    Tired of my delta printer...
    34
    2.4k
    • zaptaundefined
      zapta @fcwilt
      @fcwilt, yes, the Trident is a newer design.
      V1 and V2 mean Voron1 or Voron2, as in a product line rather than a version. It's a common source to confusion hence the move to real names such as switchwire and trident.
      The main differences are that trident has a bed that moves up/down on three leadscrews while V2.4 (version 4 of Voron2) the bed is static at the bottom and the head moves up/down on 4 belts.
      There are theoretical pros and cons for each but the general thinking is that they have about the same material capabilities, speed and quality and the difference is a matter of personal taste or 'coolness'.
      Here is the Trident announcement https://youtu.be/Be4GaSCAGU0 , the guy at the bottom left is the Voron founder.
      • peirofundefined
        peirof @zapta
        @zapta the main problem, its I cant print... My delta, its out of service.... I have see some printed kits....
        The idea its scrap my delta and use some of the components in New core xy printer...
        engikeneerundefined 1 Reply Last reply Reply Quote 0
        • fcwiltundefined
          fcwilt @zapta
          @zapta
          Thanks much.
          • engikeneerundefined
            engikeneer @peirof
            @peirof another option is the BLV MGN cube. You can get kits on Aliexpress that are reasonably complete. It also uses a Duet WiFi by default (though all the kits will come with cloned boards, but you can get them without the board and buy a proper one)
            The design and documentation might be slightly less complete than the Vorons, but I think its a slightly simpler machine which might be easier to setup.
            Either that got go for a complete printer out of the box e.g. an Ender 5
            i3 clone with a bunch of mods
            • o_lampeundefined
              o_lampe @peirof
              @peirof said in Tired of my delta printer...:
              I'm tired of my delta printer....
              The last thing is that another duet board has fallen, and it's the second...
              I'd start over building a new printer only when I've found the reason for the Delta to grill Duets.
              If it's lack of knowledge or some misunderstood documentation, your next project will fail, too. 😞
              Sorry, if it sounds harsh, but I'm trying to save you some money..
              peirofundefined 1 Reply Last reply Reply Quote 0
              • Yveskeundefined
                Yveske @peirof
                @peirof Have a look at the Rat Rig V-Core 3
                Default: https://www.ratrig.com/3d-printing-cnc/3d-printer-kits/v-core3default.html
                Configurable: https://www.ratrig.com/3d-printing-cnc/3d-printer-kits/v-core3configurable.html
                • peirofundefined
                  peirof @o_lampe
                  @o_lampe
                  think you have reason....
                  It is the great fear that I have, that I mount a new printer, and that for something that does not do well ... I will burn a Duet plate again ... But the other option is almost worse, if I change the Duet plate, in my current one printer, without changing practically anything ... I'm condemned to fry another board ... and I don't know how to get out of that loop .... when the Duet v2 board arrived, I was happy because it had more fuses than 1, and I thought that he was protected ... but apparently it wasn't enough.
                  My biggest fear, mounting a new printer, and burning another duet board again .... but I DON'T know how to deal with the problem
                    engikeneer @peirof
                    @peirof main thing to do is to test. Get a multimeter and test all your connections. Check for shorts to ground, shorts to Vin etc.
                    Reading your other thread, it sounded like you had a short somewhere in your hotend wiring which needed diagnosing and fixing before the Duet was powered up... even if the Duet has fuses, they take a (small) amount of time to blow so won't always protect your board from that kind of damage
                    o_lampeundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
                    • o_lampeundefined
                      o_lampe @engikeneer
                      @engikeneer said in Tired of my delta printer...:
                      I haven't seen that thread, but another where a Duet1 board has a burnt driver chip. The error seems to be in wiring/electronics mishaps.
                      • JamesMundefined
                        JamesM
                        https://3dfused.com/diycore/
                        Available in different sizes from 200x200 up to 500x500. All metal design.
                        • peirofundefined
                          peirof
                          Thanks to all...
                          For the moment I have 2 preselected printers:
                          • Rat Rig V-Core 3
                          • Voron Trident
                          Its easier purchase Rat Rig components...
                          Some options of those printers?
                          • zaptaundefined
                            zapta @peirof
                            I would say, stay away from bowden extruders, go with direct ones.
                            My 2c.
                            • peirofundefined
                              peirof @zapta
                              I'm studying the options, for the moment I think I'm staying with the Ratrig...
                              Maybe I like the idea of the Voron better... But the configured Ratrig website, makes getting the components much easier than the voron.
