Heated chamber air circulation fan
1.7k
    chris94
    Hi I am looking for a simple way to circulate the air in my heating chamber. The maximum chamber temperature is 120 ° C, which greatly limits the choice of finished solutions. I prefer to control the fan with a slice and it should be as quiet as possible so I don’t want to use an oven fan. At the moment I’m working on a radial fan but I’m not sure what kind of motor to look for. does someone happen to know a temperature-resistant fan that I could use or which motor (not inside the chamber) I should use for a self-construction?
    (older picture of the chamber)
    • undefined chris94 marked this topic as a question 24 Nov 2021, 14:25
      TLAS
      Most fans have a maximum rating temperature of 60C due to plastic, resin, and magnet component temperature limitations.
      External drive shafts are the way to go for anything that hot. Look at air friar fans if you want something a bit quieter.
      undefined 1 Reply Last reply 24 Nov 2021, 15:25 Reply Quote 0
        chris94 @TLAS
        @tlas I found a few fans with a max operating temperature of 90°C but that’s still too low for me. Problem with the kitchen stuff fans is the size, price or noise if you even are able to get them. My current solution is a radial fan out of a temperature resisted filament.
        Currently calculating the optimal geometry and simulating the flow inside the fan and the chamber but I have no idea what motor I should use. My electrical knowledge is not the biggest so I have no idea what the best solution would be for this application.
        undefined 1 Reply Last reply 24 Nov 2021, 21:42 Reply Quote 0
          rjenkinsgb
          This place has a range rated at 150'C continuous, going down to quite small ones:
          https://www.justfans.co.uk/commercial-fans-smoke-extract-high-temperature-fans-c-27_96.html?sort=2a
          ps. For evening out the temperature, you should try a duct set up with a fan that pulls or pushes air down from the top to the bottom of the enclosure.
          That moves hot to cold, countering some of the convection transfer and maintaining overall circulation.
          Robert J.
          Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
          undefined 1 Reply Last reply 24 Nov 2021, 16:41 Reply Quote 0
            chris94 @rjenkinsgb
            @rjenkinsgb I totally agree with you but sadly there is no space left on top of the chamber for a fan and I plan to use the camber fan with swappable outlets so I can use the fan for part cooling as well. The link you posted is looks promising, thanks for that.
            undefined 1 Reply Last reply 24 Nov 2021, 21:02 Reply Quote 0
              mrehorstdmd
              I'd mount a motor outside the chamber with a shaft going through the wall of the chamber, and use a metal fan blade inside the chamber. You might need a shaft coupler that won't transfer much heat from the shaft to the motor, but it shouldn't be too hard to find a suitable material.
              undefined 1 Reply Last reply 24 Nov 2021, 16:46 Reply Quote 0
                chris94 @mrehorstdmd
                @mrehorstdmd that was my current plan but i couldn't find a suitable motor. like i sad i dont know too much about electronics so i have no idea which motor is suitable for this application because i would like to control it with the slicer fan configuration
                  Since you're just trying to even the air temp you don't need anything more than turbulence so a real fan blade design isn't even needed. All you need are paddles on a spinning shaft. That would simplify the design considerably.
                  undefined 1 Reply Last reply 24 Nov 2021, 21:19 Reply Quote 0
                    rjenkinsgb @chris94
                    @chris94 said in Heated chamber air circulation fan:
                    The corner duct type of setup in your drawing would be fine, just with the fan at the bottom pulling air downwards rather than blowing upwards?
                    ps. Have you used high temperature cable all the way through for the motors etc?
                    Normal PVC insulation is not rated for 120'C - the industrial "Tri-rated" cable we use in machine tools etc. is only rated to 105'C.
                    Robert J.
                      chris94 @Phaedrux
                      @phaedrux The Mechanical design is not my problem. But the selection of the electronic component is. I Don’t have a problem putting an oven fan in the chamber but controlling it would kill my knowledge because I don’t even have a clew how to control such a motor or if it’s even possible to do so. My favourite solution would be a simple fan motor outside the chamber but I don’t know witch motor I should use and how I should control it. I just want the fan to be quiet (1k rpm) and easy to use so I can control it via the slicer. Is it necessary to design a radial fan from the ground up with a part cooling in mind? No decently not but I like to learn as much as possible while building this printer and that’s why there is so much “overcomplicated” stuff like the hydraulic tool changer inside. I just need someone to guide me a bit in the right direction.
                      @rjenkinsgb Yes everything inside this Printer was selected with the Temperature of 120°C in mind (HT- cables, Stepper and Hotend are watercooled etc.). The position of the inlet isn't ideal but it should works good enough and if I put the whole thing upside down I wouldn't have a chance to use the fan in the future as a "part cooler" as well
                      undefined 1 Reply Last reply 24 Nov 2021, 21:33 Reply Quote 0
                        Phaedrux Moderator @chris94
                        If the fan is outside the chamber where is it drawing air from? If it's drawing air from inside of the chamber that is at 110c then you'll be hard pressed to find a plastic construction fan and motor that would survive that. Best I've seen rated at 70c.
                        undefined 1 Reply Last reply 24 Nov 2021, 21:40 Reply Quote 0
                          chris94 @Phaedrux
                          @phaedrux the fan itself sits in the chamber and is connected to the motor by a shaft through the chamber. same principle as an oven fan
                            What filament?
                            undefined 1 Reply Last reply 24 Nov 2021, 21:51 Reply Quote 0
                              chris94 @Phaedrux
                              @phaedrux 3dktop
                              undefined 1 Reply Last reply 24 Nov 2021, 21:54 Reply Quote 0
                                3dktop
                                Wow, I've never heard of that before.
                                https://3dk.berlin/en/3dktop-heat-resistent/200-3dktop-white.html
                                undefined 1 Reply Last reply 24 Nov 2021, 21:56 Reply Quote 0
                                  chris94 @Phaedrux
                                  @phaedrux it's quite nice and not too expensive for its properties
                                    Well since you have the fan blade portion possibly solved, the external motor and it's control is where you're stuck?
                                    How heavy is the shaft/blade? Do you have a normal fan you could cannibalize to attach to the shaft?
                                    undefined 1 Reply Last reply 24 Nov 2021, 22:25 Reply Quote 0
                                      chris94 @Phaedrux
                                      @phaedrux the rotor itself is currently 16,54 Grams and the inertia is at 86,87 gcm². the shaft will be as small as possible and so not really heavy. cannibalize of some random fan would be possible but I don’t have one on hand and i would rather by a separate motor (less getto style)
                                        mrehorstdmd
                                        Buying a new motor for the task is going to be unnecessarily expensive when so many fans are available for pennies. I'd pick up an old desk fan at a garage sale, especially if it has a metal blade, and add a shaft coupler. You're not trying to control the speed, just stir the air, so all the controller has to do is switch it on and off. One of the controller's standard fan outputs can drive a small SSR to operate the fan. If you don't want it running very fast add a small speed controller and just set it to run slow.
                                        Whenever you're running the chamber heater you probably want to run the fan, too, so you could just power the two from the same source.
                                        DIY-O-Sphereundefined 1 Reply Last reply 25 Nov 2021, 12:05 Reply Quote 0
                                        • DIY-O-Sphereundefined
                                          DIY-O-Sphere @mrehorstdmd
                                          What about using a convection blower of an oven?
                                          Used ones are really cheap and metal blades are included....
                                          (UTC+1)
                                          undefined 1 Reply Last reply 25 Nov 2021, 12:19 Reply Quote 0
                                          4 out of 22
