    Advanced nozzle design
    3D Printing General Chat
    15
    48
    4.9k
      deckingman @plasticfactory
      @plasticfactory Re your combined nozzle/heater block idea, this is effectively what a Diamond mixing hot end is and IMO, one of its major drawbacks. Changing a nozzle when it wears out or for other reasons, takes hours rather than seconds (and costs a relative fortune compared to simply changing the nozzle). It also makes it difficult if not impossible to achieve both high thermal conductivity needed to melt the filament with high abrasion resistance needed for some filaments.
      • mikeabuilderundefined
        mikeabuilder
        Regarding the basic premise of following the design rules for an extrusion die - are you referring to dies used for things like aluminum? I'm not an expert, but my understanding is that, those metals are not melted in the process, but are cold-formed as they go through the die. Also, in the case of 3D printing, the plastic is heated into it's plastic region and is not liquid, so I is the laminar vs turbulent flow question really applicable? I guess I should pull out my old heat transfer and fluid mechanical textbooks and see what the equations say. Anyone know a resource for the mechanical properties of our plastics of interest at various temperatures?
        plasticfactoryundefined 1 Reply Last reply Reply Quote 0
        • plasticfactoryundefined
          plasticfactory @mikeabuilder
          @mikeabuilder I am using extrusion die standards typical for plastic extrusion; the same standards we start with when designing dies for our extrusion machinery, scaled down. For basic mechanical properties of material, (in my opinion) the best starting point is a) knowing the grade of resin specifically, and b) searching here: https://plastics.ulprospector.com/ (account required, its free) Though this will not provide properties at various temperatures, only its proper processing and formed states. Either way its an excellent resource for this type of thing.
            plasticfactory @plasticfactory
            Prepped for the HSM:
            plasticfactoryundefined 1 Reply Last reply Reply Quote 2
              @plasticfactory A little late, but small update for today. The machining is finished on the new nozzle, and started another one for a proper cross section (quality check that will ultimately make a good photo). I feel confident previous issues are resolved after putting it on our inspection setup. Now that its in my hands I should be able to start doing actual prints! More updates and photos to come throughout the week.
              If there are any tests in particular anyone would like me to do, please share!
              As for the pictures, the "C" shaped steel is a very simple fixture made to screw a nozzle into and machine from. The black piece is the finishing electrode that reflects the shape of the machined area (the bulbous areas are fluid buildup).
              giostarkundefined jens55undefined 2 Replies Last reply Reply Quote 1
              • giostarkundefined
                giostark @plasticfactory
                @plasticfactory
                Jingle tools !!! 😀
                • jens55undefined
                  jens55 @plasticfactory
                  @plasticfactory, what does it take to generate an electrode that fine that by all rights should disintegrate when you look at it ?
                  Thanks for that picture! Amazing!
                    plasticfactory @jens55
                    @jens55 We use a high speed mill designed for cutting graphite. It utilizes high cutting speeds, lower forces and a flushing system specifically for removing graphite dust. A proper graphite setup really is the difference between being able to do general EDM work, and to be able to do something like this (not to say it couldn't be done without).
                    It's definitely a difficult part to make; the last nozzle came out better but we are running one more through, but breaking the electrodes up into 2 -- one for the major ID, and one for the minor. This should help things out quite a bit. Just part of the development process! Once the process is validated it will be highly repeatable.
                      Quick update -- had some improvement on the last samples, but in doing so identified areas for further improvement. We are breaking the electrode up into 2 pieces and sampling again early next week. I'm optimistic this will be one worth sharing!
                      EDIT: rather than bumping this thread further I'll use this as an update. Currently, our EDM department is backlogged after receiving a wave of production demand. We have electrodes cut, but no EDM machining will take place for ~3 weeks. To anyone particularly intrigued by this project, do not worry -- it is line one for our AM prototype development.
                      JoergS5undefined 1 Reply Last reply Reply Quote 3
                      • JoergS5undefined
                        JoergS5 @plasticfactory
                        @plasticfactory your thread is so interesting, that I bought a book about micro EDM (from Sidpara/Malayath), please continue, I am curious to see where this goes!
                        plasticfactoryundefined 1 Reply Last reply Reply Quote 1
                          plasticfactory @JoergS5
                          @joergs5 Considering the stage this project is in it makes me exceedingly happy it inspired someone to learn more about these machining techniques. Feel free to private message me if you have any questions.
                          That book is in our small technical library, but I have not personally read it.
                          Here is another great place to start, because it covers the basics without over simplifying anything:
                          https://reliableedm.com/handbook.php
                          EDIT: and so much for me not bumping the thread, lol
                          • JoergS5undefined
                            @plasticfactory said in Advanced nozzle design:
                            thank you, I'll look into it, and thank you for your offer!
                              plasticfactory
                              Finally, an update. After finding some machine time, we were able to complete the first nozzle. We inspected the orifice with a Keyence IM inspection system, and compared it to 5 leading brands who also make nozzles (to get an idea of how close to nominal we realistically need to be). We wound up at 0.410mm, which is almost exactly as close to nominal as the best commercially available nozzles inspected. We will definitely make more, as electrode sizing is why we aren't as close to .400 as I'd like. Realistically, +/- .001mm should be achievable. However, testing can finally commence. As an aside, the most "premium" (re. expensive) nozzles inspected were the worst, dipping down as low as .35mm ID.
