Input Shaping and PA
    PCR
    i made some tests with PA an IS.
    Upper one without IS
    The other one with IS
    is this expected @dc42 ?
    This is my IS
    M593 P"ei3" F50.2
    undefined 1 Reply Last reply 4 Nov 2021, 11:00 Reply Quote 0
      T3P3Tony administrators @PCR
      @pcr can you describe the differences you are seeing? It might be easier with your description as well as the photos.
      Pressure advance works separately from input shaping, although as you have seen input shaping affects PA. I would get IS set to what you want then retune PA to match.
      undefined 1 Reply Last reply 4 Nov 2021, 11:02 Reply Quote 0
        PCR @T3P3Tony
        @t3p3tony yep it seems that with IS in you need Higher PA ;(
        undefined 1 Reply Last reply 23 Nov 2021, 18:26 Reply Quote 0
        • undefined PCR referenced this topic 23 Nov 2021, 08:06
          Argo @PCR
          @pcr
          My findings are that increasing PA to almost absurd levels for clean‘ish corners causes other issues in infill areas.
          What are your observations?
          undefined 1 Reply Last reply 24 Nov 2021, 00:44 Reply Quote 0
            Alex.cr @Argo
            @argo said in Input Shaping and PA:
            @pcr
            I am running into similar issues. It also seems to effect small features such as small gear teeth.
            Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
              sebkritikel
              The impacts on PA likely vary with the input shaping algorithm and targeted frequency. I'm running MZV at 23.85 HZ and my PA tuning strips look nearly identical.
              Large(ish?) IDEX - 6HC, 1HCL
              Stratasys Dimension 1200es to 6HC Conversion
              • undefined oliof referenced this topic 25 Nov 2021, 12:23
              6 out of 6
