    Help with new custom printer - Prints have ringing around them
    32
    2.1k
    • oliofundefined
      oliof
      If haven't PID tuned your bed heater yet, now is the time. Bang bang controlled heating can cause enough expansion and reduction of the bed heater that you will get z banding artifacts.
      • JoergS5undefined
        JoergS5 @MrAwesome987
        This post is deleted!
        • martin7404undefined
          martin7404 @MrAwesome987
          @mrawesome987 well this type of linear guide uses C shaped bushings and as far the rods are mounted on Aluprofile that is not straight in terms of hundreds of millimeter , so they can go slightly out of alignment .
          Muldex IDEX Duet2+Duex5
          Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
          Sapphire Pro with Duet2, with closed-loop motors
          custom high temp E3D tool changer with Duet2+Duex
          • jumpedwithbothfeetundefined
            jumpedwithbothfeet @MrAwesome987
            @mrawesome987 glad you found the problem, it is looking a lot better 🙂 do the lead screws still appear bent as they move on the machine? or has that gone now? as @oliof has suggested a bed PID tune is next it`s easy and most importantly free to do!
            6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
            MrAwesome987undefined 1 Reply Last reply Reply Quote 0
            • MrAwesome987undefined
              MrAwesome987 @jumpedwithbothfeet
              @jumpedwithbothfeet said in Help with new custom printer - Prints have ringing around them:
              The lead screws are definitely still looking bent. I'd like to replace them.
              I am looking at the Misumi lead screws, but I'm having a hard time speccing what I need. The lead on my current screws is 2.54 mm, which is probably a bit low, right? They offer carbon steel and stainless. Any advantage to carbon steel?
              Edit: I did PID tune the bed when I first configured it, although I PID tuned it for 60C, and I've been running it at 90C. Is that an issue?
              • mrehorstdmdundefined
                mrehorstdmd @MrAwesome987
                @mrawesome987 now check this video on fixing the Z surface smoothness:
                https://www.youtube.com/watch?v=a3oQy6v3MrA
                • zaptaundefined
                  zapta @MrAwesome987
                  @mrawesome987, here is a printer that also has that Z sync belt so probably the idea is feasible if you make it right.
                  https://youtu.be/CkTgm4AQjhY?t=401
                    mrehorstdmd @zapta
                    That z sync belt is interesting, but I'm not sure why you'd want to use that instead of a single motor driving both screws, which would eliminate any potential problems with the motor interactions. If getting sufficient torque to lift the bed is the issue, one higher torque motor would probably cost less than two smaller motors, and then you'd only need one cable and driver.
                    • zaptaundefined
                      zapta @mrehorstdmd
                      @mrehorstdmd said in Help with new custom printer - Prints have ringing around them:
                      Lower backlash since each motor holds on the exact microstep?
                      Possibly could keep the belt loose and use it to avoid large skew when the motors are off, with automatic two points bed leveling on print start to get the motors in perfect sync.
                        mrehorstdmd @zapta
                        @zapta I have a machine with two Z screws that uses a single drive motor to lift the X axis. It absolutely never tilts. Over the last 6 or 7 years that the printer has been in use I've had to re tram the X axis two or three times after taking the X axis off the machine for modifications.
                        If you use two motors and leave the belt loose, you're allowing the motors to move independently, a small amount (a backlash amount?). If you have to run a sync routine to force the screws back into sync, what did you gain by adding the belt?
                          MrAwesome987 @mrehorstdmd
                          @mrehorstdmd I agree with this I think.
                          My original thinking with the sync belt and two motors was that it would be beneficial in two ways:
                          • More torque to move the bed frame
                          • Sync the two lead screws so that they can't skip steps (or at least can't skip steps individually)
                          • Remove the possibility of turning one side without the other accidentally
                          The more I think about it, the more I am interested in moving to a single motor setup, with a much smaller pulley on the motor. Mostly for the reasons below:
                          • Probably more consistent that two motors?
                          • Remove the weight from directly on top of the motors, as it is now. Is this a huge issue? I'm not sure. Does anyone know what kind of force a Nema 23 can withstand long-term directly on the shaft?
                          As for the bent lead screw issue, I have reached out to the supplier I purchased them from a few months ago, and they seem to be willing to replace them. If that doesn't work out, I'll purchase new ones from a different, more reliable source.
                          While I wait for the issue above to resolve, I have been working to try to tune it to print decently. This has been causing some headache, but that's expected.
                          I have been testing by printing an XYZ 20mm cube, and the extrusion seems to be inconsistent. Most obviously is the corners.
                          The block on the left had PA set to .025, and the block on the right had PA set to .075. This produced a noticeable improvement, but does this sound like too much? I'm using a Hemera with Volcano, at .8mm nozzle.
