    Large Format CoreXY?
    43
    5.6k
    • michaelr123undefined
      michaelr123
      Thanks for all the feedback!
      I decided to go through and design a much more robust belt tensioning system. This has dramatically improved performance. I can tell just from the few test runs I've gotten out of it. Unfortunately I haven't been able to keep the duet connected to the SBC for more than a few minutes though, so every print is failing fairly quickly (see my other thread if you'd like to help me out with a software problem now 😄 )
      Taking this a new direction, I've really struggled with the web interface to the duet 3 board specifically being flakey. My duet 2 wifi runs like a champ all the time, keeps running if I lose connection to it for some reason, no issues at all. The only issue I have is if it gets a new IP address assigned to it and I have to figure out what the new number is. Any advice on how to improve the robustness of the connection to the SBC and duet 3 combo? Can it store and run print files locally so that if I drop internet connection it can keep running? Does it sound like my PI 3 is flakey and I should replace it?
        Phaedrux Moderator @michaelr123
        @michaelr123 said in Large Format CoreXY?:
        I suggest you start a new thread and provide as much details about your setup as possible.
        • mrehorstdmdundefined
          mrehorstdmd @Catalin_RO
          @catalin_ro I was building a VDG a few years ago and decided to ignore the "conventional wisdom" that you can't use bicycle tire tubes for the belt because the carbon in the tubes makes them conductive enough that you can't generate a charge with them. For once the "conventional wisdom" was right. Zero output.
          I suspect that the same effect will apply to the black belts used in printers. If you're using polyurethane belts, it might be different, but the steel core in those belts would probably limit any charge you could accumulate.
          @michaelr123 You should be able to reserve a specific IP address for the duet or SBC in your wifi router. Look in advanced settings and see if there's something called "DHCP server". If you enable it you can enter the MAC address of the device and assign a reserved IP address so it will always be assigned that address.
            dc42 administrators @Catalin_RO
            @catalin_ro we are fairly certain that static build up on the hot end assembly has damaged the temperature reading electronics in a few instances. That is why we strongly recommend that the hot end metalwork be grounded. We believe it is the act of extruding plastic that causes the static buildup.
            We don't have definite evidence that static buildup on axis motors has caused problems, but we think that grounding the motor bodies is a wise precaution.
              michaelr123
              See thread --- Warning: Lost connection to Duet if you've got any ideas on how to get my printer to make it past the first layer.
              • ov_darknessundefined
                ov_darkness
                HevORT can be made 800x800mm and possibly larger, but with a setup like this, you lose the most important advantage of a CoreXY system - speed, because your' gantry will be very heavy (you can use servos like Clearpath and 12mm belt though). Also, the Bed will get very, very heavy, so you'd probably need to drive your Z-axis motors with belts and also you'd need to use Nema23 for that. Not enough detent torque on even 60mm Nema17's.
                Furthermore - ball screws are out of the question, you'd need to go with regular trapezoids.
                Pro level AM audit, support and sales.
                Management of 3D scanning and printing services.
                Focused on Central and Eastern Europe.
                • o_lampeundefined
                  o_lampe @ov_darkness
                  @ov_darkness said in Large Format CoreXY?:
                  Why that? Just out off curiosity...
                  ov_darknessundefined 1 Reply Last reply Reply Quote 0
                  • vwegertundefined
                    vwegert @deckingman
                    @deckingman said in Large Format CoreXY?:
                    I started out with printed mounts but despite the fact that they were thick and printed in PET-G, the combination of heat from the motors and belt tension would cause them to distort after big multi hour prints.
                    I concur and am able to add further evidence...
                      ov_darkness @o_lampe
                      @o_lampe ball screws are not self-braking. So when you have a substantial weight (10mm slab of aluminum 800x800mm in size weighs ~17kg and 800x800x4mm Robax sheet weighs about 6,5kg) on it, they will drop when motors are not energized. Therefore, you'd need trapezoidal screws (they hold large weights much better), motors with brakes, more than three motors (over constraining your bed), or you'd need to move XY gantry in Z axis instead of your bed (so you're basically building a Voron).
                      in my opinion, using trapezoidal screws is the simplest, most efficient way to solve this problem.
                      This comes from a person that's operating, servicing, and training people to use 600x600mm bed printers.
                        mrehorstdmd
                        Or use a motor with a worm gear to drive the ball screws, or to drive belts to lift the bed. Either way, the bed won't move when you power down. It's cheaper, simpler, and more reliable than motors with brakes or other add-on gizmos, looks a lot better and takes up less space than counterweights.
