    Pictures of water-cooling
    Example setups and prints
    15
    36
    3.4k
    • fmaundefined
      fma
      Thanks! The SC-300T is brushless, as written on the pump body.
      Frédéric
      • piperswundefined
        pipersw
        For the SC-300T, what is the operating temperature ?
        I didn't find it.
        • laelundefined
          lael @Nuramori
          @nuramori Where did you source your self-sealing valves you've got installed on your liquid lines? They look like they would be quite helpful if you ever needed to do hotend maintenance etc.
          deckingmanundefined Nuramoriundefined 2 Replies Last reply Reply Quote 0
          • laelundefined
            lael @tech-raton
            @tech-raton I noticed it looks like you are running a silicone hose over some ptfe / similar tube into the quick disconnect fittings. Have you had any leakages or spills from the overlapping union?
            tech-ratonundefined 1 Reply Last reply Reply Quote 0
            • o_lampeundefined
              o_lampe
              Re: watercooled hotends. One of the most simple design is this. Not sure if it was long term tested, but quite inspiriring.
              Zatsit delta
              laelundefined 1 Reply Last reply Reply Quote 0
                deckingman @lael
                @lael The self sealing valves look like these https://www.ebay.co.uk/itm/174905154309?hash=item28b928db05:g:KZkAAOSwv91hI4tk. I bought the 6mm version but be warned, one of them leaked!!
                I also had some leaks after attaching silicone hose to rigid "non barbed" tubing so I use clips (the spring type).
                laelundefined 1 Reply Last reply Reply Quote 1
                • Nxt-1undefined
                  Nxt-1
                  If you are looking for high quality quick disconnects I can highly recommend the ones from Koolance. Being full metal, they are quite heavy which might be an important factor for some. They also are not exactly cheap but they do work wonders, have disconnect leakage in the order of a couple little drops and have never failed me.
                  I have a set of QD3 series in my machine but they do offer others as well. https://koolance.com/help-quick-disconnect-shutoff-couplings
                  Duet3D and delta printer enthousiast. Buildlog
                  Looking for Duet3D configuration support, check out Nxt-3D
                  deckingmanundefined laelundefined 2 Replies Last reply Reply Quote 1
                    deckingman @Nxt-1
                    @nxt-1 Thanks for the recommendation - I'll take a look at them.
                    • GeneRisiundefined
                      GeneRisi @Nuramori
                      @nuramori Really nice setup! Is the Nimble a sidewinder or a V3 ?
                      Nuramoriundefined 1 Reply Last reply Reply Quote 0
                      • Nuramoriundefined
                        Nuramori @lael
                        @lael said in Pictures of water-cooling:
                        They are Colder medical quick disconnects that are dripless.
                        PLCD16006 Quick-Disconnect Panel-Mount Hose Barb Fitting Body; Valved, 3/8" Tube ID, Acetal
                        • Nuramoriundefined
                          Nuramori @GeneRisi
                          @generisi that’s an old build. I ended up designing my own extruder and that’s been combined with a slice liquid mosquito.extruder
                          https://imgur.com/a/Gnz00ez
                          • laelundefined
                            lael @Nuramori
                            @nuramori Wow, not cheap. Are they good?
                            • laelundefined
                              lael @deckingman
                              @deckingman kind of like an oetiker / stepless ear clamp?
                              https://www.ebay.com/itm/184506863154?hash=item2af5774e32:g:hU0AAOSwXCVcXil7
                              • laelundefined
                                lael @o_lampe
                                @o_lampe that is very interesting. Not sure I would trust it... but interesting.
                                • laelundefined
                                  lael @Nxt-1
                                  @nxt-1 they look very nice.
                                  • tech-ratonundefined
                                    tech-raton @lael
                                    @lael nope, no leakage. But in my opinion, it would be better to have a real fitting. I'm gonna change it soonish.
                                      T3P3Tony administrators @lael
                                      @lael @o_lampe that join has never leaked on my prototpye and the cooling is sufficient for PLA&PETG printing (not tried anything else). It is incredibly simple and elegant.
                                      • laelundefined
                                        lael @T3P3Tony
                                        @t3p3tony @o_lampe - thanks - I've got a test rigged up with FEP hard tubing going into a mosquito liquid, and silicone tube over it just like this. I did add two oetiker clamps on them - I was surprised the FEP handled the pressure, but it seems fine, and no leaks with a 7 day continuous test time so far. If I firmly hold both sides I can still slowly slide the silicone over the inner tube, but I don't think it will come loose on its own.
                                        • CNCModellerundefined
                                          CNCModeller
                                          I water cooled my Wanhao D4s as I found the fans weren't lasting very long with the enclosed setup for printing ABS. The enclosure sits at about 60c with the extended bed at 100c. This is very reliable. The aluminium block is drilled with a copper pipe running through it and I've used heat sink compound to improve conductivity in that assembly.
                                          My channel video on it is here: https://youtu.be/zAQjekM1TrM
                                          16306884095763708217688729197846.jpg undefined16306885745958885769252376342854.jpg 16306886039343429015258382143410.jpg
                                          Polar Duet3 Mini + 1HCL
                                          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
                                          Wanhao D4S: Duet2
                                          https://forum.duet3d.com/post/296755
                                          K40 Laser, Duet2
                                          https://forum.duet3d.com/post/312082
                                          Wanhao D5S
                                          https://www.youtube.com/CNCModellerUK
                                          • Nuramoriundefined
                                            Nuramori @lael
                                            @lael they’ve been great, and I only need two sets. They are also often used in food service to connect/disconnect fluids like soda syrup, beer taps, etc.
                                            Like you said, it allows me to quick disconnect the hotend for whatever reason without any major disassembly, or if I want to locally drain it without emptying the entire loop.
