined 2 Replies Last reply Reply Quote 1
                              deckingman @Nxt-1
                              @nxt-1 Thanks for the recommendation - I'll take a look at them.
                              • GeneRisiundefined
                                GeneRisi @Nuramori
                                @nuramori Really nice setup! Is the Nimble a sidewinder or a V3 ?
                                Nuramoriundefined 1 Reply Last reply Reply Quote 0
                                • Nuramoriundefined
                                  Nuramori @lael
                                  @lael said in Pictures of water-cooling:
                                  They are Colder medical quick disconnects that are dripless.
                                  PLCD16006 Quick-Disconnect Panel-Mount Hose Barb Fitting Body; Valved, 3/8" Tube ID, Acetal
                                  • Nuramoriundefined
                                    Nuramori @GeneRisi
                                    @generisi that’s an old build. I ended up designing my own extruder and that’s been combined with a slice liquid mosquito.extruder
                                    https://imgur.com/a/Gnz00ez
                                    • laelundefined
                                      lael @Nuramori
                                      @nuramori Wow, not cheap. Are they good?
                                      • laelundefined
                                        lael @deckingman
                                        @deckingman kind of like an oetiker / stepless ear clamp?
                                        https://www.ebay.com/itm/184506863154?hash=item2af5774e32:g:hU0AAOSwXCVcXil7
                                        • laelundefined
                                          lael @o_lampe
                                          @o_lampe that is very interesting. Not sure I would trust it... but interesting.
                                          • laelundefined
                                            lael @Nxt-1
                                            @nxt-1 they look very nice.
