    Large Format CoreXY?
    43
    5.6k
    • mrehorstdmdundefined
      mrehorstdmd @Catalin_RO
      @catalin_ro I was building a VDG a few years ago and decided to ignore the "conventional wisdom" that you can't use bicycle tire tubes for the belt because the carbon in the tubes makes them conductive enough that you can't generate a charge with them. For once the "conventional wisdom" was right. Zero output.
      I suspect that the same effect will apply to the black belts used in printers. If you're using polyurethane belts, it might be different, but the steel core in those belts would probably limit any charge you could accumulate.
      @michaelr123 You should be able to reserve a specific IP address for the duet or SBC in your wifi router. Look in advanced settings and see if there's something called "DHCP server". If you enable it you can enter the MAC address of the device and assign a reserved IP address so it will always be assigned that address.
        dc42 administrators @Catalin_RO
        @catalin_ro we are fairly certain that static build up on the hot end assembly has damaged the temperature reading electronics in a few instances. That is why we strongly recommend that the hot end metalwork be grounded. We believe it is the act of extruding plastic that causes the static buildup.
        We don't have definite evidence that static buildup on axis motors has caused problems, but we think that grounding the motor bodies is a wise precaution.
        • michaelr123undefined
          michaelr123
          See thread --- Warning: Lost connection to Duet if you've got any ideas on how to get my printer to make it past the first layer.
          • ov_darknessundefined
            ov_darkness
            HevORT can be made 800x800mm and possibly larger, but with a setup like this, you lose the most important advantage of a CoreXY system - speed, because your' gantry will be very heavy (you can use servos like Clearpath and 12mm belt though). Also, the Bed will get very, very heavy, so you'd probably need to drive your Z-axis motors with belts and also you'd need to use Nema23 for that. Not enough detent torque on even 60mm Nema17's.
            Furthermore - ball screws are out of the question, you'd need to go with regular trapezoids.
            Pro level AM audit, support and sales.
            Management of 3D scanning and printing services.
            Focused on Central and Eastern Europe.
            • o_lampeundefined
              o_lampe @ov_darkness
              @ov_darkness said in Large Format CoreXY?:
              Why that? Just out off curiosity...
              ov_darknessundefined 1 Reply Last reply Reply Quote 0
              • vwegertundefined
                vwegert @deckingman
                @deckingman said in Large Format CoreXY?:
                I started out with printed mounts but despite the fact that they were thick and printed in PET-G, the combination of heat from the motors and belt tension would cause them to distort after big multi hour prints.
                I concur and am able to add further evidence...
                  ov_darkness @o_lampe
                  @o_lampe ball screws are not self-braking. So when you have a substantial weight (10mm slab of aluminum 800x800mm in size weighs ~17kg and 800x800x4mm Robax sheet weighs about 6,5kg) on it, they will drop when motors are not energized. Therefore, you'd need trapezoidal screws (they hold large weights much better), motors with brakes, more than three motors (over constraining your bed), or you'd need to move XY gantry in Z axis instead of your bed (so you're basically building a Voron).
                  in my opinion, using trapezoidal screws is the simplest, most efficient way to solve this problem.
                  This comes from a person that's operating, servicing, and training people to use 600x600mm bed printers.
                    mrehorstdmd
                    Or use a motor with a worm gear to drive the ball screws, or to drive belts to lift the bed. Either way, the bed won't move when you power down. It's cheaper, simpler, and more reliable than motors with brakes or other add-on gizmos, looks a lot better and takes up less space than counterweights.
                    https://www.ebay.com/itm/191714031261?epid=711126295&hash=item2ca30bf69d:g:A7UAAOSwPhdVB2f0
                    I used this gearbox in my corexy machine to lift the bed with belts. It doesn't require any special configuration, or any extra connections to the controller to operate a brake. Just connect it as a Z axis motor and you're done. With 3D printer loads, the 30:1 drive can't be back driven. The NEMA-23 motor provides plenty of torque to lift a heavy bed assembly.
                    In that picture I was using steel core belts, but have since switched to glass core. Belt stretch is negligible.
                    o_lampeundefined JoergS5undefined 2 Replies Last reply Reply Quote 1
                    • o_lampeundefined
                      o_lampe @mrehorstdmd
                      @mrehorstdmd
                      I'd give you two ThumbsUp for mentioning wormgear and counterweight.
                      @ov_darkness
                      Cudos for taking bad design to improve something by misusing trapezoidials and an overcontrained bedframe.
