    InputShaping-Plugin-0.2.0-pre7 released
    Plugins for DWC and DSF
    13
    32
    2.2k
    • mfs12undefined
      mfs12
      Hey,
      next version released. I still didn't leave the experimental realm, so be careful and don't be to wild with switch tabs and clicking while something is being processed.
      Please read the release notes and the howto first!!!
      release notes for inputshaping plugin 0.2.0-pre7
      This work is based on the original acceleration plugin. Input shaping plugin tries to take
      the input shaping calibration to a next level.
      The current state is still EXPERIMENTAL!!!
      Although it's experimental it brings already some handy features which is why i
      am doing this release. Therefore please comment, give feedback, report bugs and share your
      ideas.
      requirements
      • Duet Web Control 3.4.0-b6
      • RepRap Firmware 3.4.0-b6
      features
      • restructre plugin to use vue components
      • added test configuration component
      • added recorder component
      • added chart component
      • use object model to determine status of test
      • added add/delete of algorithm configurations
      • added add/delete/select of records
      • added add/delete/select of sessions
      • display test parameters in chart component
      • allow records with differing samples rates of up to 1%
      • cleaned up debugging output
      • added localization
      • home device only if not homed
      • improved ui layout
      • added component to manage multiple sessions
      • added more parameter validation for test and algorithm
      • disable tab record tab when no algorithms defined
      • disable tab chart when no records available
      • improved error reporting
      • localized date-timestamps
      • added integrals for each axis
      • skip algorithm test which already have test record (speed improvement, easier understanding)
      • improved editing note in configuration tab
      • cleaned input fields (ids or not editable but only names)
      • added recommendation support
      • make deletion of accelerometer files configurable
      bugs
      • fixed initial filtering of records by axis
      • fixed session cleanup when session is deleted
      • fixed data handling when swapping sessions
      • fixed can address handling (needs more testing)
      • fixed record integrity when referenced algorithm is changed
      • fixed CAN address handling when address is null
      • fixed one-time homing for some machines
      known issues
      • parameter validation doesn't cover every situation
      downloads
      • https://github.com/mfs12/DuetWebControl/releases/tag/inputshaping-plugin-0.2.0-pre7
      howto
      initialize session
      • switch to tab "initialize"
      • create a new session or
      • select an available session
      configure session
      • switch to tab "configure"
      • configure your session session
      • configure test parameters
      • add as many input shaping algorithm configurations as you like
        • more than one per algorithm are allowed
        • this is good to compare different input shaping configuration of the same algorithm
      • CAUTION: once a record in a session exists test parameters can't be changed anymore.
      record profiles
      • switch to tab "record profiles"
      • press "run" button and wait until recording is done
      frequency analysis
      • switch to tab "frequency analysis"
      • in "acceleration records" section you see a list of profiles recorded
        • clicking on the entry DELETEs it form the session!!! (it is lost!!!)
      • in "filter" section the show/hidden graphs are displayed
        • un-checking an axis will hide or show all charts of an axis group
      • in chart section
        • individual graphs can be shown or hidden by pressing the colour next to the name
      • press "FFT" button to show FFT representation of the graph
      • press "Time" button to show time representation of the graph
      recommendations
      • switch to tab "recommend"
      • select a record of type "none" from the first table
      • run recommendations, thism might take a while...
      • sort second table with recommendations by integral
      • ideally the record with the smallest integral should be provide the best configuration
      • add configuration to session
      • switch to tab "configure" to review added configurations
        • see section "configure session"
      limitations
      • currently no data is stored permanently!!!
      • everything is volatile so avoid hitting browser's reload
      what's next?
      Potential next steps are
      • store session in a local file or in browser's local storage or
      • load session from local file or browser's local storage
      • recommend input shaping parameters
      • improve input validation
      • add translations
      Visit me on github at https://github.com/mfs12/
      Alex.crundefined 1 Reply Last reply Reply Quote 1
      • Alex.crundefined
        Alex.cr @mfs12
        @mfs12
        Nice job. Works great. The recommendations section is particularly interesting.
        Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
        • CNCModellerundefined
          CNCModeller
          Hi All,
          I'm getting Error: M956: Response timeout: CAN addr 123, req type 4014, RID=6.
          Any thoughts on what this is related too? It used to work with pre6.
          I think it could be related to I'm measuring a polar printer bed and I now have limits on bed acceleration and rotation speed since the bug was fixed in M669.
          Any thought would be much appreciated.
          Cheers
          Barry M
          Polar Duet3 Mini + 1HCL
          https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
          Wanhao D4S: Duet2
          https://forum.duet3d.com/post/296755
          K40 Laser, Duet2
          https://forum.duet3d.com/post/312082
          Wanhao D5S
          https://www.youtube.com/CNCModellerUK
          CNCModellerundefined dc42undefined 2 Replies Last reply Reply Quote 0
          • ajdtreydundefined
            ajdtreyd
            Should it be possible to add more than one axis to a single session?
            I have tried adding tests for X and Y axis to a single session and then when recording, all tests are run, but only along the axis which was selected for the last configured test.
            thanks!
            sebkritikelundefined mfs12undefined 2 Replies Last reply Reply Quote 1
              CNCModeller @CNCModeller
              @cncmodeller said in InputShaping-Plugin-0.2.0-pre7 released:
              Hi All,
              Cheers
              Barry M
              Update, I've increased bed speed and Accel limits by an order of magnitude and the bed now behaves as in pre6 but I'm still getting the error.
              Wanhao D4S: Duet2
              K40 Laser, Duet2
              Wanhao D5S
              • sebkritikelundefined
                sebkritikel @ajdtreyd
                Good updates all around!
                My only report is removing algorithm run data from the current selection resets the chart view to the 'Time' plot - this is in contrast to removing axis data, which keeps the chart (time or FFT) active.
                @ajdtreyd I agree, it would be nice to nice to run different axis tests under a single 'configuration' session. The axis setup & bounds could fall under each algorithm you add.
                Large(ish?) IDEX - 6HC, 1HCL
                Stratasys Dimension 1200es to 6HC Conversion
                • ajdtreydundefined
                  ajdtreyd
                  Found a bug!
                  I used -75 and 75 as my start positions for the initial config of my sessions. After doing record and running recommendations, I selected a couple of algorithms and added them to the session. All good. But when I went back to the CONFIGURE tab the start positions had reverted to the defaults of -115 and 41.
                  I figured this was just a GUI issue and ran the recordings, but the newly added algos used the default start positions.
                  Another "nice to have" (but not a bug) is to reset the Input Shaping mode to it's original state when 1) the recording phase has finished AND 2) when the recommendations have completed. Currently M593 mode is left with whatever setting was last used by the plugin.
                  I have this in my bed.g so probing uses very low accel/jerk and then the original values are reset:
                  ; -- set accel/jerk vars to current values
                  var x_accel=move.axes[0].acceleration  ;set variable to current acceleration
                  var x_jerk=move.axes[0].jerk  ;set variable to current jerk
                  var y_accel=move.axes[1].acceleration  ;set variable to current acceleration
                  var y_jerk=move.axes[1].jerk  ;set variable to current jerk
                  var z_accel=move.axes[2].acceleration  ;set variable to current acceleration
                  var z_jerk=move.axes[2].jerk  ;set variable to current jerk
                  M201 X{var.x_accel} Y{var.y_accel} Z{var.z_accel} ;restore orig accel
                  M566 X{var.x_jerk} Y{var.y_jerk} Z{var.z_jerk} ;restore orig jerk
                  Overall the plugin is working really nicely!
                  Thanks!
                    dc42 administrators @CNCModeller
                    That indicates that board 123 is not responding to a CAN command. It's probably not running the correct firmware version.
                    • mfs12undefined
                      mfs12 @ajdtreyd
                      @ajdtreyd said in InputShaping-Plugin-0.2.0-pre7 released:
                      Right now you have exactly one test movement per session. This helps to keep things separated. When you start to mix all different test you loose pretty fast the overview. So it makes sense to me to keep things separated.
