    [Feature request] Add model preview to paneldue
    PanelDue
    8
    17
    859
    • Exerqtorundefined
      Exerqtor @A Former User
      @thedragonlord said in Request for PanelDue Feature:
      Good morning, would it be possible in future to have a thumbnail for the GCODE in printing in pane2? Maybe have an option to choose if keep on seeing the actual status view or a new view with the thumbnail...
      Would it be an interesting feature?
      Thanks
      I would really love that too, a general UI refresh/modernisation pluss some new features that's become pretty common on most mainstream 3D printers would also be super nice. Guess it's being bottlenecked on the hardware side regretably 😥
      • mfs12undefined
        mfs12
        I think it would be possible in general to integrate a model preview although it needs to be rendered somewhere else. So the image would be rendered somewhere and then you can watch it on the screen.
        I wonder where is the real benefit for the user except that it looks cool?
        And I would assume you had previously a decent look at the model when you chose it and decided to print it. Right?
        Can you please provide more arguments why this is a nice idea?
        @Exerqtor, I agree the UI could look more modern. What features from other printers do you miss?
        Visit me on github at https://github.com/mfs12/
        oliofundefined A Former User? 2 Replies Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy
          Don't some slicers now insert a preview image into the gcode file? Perhaps the PD (and the web interface) could display that?
          • oliofundefined
            oliof @mfs12
            @mfs12 might be useful in a farm-like setup where you have pre-sliced models printed over and over again. An assistant could choose by the image to make sure they choose the right image.
              A Former User @mfs12
              @mfs12 said in [Feature request] Add model preview to paneldue:
              well, the main benefit could be an easier browsing of the gcode to print, and yes, it would be cool...
              mfs12undefined 1 Reply Last reply Reply Quote 0
              • mfs12undefined
                mfs12 @A Former User
                @thedragonlord said in [Feature request] Add model preview to paneldue:
                what do you mean by "browsing of the gcode to print"? choosing the right gcode file?
                • PaulHewundefined
                  PaulHew
                  are you going to be able to get all that data up that serial cable, and possibly a memory issue in the paneldue?
                  • Nurgelrotundefined
                    Nurgelrot
                    Most model displays in the control screen of printers are just preview images created by the slicer. That I think could be implemented in a redesigned PD. But live rendering? I would not want this. Massive waste of resources in your control screen (even if it was technically possible). If you really what this, do it via DWC and the Gcode viewer plugin on a tablet display don't burden the Panel Due.
                    I used to struggle with the PD's UI. You see other products and they look really cool and at first glance the PD looks so dated. Then I actually print something and realize that everything I really need to see is on the PD and is easy to read. Actually elegant in its efficiency.
                      yes
                        A Former User @Nurgelrot
                        @nurgelrot said in [Feature request] Add model preview to paneldue:
                        I don't want live rendering too
                          We looked at this last year. Unfortunately the data compression algorithm used to encode the thumbnail needs more than 32kb of RAM to decompress the data, and the current PanelDue hardware doesn't have enough spare.
                            A Former User @dc42
                            @dc42 uh, ok.... thanks
                            • mfs12undefined
                              mfs12
                              Here's the old thread...
                              https://forum.duet3d.com/topic/18342/paneldue-image-display
                                @thedragonlord if we upgraded the processor in PanelDue from ATSAM4S4B to ATSAM4S8B then there would be enough RAM. But it would probably make more sense to redesign it around the ESP32-C3 instead.
                                  A Former User @dc42
                                  @dc42 said in [Feature request] Add model preview to paneldue:
                                  ok
                                  • mfs12undefined
                                    mfs12
                                    Preview images with QOI are now supported since pd-3.4.1-pre1.
                                    https://github.com/Duet3D/PanelDueFirmware/issues/246
                                    mfs12 created this issue in Duet3D/PanelDueFirmware
                                    closed Add support for QOI thumbnails in gcode files #246
                                    • mfs12undefined mfs12 marked this topic as a question
                                    • mfs12undefined mfs12 has marked this topic as solved