                          Of course, I forgot to get the config.g and I'm at work now. I'll try to upload that later this afternoon.
                          Thanks for your help guys.
                            MrAwesome987
                            Here's my most recent config:
                            ; Configuration file for Duet WiFi (firmware version 3.3)
                            ; generated by RepRapFirmware Configuration Tool v3.3.4 on Sat Oct 09 2021 23:56:58 GMT-0400 (Eastern Daylight Time)
                            M575 P1 S1 B57600                              ; enable support for PanelDue
                            G90                                            ; send absolute coordinates...
                            M83                                            ; ...but relative extruder moves
                            M550 P"500x500"                                ; set printer name
                            M669 K1                                        ; select CoreXY mode
                            M552 S1                                        ; enable network
                            M586 P0 S1                                     ; enable HTTP
                            M586 P1 S0                                     ; disable FTP
                            M586 P2 S0                                     ; disable Telnet
                            M569 P0 S0                                     ; physical drive 0 goes backwards
                            M569 P1 S0                                     ; physical drive 1 goes backwards
                            M569 P2 S1                                     ; physical drive 2 goes backwards
                            M569 P4 S1                                     ; physical drive 4 goes forwards
                            M584 X0 Y1 Z2 E4                               ; set drive mapping
                            M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                            M92 X80.00 Y80.00 Z1259.84 E420.50             ; set steps per mm
                            M566 X900.00 Y900.00 Z100.00 E2000.00            ; set maximum instantaneous speed changes (mm/min)
                            M203 X8000.00 Y8000.00 Z120.00 E3500.00        ; set maximum speeds (mm/min)
                            M201 X1200.00 Y1200.00 Z400.00 E5000.00            ; set accelerations (mm/s^2)
                            M906 X1800 Y1800 Z2000 E1330 I30               ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                        ; Set idle timeout
                            M208 X0 Y0 Z0 S1                               ; set axis minima
                            M208 X490 Y490 Z875 S0                         ; set axis maxima
                            M574 X1 S1 P"xstop"                            ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                            M574 Y2 S1 P"ystop"                            ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                            M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
                            M591 D0 P1 C"e1stop" S1                        ; configure filament endstop for e1 extruder on low end
                            ; Z-Probe / Compensation
                            M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
                            M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X0 Y-35.56 Z2.650                        ; set Z probe trigger value, offset and trigger height
                            M557 X25:475 Y25:450 S25                       ; define mesh grid
                            M376 H5
                            M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                            M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
                            M140 H0                                        ; map heated bed to heater 0
                            M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                            M308 S1 P"e1temp" Y"thermistor" T100000 B4138  ; configure sensor 1 as thermistor on pin e1temp
                            M950 H1 C"e1heat" T1                           ; create nozzle heater output on e1heat and map it to sensor 1
                            M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                            M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                            M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                            M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                            M563 P0 S"Extruder 1" D0 H1 F0                 ; define tool 0
                            G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                            G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                            M572 D0 S0.025                                ;set pressure advance
                            M501
                            • fcwiltundefined
                              fcwilt @MrAwesome987
                              @mrawesome987 said in Help with new custom printer - Prints have ringing around them:
                              @jumpedwithbothfeet Just wanted to make sure both steppers are always synced. Is that a problem? It made sense when I designed it, is it overkill?
                              Coupling them with a belt like that is generally fine but I don't like to do it above a flexible coupler as it puts sideways forces on them they may not be designed to handle.
                              Have you tried it without the belt?
                              As to lead screws there can be a large difference between cheap Chinese ones and ones from other sources.
                              Example Lead Screw Specs
                              Notice in the chart from the link above they specify things like the accuracy of movement per turn.
                              Also this company has "good, better, best" offerings. - so to speak.
                                MrAwesome987 @fcwilt
                                @fcwilt said in Help with new custom printer - Prints have ringing around them:
                                Yes, one of my images above shows the difference with and without the belt tensioned. It was definitely a huge part of the problem, but the issue is still not 100% cured, which I attribute to the massively bent lead screws. I have ordered some solid couplers and am also getting replacement lead screws from the place I originally ordered them from. I am hopeful that they will be better, but if not, I'll order some from elsewhere. Thanks!
                                On my most recent XYZ cubes, I am still fighting the same quality issues, ignoring the Z wobble issue for now (since that's to blame on the lead screws). This is one of the most recent cubes:
                                I cant seem to get rid of the bad corners. I have tried both Pressure Advance (.025 up to .1), more retraction (currently at 2.5mm @ 3000mm/m), rotating the print on the bed (no real change), slower print (no change), etc.
                                Any suggestions?
                                Thanks!
                                  MrAwesome987
                                  Benchy for reference:
                                  jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
                                    @mrawesome987 did you remove the leadscrews to check them for straightness?