                      But in the end you'd pay for it with needing several huge stepper motors to overcome the extra friction, adding wear to the leadscrews and the bed gantry.
                      • JoergS5undefined
                        JoergS5 @mrehorstdmd
                        @mrehorstdmd said in Large Format CoreXY?:
                        This interesting gear will probably have no backlash even without load, because the
                        is probably the antibacklash mechanism of
                        This is high quality and worth its high price IMO.
                        • gillranjeettundefined
                          gillranjeett
                          Interesting, yeah its a 1m stick of 40x20, but I oriented the 40x20 long side up to help reduce sag from gravity. Sounds like I could benefit from it being oriented the other way to help reduce flex under belt tension. I'm going to stick with V-slot just for ease of use. At the end of the day its running a 1mm nozzle or larger, so I'm not looking for ultra precision.
                            mrehorstdmd @JoergS5
                            @joergs5 The adjustment on the Rino slightly repositions the disc gear with respect to the worm gear to minimize backlash in the gears. This is the catalog page on the gearbox without the motor. It's the low backlash version which specs at <=8 msec of arc. In this application, backlash shouldn't matter as the load of the printbed mass will always keep the gears engaged on the same side of the teeth regardless of direction of motion. I think you mostly have to worry about backlash if the vertical load is very low mass or in a horizontal motion application where gravity isn't going to help prevent it.
                            The new price on that gearbox is about $700 without the motor. The ebay part is a real bargain at $108 including the motor, ready to drop in. That's about what it would cost to buy a NEMA-23 motor with a brake.
                            • Luke'sLaboratoryundefined
                              Luke'sLaboratory
                              I build alot of large corexy's.
                              To go big and keep relative "good" speeds - Going to recommend a few things:
                              Bigger belts - 9 or 12mm, allows for higher tension and allows for greater accelerations with a heavier mass, since they are stiffer due to size.
                              Metal - Frankly, metal is an important change. A plastic mount that was ok on a smaller machine may be insufficient on a larger one, particularily with higher tension from bigger belts.
                              Dual shear - Cantilevered Idlers allow for way too much flex. if your design uses them, don't. I support my motor shafts with an additional bearing and this allows me to tension belts well, and print fast.
                              Don't be afraid to upscale your Z rods or go with belted Z. Eventually it doesn't make sense to lift a thick bed (and they need to be thicker to not bend under their own mass) so there's a sane point where you park the bed.
                              But honestly, might just be time to change to dual Y motors with 9-12mm belts and then an X motor that travels along with it.
                              Luke
                              http://lukeslab.online
                              • JoergS5undefined
                                There's a saying in german "wer billig kauft, kauft zweimal", which means when one buys cheap, you have to rebuy a second time. I tend to buy high quality parts since some time, if I can afford it.
                                tenajaundefined zaptaundefined Phaedruxundefined 3 Replies Last reply Reply Quote 0
                                • tenajaundefined
                                  tenaja @JoergS5
                                  @joergs5
                                  I've purchased numerous used industrial items on ebay. Often you can get the expensive item at a cheap price... But sure, sometimes they operate at cheap performance.
                                  But at that savings, you can get two or three and have a backup... And still be under half price. As long as the eBay item isn't removed due to wear, and it's the same part number.
                                  • zaptaundefined
                                    zapta @JoergS5
                                    @joergs5 said in Large Format CoreXY?:
                                    There's a saying in english "perfect is the enemy of good" and the low cost Liberty ship are a prime example.
                                    Must be a cultural difference. 😉
                                    • JoergS5undefined
                                      JoergS5 @zapta
                                      @zapta said in Large Format CoreXY?:
                                      Thanks for this, I didn't know this history detail yet.
                                        Phaedrux Moderator @JoergS5
                                        In english we have a slightly more quipey version: "Buy once, Cry once."
                                          deckingman @JoergS5
                                          Liberty ships were a British concept adopted by the USA during to the second world war. They were lightly armed merchant ships of a simply design which could be mass produced and some 3000 were built during those war years. Some 200 or so were sunk during the hostilities but only 2 remain today.
                                          • JoergS5undefined
                                            JoergS5 @deckingman
                                            @deckingman thank you Ian, yesterday my brain extension (read: wikipedia) already helped me to update my short time memory 🙂 It is always interesting to learn from history!
                                            michaelr123undefined 1 Reply Last reply Reply Quote 0