                      But there might be some further changes in future.
                      • Fred-Yundefined
                        Fred-Y
                        A suggestion would be to add a Z position, this is mainly an issue with Delta as the recording will fail if we don’t move down the effector after having homed the printer.
                        I'm having a lot of crashes when I try to launch the recording, the Duet 2 Wifi just seems to reboot - I didn't see any error.
                        It doesn't appears to be related to the algorithm selected (happen even with none) or the number of recordings.
                        I will try to spend more time to see if I can find anything that could help to figure out what could be the reason.
                        Let me know if there is anything I can do to help trouble shooting this issue.
                        These recommendations seem wrong to me - I’m not an expert so I can be wrong.
                        I ran without compensation
                        All recommendations are on the frequency 10.82Hz; I feel it would be better to compensate something between 64 and 72Hz.
                        The spike at 102Hz is not generated by any movement, it exists when doing recording without a move.
                        dc42undefined T3P3Tonyundefined ajdtreydundefined 3 Replies Last reply Reply Quote 0
                          dc42 administrators @Fred-Y
                          @fred-y said in InputShaping-Plugin-0.2.0-pre7 released:
                          Please post a M122 report taken after one of those reboots.
                          Fred-Yundefined 1 Reply Last reply Reply Quote 0
                          • Fred-Yundefined
                            Fred-Y @dc42
                            @dc42 I did a lot of tests yesterday but I have not been able to reproduce the issue (reboot) I had.
                            I'm unsure what caused it I haven't changed anything: same config and wiring ... the board is a few years old maybe something starts to wear.
                            I'm planning to do more testing within the next few days and I will report back with a log if it is happening again.
                              A Former User
                              Good morning, I've been able to make my accelerometer to work! I'm trying the plugin but (again) there's something I'm missing, I'm afraid.
                              I've created two analysis, the first for the X axis and the second for the Y axis, these are the results:
                              X axis:
                              Y axis:
                              Why does the plugin suggest me 10,87/88Hz as frequence? Particullary for the Y axis the spike is at 67.8 Hz wich is about where I expected it to be....what's wrong? CoreXY printer, here my M122:
                              13/11/2021, 07:52:25	M122
                              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0beta6 (2021-11-06 11:37:41) running on Duet WiFi 1.02 or later
                              Board ID: 08DLM-996RU-N85T0-6JKFJ-3SD6R-9SSHN
                              Used output buffers: 3 of 24 (24 max)
                              Static ram: 23772
                              Dynamic ram: 79576 of which 12 recycled
                              Never used RAM 5408, free system stack 118 words
                              Tasks: NETWORK(ready,16.6%,234) ACCEL(notifyWait,0.1%,244) HEAT(notifyWait,0.0%,326) Move(notifyWait,0.0%,283) MAIN(running,83.2%,440) IDLE(ready,0.2%,30), total 100.0%
                              Owned mutexes: WiFi(NETWORK)
                              Last reset 00:09:52 ago, cause: software
                              Last software reset at 2021-11-13 07:42, reason: User, GCodes spinning, available RAM 5408, slot 2
                              Error status: 0x0c
                              Aux0 errors 0,0,0
                              Step timer max interval 0
                              MCU temperature: min 32.6, current 33.2, max 33.9
                              Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/10, heap memory allocated/used/recyclable 2048/672/472, gc cycles 0
                              Driver 0: pos 74214, standstill, SG min 0
                              Driver 1: pos -21546, standstill, SG min 0
                              Driver 2: pos 6345, standstill, SG min 29
                              Driver 3: pos 0, standstill, SG min n/a
                              Driver 4: pos 0, standstill, SG min n/a
                              Driver 5: pos 0
                              Driver 6: pos 0
                              Driver 7: pos 0
                              Driver 8: pos 0
                              Driver 9: pos 0
                              Driver 10: pos 0
                              Driver 11: pos 0
                              Date/time: 2021-11-13 07:52:23
                              Slowest loop: 50.36ms; fastest: 0.09ms
                              === Storage ===
                              Free file entries: 10
                              SD card longest read time 3.4ms, write time 39.6ms, max retries 0
                              DMs created 83, segments created 19, maxWait 118823ms, bed compensation in use: none, comp offset 0.000
                              === MainDDARing ===
                              Scheduled moves 19, completed 19, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