                        https://www.ebay.com/itm/191714031261?epid=711126295&hash=item2ca30bf69d:g:A7UAAOSwPhdVB2f0
                        I used this gearbox in my corexy machine to lift the bed with belts. It doesn't require any special configuration, or any extra connections to the controller to operate a brake. Just connect it as a Z axis motor and you're done. With 3D printer loads, the 30:1 drive can't be back driven. The NEMA-23 motor provides plenty of torque to lift a heavy bed assembly.
                        In that picture I was using steel core belts, but have since switched to glass core. Belt stretch is negligible.
                        o_lampeundefined JoergS5undefined 2 Replies Last reply Reply Quote 1
                        • o_lampeundefined
                          o_lampe @mrehorstdmd
                          @mrehorstdmd
                          I'd give you two ThumbsUp for mentioning wormgear and counterweight.
                          @ov_darkness
                          Cudos for taking bad design to improve something by misusing trapezoidials and an overcontrained bedframe.
                          But in the end you'd pay for it with needing several huge stepper motors to overcome the extra friction, adding wear to the leadscrews and the bed gantry.
                          • JoergS5undefined
                            JoergS5 @mrehorstdmd
                            @mrehorstdmd said in Large Format CoreXY?:
                            This interesting gear will probably have no backlash even without load, because the
                            is probably the antibacklash mechanism of
                            This is high quality and worth its high price IMO.
                            • gillranjeettundefined
                              gillranjeett
                              Interesting, yeah its a 1m stick of 40x20, but I oriented the 40x20 long side up to help reduce sag from gravity. Sounds like I could benefit from it being oriented the other way to help reduce flex under belt tension. I'm going to stick with V-slot just for ease of use. At the end of the day its running a 1mm nozzle or larger, so I'm not looking for ultra precision.
                                mrehorstdmd @JoergS5
                                @joergs5 The adjustment on the Rino slightly repositions the disc gear with respect to the worm gear to minimize backlash in the gears. This is the catalog page on the gearbox without the motor. It's the low backlash version which specs at <=8 msec of arc. In this application, backlash shouldn't matter as the load of the printbed mass will always keep the gears engaged on the same side of the teeth regardless of direction of motion. I think you mostly have to worry about backlash if the vertical load is very low mass or in a horizontal motion application where gravity isn't going to help prevent it.
                                The new price on that gearbox is about $700 without the motor. The ebay part is a real bargain at $108 including the motor, ready to drop in. That's about what it would cost to buy a NEMA-23 motor with a brake.
                                • Luke'sLaboratoryundefined
                                  Luke'sLaboratory
                                  I build alot of large corexy's.
                                  To go big and keep relative "good" speeds - Going to recommend a few things:
                                  Bigger belts - 9 or 12mm, allows for higher tension and allows for greater accelerations with a heavier mass, since they are stiffer due to size.
                                  Metal - Frankly, metal is an important change. A plastic mount that was ok on a smaller machine may be insufficient on a larger one, particularily with higher tension from bigger belts.
                                  Dual shear - Cantilevered Idlers allow for way too much flex. if your design uses them, don't. I support my motor shafts with an additional bearing and this allows me to tension belts well, and print fast.
                                  Don't be afraid to upscale your Z rods or go with belted Z. Eventually it doesn't make sense to lift a thick bed (and they need to be thicker to not bend under their own mass) so there's a sane point where you park the bed.
                                  But honestly, might just be time to change to dual Y motors with 9-12mm belts and then an X motor that travels along with it.
                                  Luke
                                  http://lukeslab.online
                                  • JoergS5undefined
                                    There's a saying in german "wer billig kauft, kauft zweimal", which means when one buys cheap, you have to rebuy a second time. I tend to buy high quality parts since some time, if I can afford it.
                                    tenajaundefined zaptaundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                                    • tenajaundefined
                                      tenaja @JoergS5
                                      @joergs5
                                      I've purchased numerous used industrial items on ebay. Often you can get the expensive item at a cheap price... But sure, sometimes they operate at cheap performance.
                                      But at that savings, you can get two or three and have a backup... And still be under half price. As long as the eBay item isn't removed due to wear, and it's the same part number.
                                      • zaptaundefined
                                        zapta @JoergS5
                                        @joergs5 said in Large Format CoreXY?:
                                        There's a saying in english "perfect is the enemy of good" and the low cost Liberty ship are a prime example.
                                        Must be a cultural difference. 😉
                                        • JoergS5undefined
                                          JoergS5 @zapta
                                          @zapta said in Large Format CoreXY?:
                                          Thanks for this, I didn't know this history detail yet.
                                            Phaedrux Moderator @JoergS5
                                            In english we have a slightly more quipey version: "Buy once, Cry once."
