    Turning of the SSR heated bed immediately kicks the printed part
    23
    1.2k
    • engikeneerundefined
      engikeneer @secure
      @secure could simply be thermal expansion? If your bed bows downwards when hot, maybe it just bowed back up when you turned it off and it started to cool. That means the effective later height would reduce and look like overextrusion.
      Depending on your bed/heater type, some pcb type heaters also expand/contract when powered on/off so could be that?
      i3 clone with a bunch of mods
      nikschaundefined 1 Reply Last reply Reply Quote 0
      • nikschaundefined
        nikscha @engikeneer
        @engikeneer I think this is the right answer.
        Get the bed to 110 degrees, take a piece of paper and position it under the nozzle, then lower the nozzle until it just starts to grab the piece of paper. Then turn of the bed and move the paper around a bit. Probably you will feel the friction increase.
        You can also try to print on the 'edge' of the printbed and see whether that makes a difference
        Stay in school
        • secureundefined
          secure
          No I have seen this live. It is not a thermal expansion. Turned off the heated bed and immediately I had seen over extrusion.
          I have over extrusion problems on that printer that I couldn't find an easy fix. May be I need to change the bulldog extruder.
          mrehorstdmdundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
          • mrehorstdmdundefined
            mrehorstdmd @secure
            @secure It seems unlikely to be an extruder problem. Is the problem repeatable? Will shutting off the bed heater cause this effect on any print at any Z position? What happens if you turn the heater back on? And then off again?
            Is the bed heater powered by the same power supply that powers the controller board? Are there any off-controller board motor drivers?
            A wiring diagram and some photos of the printer might be helpful...
            • o_lampeundefined
              o_lampe @secure
              @secure said in Turning of the SSR heated bed immediately kicks the printed part:
              You've seen overextrusion, because the layer height was wrong immediately after the SSR switched off.
              You seem to have something like a bimetall effect in your bed mounts or glass plate.
              secureundefined 1 Reply Last reply Reply Quote 0
              • secureundefined
                secure
                Interesting but it is repeated. I turned off the heater at 100 degC and 4-5 layer expanded/overextruded/shifted while the heated bed is still at 95 cdeg. I think it is nothing to do with temperature. Heater powered by 220 AC outlet nothing to do with the board. I will try PID tuning again anycase.
                M308 S0 P"bedtemp" Y"thermistor" T100000 B4138  ; configure sensor 0 as thermistor on pin bedtemp
                M950 H0 C"bedheat" T0                           ; create bed heater output on bedheat and map it to sensor 0
                M307 H0 B0 R0.577 C501.4 D8.08 S1.00 V24.0      ; enable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                         ; map heated bed to heater 0
                M143 H0 S120                                    ; set temperature limit for heater 0 to 120C
                Here some photos of the printer.
                WhatsApp Image 2021-12-14 at 18.22.12.jpeg WhatsApp Image 2021-12-14 at 18.22.12 (3).jpeg WhatsApp Image 2021-12-14 at 18.22.12 (2).jpeg WhatsApp Image 2021-12-14 at 18.22.12 (1).jpeg
                rjenkinsgbundefined 1 Reply Last reply Reply Quote 0
                • secureundefined
                  secure @o_lampe
                  @o_lampe said in Turning of the SSR heated bed immediately kicks the printed part:
                  Sorry I don't understand. What do you mean? It is going back to normal after a few layers
                  • rjenkinsgbundefined
                    rjenkinsgb @secure
                    @secure
                    You appear to have the logic level control wire to the SSR bundled with the high current heater wire; that could be spiking the controller - try separating them?
                    Tip: Where possible always twist the pairs of wires to heaters, controls and sensors etc. separately from each other, to minimise possible crosstalk.
                    Robert J.
                    Printers: Overlord pro, Kossel XL+ with Duet 6HC and "Frankentron", TronXY X5SA Pro converted to E3D toolchange with Duet 6HC and 1LC toolboards.
                    • secureundefined
                      secure @rjenkinsgb
                      @rjenkinsgb said in Turning of the SSR heated bed immediately kicks the printed part:
                      @secure
                      Yes, spiking is my suspect too. This is my first thing to do.
                      I'll add another small PSU for 12V leds&fans and source the heated bed AC from this PSU.
                      Thanks for the tip too. I'm very bad on wiring this printer. All my connectors loose.
                      • secureundefined
                        secure
                        Back again!
                        I made a quick change and added another PSU and separate board output and heater output. Nothing changed.