                              I have a doubt, after using the configurator, I do not know if you have tried it ...
                              And it is that when choosing the board gives you the option of Duet v3 mini (it is the idea I had, for that perfect face) but adds:
                              • Duet 3 mini
                              • v1 WiFi with Duet v3 (I suppose I guess this will be to add WiFi to the duet 3 mini)
                              • Dual steppers expansión board (Ratrig uses 5 steppers motors, duet 3 mini have 5 drivers... Why this expansión board?)
                              Someone can give me feedback about these printer?
                              Thanks
                              • zaptaundefined
                                zapta
                                It's possible that they use 3 independent Z motors? (+ two for X/Y and one for extruder) and thus needs the expansion to drive the 6th motor.
                                The 'V1' is the version of the Duet Mini5+ Wifi. Github shows two versions, 1.0 and 1.01. Not sure what the differences are.
                                https://github.com/Duet3D/Duet3-Mini5plus
                                • Gixxerfastundefined
                                  Gixxerfast
                                  I think it depends a bit on what material you want to print. Do you want to print ABS/ASA/PC then you'll want an enclosed printer.
                                  I would recommend a Voron for that, a Trident or the 2.4. Yes, the 2.4 has some challenges, it has a flying gantry and four z-motors but it's very well designed and together with some mods it's a print-and-go machine. It requires that you understand it though, it's not an Ender 3.
                                  As with all enlosed printers that get's a higher chamber temp you will have heat expansion that can be a problem if you don't understand it. It can be handled with Auto Z-correction and mesh compensation with large prints. Or you always print with the same circumstances.
                                  The community is large or rather getting huge, though we are a fewerbunch using Duets but it works really nice with the 1LC toolboard. Just four cables to the toolhead. It is though an DIY printer for people who want to build a printer themself.
                                  Tuned it can produce great prints. Small example in ABS (greatly enlarged. It's about 3 cm across):
                                  If you want mainly a PLA-printer I would go with maybe another machine, open frame or where the enclosement is more of an afterthought.
                                  Voron V2.4 (#1317) with Duet 3 Mini5+ Wifi and 1LC v1.1 Toolboard
                                  Voron V0.1 (#637) with Duet 3 Mini 5+ Wifi and 1LC v1.2 Toolboard
                                  Ender 3 Pro with BTT SKR-2 + RRF
                                  • peirofundefined
                                    peirof @Gixxerfast
                                    @gixxerfast said in Tired of my delta printer...:
                                    I see, that you have a Voron....
                                    How did you get the materials?
                                    Did you take the BOM from the web, and you were buying them separately?
                                    Did you buy a pack? Web?
                                    The printed parts ... did you buy them, or did you print them?
                                    As I have said, I like the Voron more, but finding the materials to make it seems more complicated, although I already have part of them ...
                                    Gixxerfastundefined 1 Reply Last reply Reply Quote 0
                                    • JoergS5undefined
                                      JoergS5 @engikeneer
                                      I have started to build me a little teststation, where I test all electronic components before I use it with a Duet:
                                      • endstop
                                      • steppers (with Arduino and Pololu)
                                      • SSR
                                      • hotend circuit
                                      • wires with crimping (I've still problems to crimp)
                                      So I know that the electronics are ok (no short circuits, right poling) before I "set the Duet under danger".
                                        Gixxerfast @peirof
                                        @peirof I bought the parts from mainly a couple of sources, Fermio (DE), Lecktor (EE) and AliExpress (Powge and Trianglelabs and a few more). Then a few bits here and there and the Duet boards from Denmark.
                                        I built an Ikea Lack enclosure for my Ender 3 and printed the first parts on that in ABS/ASA. Then I have reprinted most parts on the 2.4 itself as I have modified it.
                                        Yes, there are so many now that want Voron parts, but checkout the Voron Discord there you will get heap of info, almost too much 🙂 A very friendly and helpful bunch https://discord.gg/voron
                                        • peirofundefined
                                          peirof @JoergS5
                                          @joergs5 said in Tired of my delta printer...:
                                          Seems a good tip...
                                          but... how do you know if a component its wrong? Check continuti, voltage?
                                          • JoergS5undefined
                                            JoergS5 @peirof
                                            At the moment it depends on the component, but in most cases yes. Sometimes only a check whether it works. And I'm trying to do the best to stay at a specific color coding if possible, black always ground, red 24/12/5V/3.3V, steppers black+green together. (that's easy to remember for me: black and green political parties in germany).