                              Attached is a photo of the electrodes used, and inspection of the EDM machined nozzle. Testing is next, then I will cut more cross sections to share. These should be much, much cleaner on the inside than what is in OP.
                              CCS86undefined 1 Reply Last reply Reply Quote 6
                              • CCS86undefined
                                CCS86 @plasticfactory
                                @plasticfactory
                                Very cool. We have an IM at our shop, with a rotary axis as well.
                                  plasticfactory @CCS86
                                  First, apologies for the lack of updates. I started doing testing today, and have reached out to various content creators hoping for some assistance with this side of things. Time to do testing has just not been on my side.
                                  Today I did some very simple vase mode prints to check two things:
                                  1. potential change in surface finish
                                  2. ability to take objective measurements of layer width
                                  The prints were done on an E3D toolchanger, using a Hemera extruder and Copper V6 block. Both prints were done with the exact same hardware, only the nozzle being different. I used a hardened steel E3D V6 nozzle as the control. The material was the same spool of Prusament PLA, fed closed loop from a material dryer.
                                  First impression: the ADV nozzle produces a significantly more matte finish. Though "improvement" is completely subjective, it objectively hides layer lines more than the gloss, especially in person. The photo posted was spliced together as both parts were taken under identical lighting conditions.
                                  The next step is to use our IM to take measurements of wall thickness and layer width, to determine if there is any significant difference in extrusion consistency (visually, I'm not expecting much difference).
                                  Anecdotally, the ADV nozzle oozes considerably less than the V6. The next steps will be various retraction prints, sans retraction, to evaluate stringing/oozing.
                                  Finally, I had some mushrooming at the bottom of the V6 print. This is obviously not a fault of the nozzle.
                                  I'm not expecting too much enthusiasm over the initial results, but I'm happy so far and am very excited to get to the retraction tests. My first reaction is that will be the area most improved.
                                  ADV left, E3D right
                                  plasticfactoryundefined 1 Reply Last reply Reply Quote 5
                                    @plasticfactory Last quick update before Monday. From our QE: "the ADV nozzle is more consistent with layer width, but I will do more inspections Monday and generate a proper report".
                                    I will of course share said report, with data, here. This will include how the inspection was conducted. But that was a nice message to cap off the week.
                                    EDIT: This probably doesn't mean much right now as it was a "first guess" way to check this, but here is the image I was provided:
                                    Top is ADV, bottom V6
                                    This is an overall straightness measurement. So it doesn't account for the exact deviation from each layer line, but would indicate that overall it is less "wavy" (ie, more consistent extrusion width).
                                    I'm open to suggestions on what types of measurements to take, or prints to use to take said measurements.
                                    EDIT 2: I was also sent some inspections comparing actual individual layer lines. I will share those images and preliminary findings shortly. Similar conclusion -- ADV is more consistent. Is it an appreciable improvement? Maybe not, but it appears to be an improvement. I hope to have real conclusions by the middle of next week (but if you have kept up with this thread, it could be in 2023...)
                                    CCS86undefined 1 Reply Last reply Reply Quote 2
                                    • CCS86undefined
                                      @plasticfactory
                                      The point snapping on the ADV is better synchronized to the peaks and valleys of the layer lines. It falls out of sync on the V6 nozzle, which may be hiding straightness error.
                                      I should throw a print on our IM sometime.
                                        @ccs86 Yeah, I definitely see that -- good eye. I probably got too excited with the last post, but the other images, coupled with this, are promising. I will refrain from making conclusions until we get a proper inspection next week.
                                          plasticfactory
                                          Disclaimer: A sample size of 1 is not enough to draw distinct conclusions. Everything I am sharing are simply preliminary results and I will do many prints/inspections before making any clear statements of capability.
                                          Based on user CCS86's suggestion, we performed another straightness test with more data points:
                                          Slight reduction, but ~12% "straighter". Eventually we will do more thorough inspections on this. I was considering using our extrusion measurement systems to test it not on a print, but in line (like a normal plastic extruder).
                                          Next up are simple stringing tests, pictured here:
                                          ADV Left, V6 Right
                                          These prints were done on the same hardware, with same the same Gcode file. Both prints were done with no retraction. Prusament PLA, 200*, 15mm/s print, 180mm/s travel.
                                          Clearly, the ADV oozes considerably less, almost none at all. I do notice "fuzz" on the edges, and what appears to be occasional heat dissipation issues from the ADV nozzle. I suspect this is due to the end taper geometry not being correct for a V6 0.4 orifice nozzle (as mentioned by another user earlier in the thread). The next step is to EDM or surface grind this taper to the correct geometry to eliminate this as a variable. Nozzle taper comparison below:
                                          I very much welcome feedback!
                                          HebigTundefined Darth Scoobundefined 2 Replies Last reply Reply Quote 5
                                          • HebigTundefined
                                            HebigT @plasticfactory
                                            This post is deleted!