                        I have measured AC outlet; 240 @ 50 hz. / PSU output 24.4 volt (stable) / Board input connector 23.6 volt (stable)
                        Board Vin voltage while printing took my attention. It is not stable and jumps between 22.4v to 24 volt.
                        I stopped printing and vin voltage becomes stable at 24.1 volt. Turned on hotend 1 and Vin dropped to 23.3 v.
                        I will check all my wirings again. There could be loose connection as I believe there shouldn't be a drop in voltage like this.
                        jens55undefined 1 Reply Last reply Reply Quote 1
                        • jens55undefined
                          jens55 @secure
                          @secure, I think you have more fundamental errors than the what you suspect is caused by the heated bed. You are correct that voltage should not fluctuate like that - it should be rock steady with a decent power supply (Meanwell but not a Meanwell clone)
                          This might possibly be the reason why the rest of the print looks quite crappy (sorry). The walls are all over the place and are just terrible.
                          I would try replacing the power supply first .... but I am afraid that there might be other gremlins at work that cause the poor walls. I suppose they could be just over extruded .... hard to tell from here.
                          • secureundefined
                            secure @jens55
                            @jens55 said in Turning of the SSR heated bed immediately kicks the printed part:
                            Yes it is crappy I have some errors and trying find the possible causes.
                            I think it is hardware related error because I had recently(3 weeks ago) printed this part with the same printer.
                            Not a Meanwell but I have 1300 watt @24 volt PSU lying around here. I don't think it is related with PSU because it's voltage output is stable. I had changed a lot of things on that printer for the last 3 weeks. One another suspect is the twisted CAT7 23 awg cables that I used to for heat cartidges. Like @rjenkinsgb said I may need to rewire those cables. Thanks for the inputs.
                            • jens55undefined
                              jens55 @secure
                              That's a night and day quality difference!
                              What do you mean the output is stable .... you said "Board Vin voltage while printing took my attention. It is not stable and jumps between 22.4v to 24 volt."
                              If Vin varies at the board but not on the power supply then you have either severely undersized wiring or bad connections on the wiring which I assume you checked as soon as you noticed the fluctuations.
                              Yes, 23 gauge is iffy but might work if it's a 24V / 40W heater .... if it is a 12V heater then 23 ga is not heavy enough.
                              • jens55undefined
                                jens55
                                Further thought - the crappy wall finish could very well be related to an undersized extruder heater wire.
                                  rjenkinsgb @secure
                                  You still have the SSR control wire bundled in with the power wires; that's a no-no - small signal wires need some form of isolation, eg. distance, screening, twisting etc., to separate them from power wires anywhere it is physically possible.
                                  Robert J.
                                  • danzaywerundefined
                                    danzaywer @secure
                                    @secure
                                    Can you separate the input lines of the two PSUs? maybe using UPS, if you can pull an extension cable from your neighbor's garage it's better 🙂
                                    just for what causes this feedback, reading the various posts the only point in common is the AC line ....
                                    • percarundefined
                                      percar
                                      Are you using Bang Bang heater control or PID
                                      A long time ago i was using BANG BANG and i put a indicator on the platform and i could see movment in the platform of up to .2mm. I changed to PID and that variation went away..you can use PID with SSR without a problem.
                                      Also if i were you i would use a seperate power supply for the DUET controller and one for the bed heater that should control your 24vdc variations. (Personally i would use mains to power a bed heater but that means purchasing a new heater)
                                      One other thing that i noticed was the way you are pulling the filament off the spool. With that arrangement you are going to be twisting the filament. This may cause issues with the extruder.
                                      engikeneerundefined 1 Reply Last reply Reply Quote 0
                                        engikeneer @percar
                                        @percar I think @secure I using an AC mains heater, he just happens to be using a small PSU as a terminal box for reasons I don't really understand....
                                        • secureundefined
                                          secure @danzaywer
                                          @danzaywer I did it. Powered the board with adjustable power supply to see the current it draws. 0.18A at idle and 1.80A when hotend is on.
                                          Ac outlet 230volt stable. PSU output 24.2volt stable. Board power input connector 24.0 v stable.
                                          @percar It is in a PiD mode. I'm using two PSU. The 24V psu is for the board, 12V psu is for leds and 12v fans around enclosure. Filament spool made by a turntable. It is a free spinning bearing.
                                          @rjenkinsgb I understood what you mean. I tried it. Nothing seem works really right now.
                                          I don't know if this macro shows a layer height change or over extruded layer? I think layer height is different than others.
                                          Anyway I'm tired. Don't shut off the heater bed and problem is solved.