                              === AuxDDARing ===
                              Segments left: 0
                              Movement lock held by null
                              HTTP is idle in state(s) 0
                              Telnet is idle in state(s) 0
                              File is idle in state(s) 0
                              USB is idle in state(s) 0
                              Aux is idle in state(s) 0
                              Trigger is idle in state(s) 0
                              Queue is idle in state(s) 0
                              LCD is idle in state(s) 0
                              Daemon is idle in state(s) 0
                              Code queue is empty
                              === Filament sensors ===
                              Extruder 0: pos 0.00, errs: frame 1 parity 0 ovrun 0 pol 0 ovdue 0
                              Extruder 1: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                              === Network ===
                              Slowest loop: 80.25ms; fastest: 0.00ms
                              Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(1), 1 sessions
                              HTTP sessions: 2 of 8
                              - WiFi -
                              Network state is active
                              WiFi firmware version 1.26
                              WiFi MAC address 84:0d:8e:b3:bc:96
                              WiFi Vcc 3.45, reset reason Turned on by main processor
                              WiFi flash size 4194304, free heap 25264
                              WiFi IP address 192.168.1.7
                              WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
                              Clock register 00002002
                              Socket states: 2 4 0 0 0 0 0 0
                              Thanks!
                              gloomyandyundefined 2 Replies Last reply Reply Quote 1
                              • gloomyandyundefined
                                gloomyandy @A Former User
                                @thedragonlord You really need to run a base line test for each axis (so set the input shaper to "none") and then use that as the input to the recommendation stage. However I suspect that this will still select too low a frequency (as reported by Fred-Y above and I see the same thing). However by having the base results (with no input shaper), you may be able to judge for yourself what other tests to run and what frequency will work best for you. Remember that at the moment RRF only supports a single shaper for X and Y so you will need to select on that basis.
                                @mfs12 Are there any plans to change the way that the recommendations selects the target frequency? At the moment it always seems to select something that is too low.
                                  @thedragonlord You might find the thread I started on input shaping of interest: https://forum.duet3d.com/topic/25931/input-shaping-testing-and-thoughts
                                    T3P3Tony administrators @Fred-Y
                                    Its a good idea to move your effector down at the end of homedelta.g to a position where any XY commands that are valid will not crash the carriages at the top of the endstops.
                                    • ajdtreydundefined
                                      ajdtreyd @Fred-Y
                                      +1 for this
                                      Also, to take this a bit further, it would be nice to be able to specify test moves by XYZ coordinates. On deltas (mine, at least) the resonances vary a lot based on effector position and direction of travel. Currently I do this using the Accelerometer plugin, but that has no way to overlay FFT graphs of multiple recordings and it takes a long time to do comparisons.
                                      Hehehe ... sounds like I'm complaining, but this tuning process is soooo much better than it was in 3.3!
                                      • Fred-Yundefined
                                        Fred-Y @T3P3Tony
                                        @t3p3tony Actually the firmware has been properly coded to handle this situation as it prevents these moves.
                                        But I like your recommendation to move down the effector at the end of the homedelta file, I know some slicers (at least IdeaMaker) starts to move the effector on X/Y before moving down the effector causing an error.
                                          A Former User @gloomyandy
                                          @gloomyandy said in InputShaping-Plugin-0.2.0-pre7 released:
                                          Ok, but it's not clear, after using the recomendation, how to choose the frequency to set in the M593....all the recomendation displays the same frequency....is this a plugin's bug? I know it's my fault due to my ignorance but except for the analysis I really can't understand how to use this plugin..
                                          gloomyandyundefined 1 Reply Last reply Reply Quote 0
                                            @thedragonlord Yes, it looks like the frequency chosen is not correct and it is probably a bug (which is why I was asking @mfs12 about it). Remember that this is all new software (and still not a final release), so there are likely to be problems.
